Bypass Remote Switch / Wire - Polaris RZR Forum - RZR Forums.net
This is a discussion on Bypass Remote Switch / Wire within the Lighting, Stereo and Electrical forums, part of the Technical category; I got a amp I would like to hookup in my rzr. My problem is, the amp needs a remote switch to power up. Well ...
Old April 27th, 2011, 07:17 PM   #1
Newbie to Rzr
Fuzz's Avatar
My RZR: RZR S Orange Madness
Member #15726
View Fuzz's Photo Gallery(0)
Well I'm not running a deck just a ipod. How can I by pass this remote switch so the amp will power up and play some tunes?
Please keep your answers simple. I'm not at all electrically talented. Hooking the speakers to the amp was tough enough! OK I'm not that bad but no far off.
Thanks Folks!
Fuzz is offline   Reply With Quote
Old April 27th, 2011, 07:19 PM   #2
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: Bypass Remote Switch / Wire
if you want it to turn on with the key, there is a keyed power wire under the dash (orange).
if you want it to turn on without the key, I think you have to put in a switch.
Old April 27th, 2011, 10:26 PM   #3
Newbie to Rzr
Fuzz's Avatar
Member #15726
Thankyou Tuf-Skin.
I actually "bridged" from the Power connection to the switch connector. This worked but of course it keys the amp powered on the whole time it connected.
I'm going to try and figure out how to run 2 batteries and put in a switch for the stereo.
I would like to be able to run the stereo without the key on so the hour clock doesn't keep ticking.
Old April 27th, 2011, 10:45 PM   #4
rzr(s)hroom's Avatar
First Name: kevin
My RZR: 2010 rzr s
Member #14447
View rzr(s)hroom's Photo Gallery(0)
to have the amp come on with the key you just need to connect the remote lead to a switched 12v source. the extra orange lead under the dash works great for this
then just run the primary power to the battery (with an inline fuse of course)
rzr(s)hroom is offline   Reply With Quote
Old April 27th, 2011, 11:17 PM   #5
Feedback Score: 26 reviews
MotoXXX's Avatar
First Name: Jeff
Member #4542
You need to add a switch that connects the amp to your battery with an inline fuse if you want to run your stereo with the key off.
MotoXXX is offline   Reply With Quote
Old April 28th, 2011, 05:56 AM   #6
treadsouthwest's Avatar
First Name: Tim
My RZR: 2009 Nuclear Sunset
Member #9047
View treadsouthwest's Photo Gallery(0)
Run the remote wire through a switch and then through a fuse to a power source i.e. the battery. Make sure you have a good ground close to the amp and run the main power wire straight to the battery. Make sure you have a fuse in the main power wire as close to the battery as possible to prevent nasty things happening if the wire shorts somewhere.
treadsouthwest is offline   Reply With Quote
Old April 28th, 2011, 04:27 PM   #7
safehaven's Avatar
My RZR: 2010 RZR-S
Member #15456
View safehaven's Photo Gallery(2)
I haven't put an amp in my RZR yet. But, when I did my Rhino, I connected the remote wire to an illuminated marine rocker switch. It lights up when the amp is on, that way it reminds me to turn it off. Using the switch setup, I can listen to music without the key on.
safehaven is offline   Reply With Quote
Old May 3rd, 2011, 09:58 AM   #8
Newbie to Rzr
Fuzz's Avatar
Member #15726
Just wanted to say thanks to everyone for their help!
I got the stereo hooked up. Sounds pretty good to considering I didn't use high end equipment.
Don't ask to drive it, if you can't afford to fix it!
Old August 6th, 2011, 02:15 PM   #9
Alain's Avatar
My RZR: 2011 rzr XP
Member #28782
View Alain's Photo Gallery(0)
i got my sterio installed at a dealer and they jumped off the main power cable to the remote on the amp and guess what that does...KILLS batterie! glad i found this forum, i will be looking for this orange wire tonight.
Alain is offline   Reply With Quote
Old April 18th, 2012, 10:30 PM   #10
skyler.hager's Avatar
My RZR: 2010 RZR LE 50"
Member #36022
View skyler.hager's Photo Gallery(0)
I'm glad I found this thread! Should really help with my stereo install this weekend.
skyler.hager is offline   Reply With Quote
bypass remote turn on wire
bypass remote wire amp
bypass remote wire car amp
bypass remote wire on amp
bypassing remote wire
car amp rem bypass
car amp remote wire bypass
how to byepass remote wire of amp
how to bypass amp remote wire
how to bypass poweramp rem
how to bypass rem on amp
how to bypass remote wire on amp
how to bypass the remote wire on a amp
marine raido deck power switch bypass
wire toggle switch for remote wire amp yamaha rhino
Turf mode diff installed - How do I wire the switch? dmax61 General RZR Discussion 25 July 25th, 2012 09:28 AM
How to wire my amp, Ipod & GPS on one switch??? dbow32 Lighting, Stereo and Electrical 7 March 31st, 2011 03:24 PM
Need: 4 wheel drive switch and headlight switch for pre 2011 RZR RZR4Crew Want to Buy 4 January 25th, 2011 11:07 PM
Remote AWD switch? GstRdr General RZR Discussion 10 June 24th, 2010 10:27 AM
bypass awd control futuredenied Projects and How-To 8 June 12th, 2010 09:31 AM
