Grounding!
Old July 7th, 2008, 10:42 PM
RZRARMY RZRARMY is offline
My RZR: 2008 RZR
Grounding!
Just thought I would make a quick post about something that is often overlooked. A Good Ground Point!
I've attempted to help people over the phone many times diagnose electrical problems mainly starting issues. Every time I mention to check their ground and they grab the "Black Wire" and see if it's loose and then quickly move on to what they really think is wrong when they just missed the real issue.
Even straight from the factory they miss the boat. Surface area really makes a difference over just those few exposed metal threads are providing. This won't give you 20% HP increase, but it can recover lost electrical power. Things loosen up and corrode over time especially in our environment.
I have a special little tool called a Piloted Bonding Brush that runs about $15 and really gets used more than you think. You don't have to use one, but it makes it a 10 second job and is neat.
Here is what you get.
This first image is the main ground point near the battery.
Here is the result from the Bonding Brush.
http://rzrarmy.com/images/A_7/4/0/5/...fter_db9f5.jpg
Here are a couple other examples...One being the HID setup...This is an even more important place to have a proper ground.
http://rzrarmy.com/images/A_7/4/0/5/...ter3_e48a8.jpg
http://rzrarmy.com/images/A_7/4/0/5/...ter2_f7b9f.jpg
Here is the Piloted Bonding Brush...
http://rzrarmy.com/images/A_7/4/0/5/...rush_6b004.jpg
Anyway I thought I would share. You can get these from most electrical supply houses or Google "Piloted Bonding Brush" and find some Online sales.
Re: Grounding!
Old July 7th, 2008, 11:30 PM
Re: Grounding!
i like that i use a gun cleaning brush it works good to but that is a lot nicer.... ya grounds suck on anything i find bad ones alot..... many a missfire on inj and fuel pumps and from people that tend to steam clean alot even detailers that go crazy cleaning carpets in cars i do alot of used car dealers and the detailers tend to drown the interiors alot not knowing the amout of grounds beneith the carpet and the moisture that gets up under the dash!!!!!
2006 silverado 2500 hd
2006 additude toy hauler
2008 polaris rzr
2006 suzuki ltr450
2005 kawisaki kfx700
2003 suzuki z400
2003 honda ex250
Re: Grounding!
Old July 8th, 2008, 08:50 PM
My RZR: 2008 RZR
Re: Grounding!
Johnnycat picked up on something I forgot to mention and that was the point about the Fuel Injection system.
I also replaced the engine ground and the starter power wire with newer heavier gauge wire and better terminals. It's a fairly cheap modification that is also easy to do. I'll post those pics later.
