LED Brake Light Problem
Old September 1st, 2008, 09:10 PM
jeephreak's Avatar
jeephreak jeephreak is offline
First Name: 'phreak
My RZR: Gen 2
Is anyone else using LED brake lights? I just threw a set in, and they are supposed to run 1/3 bright in normal position and full bright when the brake is applied. Mine are the same no matter what.
I tried flipping them, etc and nothing. Just to make sure things were in proper working order I put the original bulbs back in and they were fine. I read about load equalizers, guessing that is the next step.
Any one else have experience with this?
Re: LED Brake Light Problem
Old September 2nd, 2008, 07:33 AM
Harryscarlot's Avatar
Harryscarlot Harryscarlot is offline
HairRZR
First Name: Harry
My RZR: 2009 RZR
read up on this, it might help out-
Troubleshooting Wiki
A brush with death can inspire you to live............
2009 Polaris RZR 800, 2002 Ducati 998, 1998 Ducati 916, 1998 Ducati 748, 1995 Ninja ZX6R, 1990 Honda Hawk NT650, 2000 Kawasaki Bayou 220 2X4, 2001 Yamaha Breeze 125, 2002 Honda 300ex Sportrax, 2006 Polaris Hawkeye 300 4X4 (JUNK), 2000 Polaris Magnum 325 2X4, 2000 Honda Rancher ES 350 4X4, 2003 Harley Davidson, 2000 Buell Lightning X1
2-2003 Kawasaki Prairie 360 4X4's, 2000 Eton 50cc, 1988 Toyota 4 Runner,1984 Toyota 4 Runner,
Old September 20th, 2008, 12:45 AM
mmotley mmotley is offline
Polaris does it weird -- the brake pedal switches the NEGATIVE lead instead of the positive lead (which is what everybody BUT Polaris does). With a normal bulb it doesn't matter, but LEDs are polarized.
The resistor trick works great. I'm running the same LED's as listed in that article link and they work great. I used 330ohm (I think?) resistors instead of the 470ohm ones, as I wanted the running lights a little brighter.
Old September 20th, 2008, 01:50 AM
boatnaz's Avatar
boatnaz boatnaz is offline
Thanks for the info.
Old September 22nd, 2008, 07:33 PM
txwpd103's Avatar
txwpd103 txwpd103 is offline
My RZR: Greenie - 2nd Gen.
There is a full thread on PRC on this. Do a search for LED without relay. I've done the 330ohm resistor mod and it works great.
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm.
Old September 29th, 2008, 09:17 AM
dmeis dmeis is offline
I didn't want the running lights so I clipped two of the leads on the bulbs so just the brights turn on when I apply the brake pedal.
Old September 29th, 2008, 11:04 AM
ldb ldb is offline
First Name: Kevin
My RZR: Red
The resistor mod works. You don't want your running lights to bright because it will melt the lens if you get mud on the lens.
Old October 14th, 2008, 04:13 PM
billyboy_1 billyboy_1 is offline
My RZR: 2008
I did the mod but had one problem, when sliding the cover off of the led, I had one of the legs come out of the board. It seems that it must have been a cold solder joint from the factory. After repairing the loose leg, i had another one of them pop loose. I ended up having to go buy another pak of the lights to finish the job. my luck..
Old October 14th, 2008, 04:40 PM
gdog gdog is offline
Your running the LED's to save battery power right?
  #10 (permalink)
Old October 14th, 2008, 05:57 PM
martymoe's Avatar
martymoe martymoe is offline
Mad Scientist
First Name: Marty
i did it so i didnt have the melted taillights and they look cool.
  #11 (permalink)
Old October 14th, 2008, 10:42 PM
My RZR: 2008
Yes i did it to save power, plus they look cool
Now if i can get my regulator to stay a little cooler i'll be happy.
  #12 (permalink)
Old October 14th, 2008, 10:56 PM
martymoe's Avatar
Mad Scientist
First Name: Marty
put your regulator up front. it makes a huge difference
  #13 (permalink)
Old October 14th, 2008, 11:05 PM
My RZR: 2008
I was kinda hopeing for a harness kit to move it up front instead of cutting the wires.
  #14 (permalink)
Old October 15th, 2008, 08:57 AM
jeephreak's Avatar
First Name: 'phreak
My RZR: Gen 2
Can someone post a pic of the regulator...so I know what it is and if I want to move it?
thnx.
I didnt have any issues doing the mod - works well!
  #15 (permalink)
Old October 15th, 2008, 07:16 PM
boatnaz's Avatar
Me too!
