Stock Lighting Question |
September 29th, 2008, 08:56 PM
I rode for the first time at night this evening and when I use my brakes or the fan kicks on the lights dim tremendously. Is this normal for a RZR I am used to Rhinos, and if so what can I do to fix it.
2009 RZR S
Re: Stock Lighting Question |
September 30th, 2008, 05:50 AM
Rhino defector
My RZR: green gen 3 racer
relocate the voltage regulator from under seat to under hood area. it needs airflow. it shuts down when it gets too hot.
September 30th, 2008, 08:40 AM
My RZR: the green one
hay megaD, he's got an 09S, reg should be already up front.
September 30th, 2008, 08:41 AM
Yup, I did this mod and problem fix ;-)
Thousand Palms , CA
RZR #23
07 700XP
08 800RZR
September 30th, 2008, 09:38 AM
Pics? I had this happening to me as well.
September 30th, 2008, 09:39 AM
Rhino defector
ok then he is fucked!! popo charging system is just enough to let the engine run.
September 30th, 2008, 10:00 AM
Check all connections and is RZR getting cool air to the reg ;-)
I also installed a front hood grill ;-)
September 30th, 2008, 10:01 AM
Check Martmoe posts on PRC ;-)
September 30th, 2008, 10:48 AM
mine dims a little bit .. but not to bad.. its only for a second or two and then its back on ... bigger battery might fix that problem to ..
September 30th, 2008, 01:33 PM
Thanks!
September 30th, 2008, 02:40 PM
What about mounting a small cooling fan right on top of it. Almost the same as a cooling fan from a computer. They're quiet, use very little power, and theyre cheap. it would keep a constant circulation of air on it...
September 30th, 2008, 02:43 PM
Some have try that and it works a bit, but now you have another item using power ;-)
September 30th, 2008, 03:10 PM
My RZR: 2009 RZR s
Hey Cisco how do you like those lights.... are the holding up well? Bright? whats the lumen rating on them?.... sorry to change the subject
September 30th, 2008, 03:53 PM
We be testing them this weekend ;-)
We will post pic's nad test info ;-)
I will be adding 4 - 7" Hid's on top also for this test ;-)
September 30th, 2008, 04:42 PM
My RZR: 2009 RZR s
Awesome! Im curious to see how they do, keep me posted!
