Interior LED's - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old April 4th, 2011, 11:08 AM Thread Starter
TBONE21's Avatar
First Name: Tolliver
My RZR: 13 Jagged X 900
Member #20718
View TBONE21's Photo Gallery(0)
Interior LED's
Anyone fooled with any 12 inch strip led's for your RZR?
Was thinking about adding them under the dash boards to light her up at night.
Do you think they can stand up to the abuse?
LED BLUE 12" STRIP INTERIOR LIGHTS xenon hid MAZDA - eBay (item 190519445651 end time Apr-04-11 12:39:42 PDT)
TBONE21 is offline
post #2 of 8 Old April 4th, 2011, 02:24 PM
WesNewATV's Avatar
First Name: Wesley
Member #21083
View WesNewATV's Photo Gallery(0)
Re: Interior LED's
Yep, a friend of mine used some similar to those to light up under his dash and also under each wheel well and his front grill. I have a similar setup but I used a different style of flexible led light. Ours are constantly in mud and submerged in water and hold up well. Also, that's a pretty good price for a pair of 12" lights.
2011 RZR - SOLD
WesNewATV is offline
post #3 of 8 Old April 4th, 2011, 02:48 PM Thread Starter
TBONE21's Avatar
Member #20718
Re: Interior LED's
would you buy those for this application?
TBONE21 is offline
post #4 of 8 Old April 4th, 2011, 03:00 PM
WesNewATV's Avatar
First Name: Wesley
Member #21083
Re: Interior LED's
I would go for it, the main thing is to make sure they are waterproof and it says they are. With the blue color and as small as a rzr is you may only need one strip in the middle, I have red in mine and they don't seem to be as bright as the blue color in my friends rzr.
Also, if the 3M tape gives you any trouble sticking, I've found that liquid nails works pretty good as an alternative. Just give it a few days dry time to let it set up good.
2011 RZR - SOLD
post #5 of 8 Old April 4th, 2011, 03:09 PM Thread Starter
TBONE21's Avatar
Member #20718
Re: Interior LED's
awesome! Thanks for your help! I ordered a switch today and I am going to order those. What size fuse do you recomend to put inline to run both of them?
TBONE21 is offline
post #6 of 8 Old April 4th, 2011, 03:36 PM
WesNewATV's Avatar
First Name: Wesley
Member #21083
Re: Interior LED's
I'm definitely not an electrical expert, so maybe someone else can chime in, but you may try a 3amp fuse and see how that works. If it gives you any trouble, step it up a to 5amp. I didn't see any power info on the ebay listing, but they don't typically draw that much power. I had (5) 9 inch strips on my first setup and found that a 5amp fuse was just a little to small, so I stepped it up to a 7amp and it worked fine from there.
2011 RZR - SOLD
post #7 of 8 Old April 5th, 2011, 05:41 PM
crnacnac's Avatar
First Name: Jon
Member #1975
View crnacnac's Photo Gallery(1)
Re: Interior LED's
I used these from this same ebay seller. Great item for the price.
crnacnac is offline
post #8 of 8 Old April 12th, 2011, 05:26 AM
RZR2110's Avatar
First Name: Brandon
My RZR: 2011 RZR 900XP LE
Member #24218
View RZR2110's Photo Gallery(0)
Re: Interior LED's
I have used oznium led's in the past on quite a few 4wheelers and have never had a problem out of these. I just resently put these on my xp9 and couldnt be happier. I added a waterproof switch from my local marine store and everything works perfectly. I dont have any exact numbers but can tell you that I have left these lights on over night by accident and had no trouble starting the next morning
STOLEN
2011 RZR 900 XP LE
30 inch Silverbacks on MSA wheels/ EPI Clutch kit Snorkled/ / LED Lights on the corners and grill/SSV works and Fusion audio
RZR2110 is offline
interior lighting badchad626 General RZR Discussion 35 January 18th, 2015 11:01 PM
rv .interior led conversions johnnycat8 Lighting, Stereo and Electrical 41 April 29th, 2012 05:22 AM
More roomy interior??? sandfreak RZR XP 900 16 January 2nd, 2011 09:55 PM
Interior lighting help meatcurtain Lighting, Stereo and Electrical 24 November 5th, 2010 03:37 PM
