LED brake lights how to - Polaris RZR Forum - RZR Forums.net
This is a discussion on LED brake lights how to within the Lighting, Stereo and Electrical forums, part of the Technical category; Some time back HawkEng had a post on how to wire in or add LED brake lights by using a relay it was post #20 ...
Old August 24th, 2010, 07:58 PM   #1
Buckys1's Avatar
My RZR: RZR-4
Member #13545
View Buckys1's Photo Gallery(0)
Some time back HawkEng had a post on how to wire in or add LED brake lights by using a relay it was post #20 1-29-10 I have a 2010 RZR-4 and have looked at the schematic and wired it just about every way I can think of and it still will not work, from RZR brown to ground to light, from RZR orange to #86 , from RZR R/Y to #30 and 85 , from light orange to # 87A , from light R/Y to #87, I changed out the brown and R/Y slots on the light, is there someone out there that might tell me what I'm still missing , I keep blowing fuses when I step on the brake .
Buckys1 is offline   Reply With Quote
Old August 24th, 2010, 08:02 PM   #2
Feedback Score: 19 reviews
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
Re: LED brake lights how to
Go back to stock and start over.
I wired mine from that schematic and it works fine.
If you have changed the wires at the tail lights you must use an LED or you will blow a fuse
using a regular 3157 bulb.
quadnkev is offline   Reply With Quote
Old August 24th, 2010, 08:04 PM   #3
Craig_c's Avatar
Member #11066
View Craig_c's Photo Gallery(0)
You have to wire the relay just like that post showed, but you also have to swap wire position at the bulb connector.....I did it on mine, but I dont remember what went where....Im kinda an expert at automotive electrical so I just did it and was done with it....maybe someone on here know what wire goes where. I can go look at mine tomorrow and post back
Craig_c is offline   Reply With Quote
Old August 24th, 2010, 08:10 PM   #4
Buckys1's Avatar
My RZR: RZR-4
Member #13545
All I'm trying to do is add some flashing LED's to what I have using the same bulbs in the tail lights , could that be why I'm having problems?
Old August 25th, 2010, 07:38 PM   #5
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
YES BIG TIME YES ALL TAIL LIGHTS NEED TO BE LED.
Reread my above post that is your basic problem mixing apples and oranges.
Old August 25th, 2010, 07:54 PM   #6
Buckys1's Avatar
My RZR: RZR-4
Member #13545
Ok today replaced regular bulbs with LEDs and still will blow fuse, turn on key no tail lights , step on brake and then it blows the fuse. is there any way the RZR-4 is different from the standard RZR are any of the ones that have responded that have made this change the RZR-4. Something is amuck or I'm just not seeing how it is wired from the drawing or missing a step somewhere.
Old August 25th, 2010, 07:59 PM   #7
Feedback Score: 18 reviews
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
Thought I would post Jason's diagram here for reference
GIFF-TURBO is offline   Reply With Quote
Old August 26th, 2010, 08:09 PM   #8
Craig_c's Avatar
Member #11066
you have to switch the wire position at the tail light bulb so that the ground wire is the shared terminal at the bulb.
Old August 26th, 2010, 09:15 PM   #9
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
I used this schematic and as stated above switched the wires for the brake light power and ground at each tail lamp assembly.
http://www.rzrforums.net/lighting-st...hematic-3.html
See Bobholthaus post #44.
Mine work fine and also added a high level Tail/Brake lamp too.
Disregard the relay for the trailer portion unless you want that, I did not.
I mounted my relay after the factory connection under the bed so if you take the bed off
it will be part of what comes off.
I hope this helps.
Old August 26th, 2010, 09:58 PM   #10
Buckys1's Avatar
My RZR: RZR-4
Member #13545
All I switched the two wires at the light, wired in the relay per the drawing, used LED tail lights and still would blow out the fuse, gave up and put back to stock. has anyone with an RZR-4 tried this and made it work
Old August 27th, 2010, 12:28 AM   #11
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
So are you still blowing a fuse after going back to the original wiring setup?
3157 led fuse blowout
adding a brake light to a polaris atv
how to led brake lights on a polaris rzr
how to wire auxiliary brake lights on polaris rzr
how to wire led brake lights on a rzr4
is there any way to adjust the rzr4 turning
led brake
polaris led light wiring
rzr 170 tail light led safe
rzr brake light
rzr led brake light
rzr led tail light bulb
rzr orange led
what fuse to use for led brake light
wire led brake rzr
LED Tail/Brake Lights and Trailer Hookup!!! Kid Dynomite Lighting, Stereo and Electrical 4 August 12th, 2010 10:23 AM
brake lights wont light up wheni push pedal stickman89 Lighting, Stereo and Electrical 1 July 7th, 2010 08:09 PM
Foot Pedal e-brake or Line Lock e-brake RZRider General RZR Discussion 10 December 12th, 2009 10:04 PM
LED Brake/Tail lights Gunfighterdusty Lighting, Stereo and Electrical 10 April 30th, 2009 09:44 PM
J.Strong Roof with Stereo / Lights / Dome Lights LTZ470 General RZR Discussion 6 April 27th, 2009 09:17 PM
