OTRATTW 7 pin. Winch Switch Wiring Advise. - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old May 18th, 2017, 09:05 AM Thread Starter
matucci's Avatar
First Name: Michael
My RZR: 2017 XP1K Titanium
Member #170281
View matucci's Photo Gallery(0)
I am in he process of wiring up this switch and wanted to see if my plan is correct. I have read every previous thread but think I got more confused. So I apologize to the members if this has been fully covered. Here is my plan
Pin 2 - connect to 12v ignition source
Pin 1 - to contractor 12v in
Pin 3 - to contractor 12v out
Is this how to connect Pins 1-3?
The pins for the upper and lower lights I am not sure how too wire them. Can I jump 7 and 9 and then to a common ground? And would I jump 8 and 2. And then jump 10 and 2. Thanks for your help.
matucci is offline
post #2 of 3 Old May 18th, 2017, 09:38 AM
Clothier's Avatar
First Name: Brian
Member #65577
Re: OTRATTW 7 pin. Winch Switch Wiring Advise.
Your plan for pins 1-3 and pins 7 and 9 sounds good. Depending on how you want the switch to light up will determine how to wire pins 8 and 10. If you jump 8 and 10 to pin 2, then both lights will be on anytime the key is on. Is this what you are wanting? Thats how I would wire it for a winch myself.
Super Atv, RT Pro(Racertech), Utv Inc, Factory Utv, Super Dave's Bushings, Garage Products Inc., Team FAS Motorsports, OTRATTW, Hunterworks, JJ and A Racing, Gilbert's Custom Utv's, Twisted Werkz Offroad, 606 Offroad, Harts Motorsports Somerset, Ky
Clothier is online now
post #3 of 3 Old May 19th, 2017, 01:36 PM Thread Starter
matucci's Avatar
First Name: Michael
Member #170281
Thanks for the info. I guess it make sense to have to light on for a Winch Switch. Thanks for the advise.
matucci is offline
Wiring a 5 pin, 2 LED rocker switch using a fuse block RZRRobb General RZR Discussion 7 March 23rd, 2017 10:29 AM
7 pin rocker switch for a winch VancouverIslandRZR General RZR Discussion 5 October 21st, 2016 11:33 AM
Viper Elite Winch Install - Electrical - 2016 RZR S 900 joshrhykerd Lighting, Stereo and Electrical 5 May 4th, 2016 05:37 AM
Winch switch wiring question Beestieboy Lighting, Stereo and Electrical 14 April 26th, 2016 08:10 AM
Help wiring a winch 7 pole dash switch nateburch Lighting, Stereo and Electrical 5 January 16th, 2016 02:47 PM
