Mounting a whip |
November 19th, 2007, 12:08 AM
Mounting a whip
Where and what do you use to mount a whip?
Re: Mounting a whip |
November 19th, 2007, 10:08 AM
Re: Mounting a whip
November 20th, 2007, 10:15 AM
Re: Mounting a whip
The only place I dune is Silver Lake in Michigan. They require the flag be mounted in front. Their explanation sort of makes sense (Silver Lake is small...you will spot a front-mounted flag coming over a hill sooner).
If you don't have a bumper, there's nowhere to mount the whip--it's all plastic up front. My solution was to make a stiff bracket that mounts to the existing bumper holes & steel support. This requires no mods so it's reversible. It's just a short piece of 1/4" 2x2 angle iron, shaped to look nice.
And yes that's an ordinary air hose quick release on the whip. Since this mount can't fold up I needed a way to remove the whip easily for trailering.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
December 17th, 2007, 08:21 PM
First Name: Al
My RZR: 08 Red
Re: Mounting a whip
e-bay has a few whip mounts listed all the time.
I really like the unit Axia makes but man aluminum is getting pricey.
December 17th, 2007, 09:25 PM
Re: Mounting a whip
The AXIA Alloys clamp system is bar far the cleanest set up I have seen we have them in stock there are a couple of variations you can use.
Unleashed UTV
5838 N. 19th Ave
602-246-4011
December 18th, 2007, 12:33 PM
Re: Mounting a whip
Where would it clamp on in the "front" of the Razor?? which is where he has to have his whip mounted.
Rog
December 18th, 2007, 01:14 PM
Re: Mounting a whip
The axia alloys clamp would only work on the front of a rzr if it had an aftermarket bumper installed as they clamp around tubing.- mike
December 18th, 2007, 08:13 PM
Re: Mounting a whip
Rog
Ya the AXIA set up will clamp to any tubing and it can be vertical or horizontal
December 18th, 2007, 10:01 PM
My RZR: two red ones
Re: Mounting a whip
I was mostly sold till I read this " it can be vertical or horizontal" how so or better yet surely you don't mean and the whip is vertical with either application..
December 18th, 2007, 10:14 PM
Re: Mounting a whip
By using defferent brackectry you can have your whip (pointing up) mounted on a vertical bar or horizontal bar.
December 19th, 2007, 12:28 AM
Re: Mounting a whip
look under sand rail whip mounts they look the same and are about 1/50 the cost i have a quik fold down so i can leave it on in the trailer
December 19th, 2007, 12:36 AM
Re: Mounting a whip
Do you have a link
December 19th, 2007, 07:52 AM
Re: Mounting a whip
December 19th, 2007, 07:41 PM
Re: Mounting a whip
