any upgrades for the stock charging system?
Old December 16th, 2007, 09:51 AM
megadesertdiesel's Avatar
megadesertdiesel megadesertdiesel is offline
Rhino defector
My RZR: green gen 3 racer
how much power does the stock system put out? i want to run lights and gps and a couple of other things. any up grades to the stock system? how about an alternator? i have a alternator on my rhino and love electrical gadgets.
Re: any upgrades for the stock charging system?
Old December 16th, 2007, 10:33 AM
RGERBER's Avatar
RGERBER RGERBER is offline
First Name: RUSTY GERBER
My RZR: 2008 GENERATION 1
it has a 500 watt stator / altenator
Old December 16th, 2007, 06:22 PM
guy48065's Avatar
guy48065 guy48065 is offline
Alternators don't like mud
But seriously Polaris claims 500W for the stator but many folks find their "battery" idiot light comes on with only the headlights on. Does it take 500W to operate the ignition, fuel pump and headlights?? Maybe Ricky Stator is working on this problem right now...
Ricky Stator: Manufacture of ATV & dirt bike stators, electrical componets, lighting systems, and suspension products.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
Old December 16th, 2007, 06:36 PM
RGERBER's Avatar
the Rhino upgrade is 5oo watts
Old December 17th, 2007, 08:19 PM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
Install a good sized battery, run the accessories off it and you shouldn't trip or overload the alternator lamp.
My RZR Project
Keep It Wet and Dirty!
Old December 17th, 2007, 08:30 PM
Cooter's Avatar
Cooter Cooter is offline
My RZR: 800
My battery idiot light comes on with all stock electric. It's either over-rated or the battery sucks.
Old January 3rd, 2008, 12:36 AM
brad4021's Avatar
brad4021 brad4021 is offline
First Name: Brad
My RZR: shiny new RZR-S
im thinkin its the battery cuz im runnin 4 hella 6.5" hids on a rack and the stock replacements wiht no problem. i did run a second battery though just to be safe and the thing has no problem charging it.
Old January 3rd, 2008, 10:34 AM
Johnny's Avatar
Johnny Johnny is offline
UTVCRAP*****
First Name: Johnny
My RZR: the red one
you can buy the polaris service manual and it tells ya all about the charging system and how to test the system with all the lights on ect so you can see how many rpms your motor has to be running to produce a charge I think it was around 3000 rpm with the lights on ect to produce a charge...I was going to check into led taillight bulbs to save some wattage
www.utvcrap.com 623-934-3070
623.934.3070
Old January 3rd, 2008, 11:02 AM
RZRider's Avatar
First Name: Al
My RZR: 08 Red
You can also take your current alternator to any alt/gen rebuild company and have then rewind your alternator for better charging right off idle. I have a lot of gadgets and have found the stock system work fine, just a bigger better battery.
  #10 (permalink)
Old January 3rd, 2008, 08:31 PM
Crowdog's Avatar
Crowdog Crowdog is offline
First Name: Jon
Does anyone know exactly what the blicking battery acutally means?
Does it blink at a certain voltage level?
www.UTVGuide.net
  #11 (permalink)
Old January 4th, 2008, 08:34 AM
Johnny's Avatar
UTVCRAP*****
First Name: Johnny
My RZR: the red one
LOW BATTERY AND OVER VOLTAGE
this warning means that the vehicle is operating at a rpm too low to keep the battery charged. It may also occur when the engine is at idle and high electrical loads (Lights, cooling fan, accessories) is applied. Drive at higher rpm or recharge the battery to clear the warning.
So even polaris say you drive to slow ...................
  #12 (permalink)
Old January 4th, 2008, 08:36 AM
Johnny's Avatar
UTVCRAP*****
First Name: Johnny
My RZR: the red one
You can go into diagnostic display mode and see the voltage 12.0 12.4 ect if you wana call me Ill tell ya how to get into it 602-284-2430
  #13 (permalink)
Old January 4th, 2008, 09:12 AM
Crowdog's Avatar
First Name: Jon
OK, so we know there isn't enough RPM to keep the battery charged, but does it start blinking at a certain voltage or does it actually read that there is more amps going out that there is coming in?
  #14 (permalink)
Old January 4th, 2008, 10:58 AM
Johnny's Avatar
UTVCRAP*****
First Name: Johnny
My RZR: the red one
It starts blinking at a low voltage and or over voltage
if you go out and put a volt meter on the battery with the key off it should read 12.4 volts or more if its not I would charge the battery first
if you have installed a bunch of acc. you can take the ground off the battery put a volt amp meter on DCAmps inbetween the ground post on the battery and the and the battery lead and that will tell you current draw it should not be over .01 dca (ma)
if it was me id test the battery first after charging the battery
load test
hook up the volt meter to the pos and neg on the battery with key off after charging it should read 12.6 or greater if so crank the engine for 15 seconds with the meter still hooked up and during cranking if the voltage drops below 9.5 volts you need a new battery from utvcrap.com
  #15 (permalink)
Old January 4th, 2008, 01:26 PM
guy48065's Avatar
... you need a new battery from utvcrap.com
