I can help with any stereo questions......
Old July 9th, 2008, 11:57 PM
RZRwanter0019 RZRwanter0019 is offline
Laughing I can help with any stereo questions......
I have noticed ALOT of very basic questions about using stereo's or amps in the rzr. Its all very easy depending on how crazy you want to get. I installed a Lightning Audio amp under the hood. A Equalizer under the dash and kicker marine audio boat speakers on the back. Boat tower speakers are by far the best and easiest way to get sound!!! cheap on ebay. even the cheap ones are better than the Polaris speakers. If anyone would like help answering questions feel free to just ask.
Re: I can help with any stereo questions......
Old July 10th, 2008, 02:49 PM
crnacnac crnacnac is offline
Is your equalizer attached with a zip tie?
Old July 10th, 2008, 03:47 PM
USMCSKI's Avatar
USMCSKI USMCSKI is offline
Tell me about that bar on the back of the machine that the speakers are mounted to!!
I am looking to do a 4 speaker set up- 2 under the dash-possibly 2 boat tower with a marine grade amp and Ipod as source.
2008 RZR
Old July 10th, 2008, 05:41 PM
the zip tie is holding part of the facotry wires. u want me to weld it? i dont get the smart ass question about a zip tie?
the rear bar is just 1 3/4 tube bent to fit. most tower speakers fit 1 3/4 the best.
Old July 11th, 2008, 11:30 AM
Sorry if that came off rude. Not a smart ass question. That's the same place I mounted my head unit.
Jon
Old July 11th, 2008, 05:31 PM
ohiotodd's Avatar
ohiotodd ohiotodd is offline
razor abuser
First Name: todd
My RZR: 3rd gen red
wow too much coffee in the morning or what ? the guy asks a straight forward honest question after you say "feel free to just ask" and thats the reply man your off to a great start on the forum and to be totally honest looks to me like its zip tied as well looks like you used a piece of that universal mounting strap stuff with the holes drilled in it bent it in a U bolted one end to the eq and ziped the other end to the frame
Old July 12th, 2008, 12:22 PM
Jeffro Jeffro is offline
My RZR: 2008 Green Gen 3
Doesn't your amp get to hot in there? I was thinking about getting the maier hood so it can get some air in there before I put an amp in there.
Jeffro
08' Green Polaris Rzr (Gen 3)
26" ITP Mudlite XTR's on 12" Vision Bruiser Wheels
Deluxe Front & Rear Brushguards
3500lb Polaris Winch
Old July 13th, 2008, 10:15 AM
Sprinklerhead Sprinklerhead is offline
First Name: Kevin
My RZR: uuhh-Green
Well im gonna try my hand at asking a question.I have the marine jensen stereo that polaris advertises and speakers,and i also have sirius satellite receiver mounted on dash.I use satellite wirelessly so i can quickly put it back in truck when not riding.My problem is that while riding and jamming @high volume,my low battery warning on stereo will eventually start chirping.Can this be fixed by installing a battery with a little more crank amperage or is there something else that needs to be done?I have thought about a more powerful battery anyways to accomodate any other devices i may pursue.Am i on right track or not?
Old July 13th, 2008, 04:13 PM
ohiotodd's Avatar
razor abuser
First Name: todd
My RZR: 3rd gen red
bigger battery also consider a deep cycle battery plus there are alternator kits availible that will charge your battery far better and battery trays are out there as well that allow you to run dual batteries either way you go get a trickle charger and keep it on when ever not riding as your stator really doesnt do a great job at keeping your battery charged all the way its actually almost maxed out with your lights on and cooling fan running if you do alot of slow low rpm ridingso starting out with a battery thats fully charged is a step in the right direction
  #10 (permalink)
Old July 13th, 2008, 11:07 PM
First Name: Kevin
My RZR: uuhh-Green
Thank you sir.And thanx for not being a smart ass to me!!!!heheheheh
  #11 (permalink)
Old July 14th, 2008, 06:16 AM
THNKTWCE's Avatar
THNKTWCE THNKTWCE is offline
You can put in a ranger xp battery, and it might take care of your problems.
That would probably be the cheapest route.
Just Muddin!
  #12 (permalink)
Old July 14th, 2008, 11:42 PM
Ive been really suprised. I have never seen the low battery light or warning... its cranked up full blast the whole time riding! The amp hasnt ever shut off or got too hot.
I do want to do the maier hood but then water coming in might be a problem..
  #13 (permalink)
Old July 15th, 2008, 01:16 AM
CHESBIRDS RZR's Avatar
CHESBIRDS RZR CHESBIRDS RZR is offline
First Name: Jeremiah
My RZR: 2008 RED,1/2 SHIELD,SPORT ROOF,ITP112 27"XTR'S, 3" ROKTEK LIFT
Ok , my question is >What is a cheap way to put a regular old marine radio and 1 old marine speaker(between the seats,you know the little spot)I have NO wireing exp. I just want some sounds.Do I run staight to the battery or will this screw things up?May be a dumb ass question but I have been called a dumb ass by my wife countless times.
No wiring exp. But I do have access to alot of CNC machines and UHMW (I do have to buy the UHMW)I'm making some neat little items for my RZR , So I need a radio in a Cheap way.
  #14 (permalink)
Old July 15th, 2008, 03:28 AM
ohiotodd's Avatar
razor abuser
First Name: todd
My RZR: 3rd gen red
yes you can go straight off the battery as long as you remember to turn the radio off everytime you park id rather go off the ignition so the radio goes on and off with the key theres an extra orange wire with a connector already on it under the dash comming off the 12v outlet its switched with the ignition pretty easy to use it
  #15 (permalink)
Old July 15th, 2008, 11:04 PM
I think the easiest is using a switch to turn the stereo?amp on and off. I didnt want to mess with my ignition switch and fuse box. affraid I would pop a fuse way out somewhere
One speaker in the middle should be plenty. mount a cheap cd player under the dash and be good to go!
most electronic shop sell marine audio. if not ebay is always a good place.
