No Power - Polaris RZR Forum - RZR Forums.net
No Power
This is a discussion on No Power within the Lighting, Stereo and Electrical forums, part of the Technical category; Here's the deal. I installed the large battery kit for my RZR and had a left over generic optima battery that I placed in there. ...
Old July 13th, 2010, 06:29 AM   #1
polaristracker's Avatar
Member #7056
View polaristracker's Photo Gallery(0)
No Power
Here's the deal. I installed the large battery kit for my RZR and had a left over generic optima battery that I placed in there. The battery had sat for a year (unfortunately) but I thought it should still have some life left because I bought it new.
Anyways I noticed if I let the RZR sit for more than a day, I had to jump the battery to get it started (I wanted to buy a new battery next paycheck). So this last time I jumped it when I removed the jumper cables it shut off. I went to turn it over again and no luck. I was frustrated so I went out that day and bought an Optima battery. After installing the battery I turned the key to prime (power was on) but when I went to turn for ignition all power went out. I checked the battery all is good, all wires and connections at the battery are good (ground good). Starter fires like a champ when a direct wire to the positive on the battery.
I have not put a multitester (need to get one) to the voltage regulator or alternator and to truly test the alternator I probably need to take it out and get it tested at an auto parts store. However I am guessing it is the voltage regulator, because if it was the alternator wouldn't I get some power DC from the battery and when I went to turn the key to turn over the engine then it would be a no go?
FYI my voltage regulator is located in front of the radiator?
ANy suggestions or advise is welcome
THX
polaristracker is offline   Reply With Quote
Old July 13th, 2010, 07:12 AM   #2
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: No Power
THX
Check your starter / brake switch located under the seat on the main frame rail behind the battery... Also check the sarter diode on the fire wall by the fuse box...
Old July 13th, 2010, 07:48 AM   #3
bwinkl04's Avatar
First Name: Brian
My RZR: '10 RZR S
Member #16740
View bwinkl04's Photo Gallery(0)
Re: No Power
yep, if the battery is new and has 12 - 14 volts, and the starter will turn over when you direct wire it, but not with the key, then it's not the voltage reg. or alternator. Alternator only keeps the battery charged.
If you have a continuity tester, you can test the ignition switch.
When looking at the back of the switch, you should see 6 pins on the switch... call these, from left to right, a - f.
- with the switch in off position, you should have continuity between e and f (last two pins).
- with the switch in on position, you should have continuity between c and d (middle two pins).
- with the switch in on position, you should have continuity between a and f (first pin, last pin).
- with the switch in start position, you should have continuity between a and b (first two pins).
- with the switch in start position, you should have continuity between c and d (middle two pins).
Also, when you direct wired it, did you go to the starter, or the starter solenoid? if you follow the heavy positive wire back for the starter, you should come to the solenoid (sorry, I'm not sure where it is located). there should be 2 heavy gauge wires connected, and a plug with 2 small gauge wires. if you unplug the small wire and put 12volts to on, and ground to the other, will the starter turn? if not, thats your problem.
bwinkl04 is offline   Reply With Quote
110 polais no power key on
2009 polaris ranger battery good but no power at all when key is on
2009 polaris rzr no power to key switch
2012 rzr no electrical power
450 polaris sportsmanno ign power
genaric polaris battery
no power on rzr
polaris no power to key voltage regulator
polaris rzr stereo no power
rzr ignition left in on position
rzr no power
rzr no power to lights
test voltage regulator rzr
turn key no power
Looking for power gskaggs12 Engine and Drivetrain 1 March 15th, 2010 12:15 AM
More Power digarcia1987 Engine and Drivetrain 13 February 23rd, 2010 06:29 AM
need more power mikemnkt Forced Induction 2 December 8th, 2009 11:35 AM
RzR Power? 98rickstang General RZR Discussion 12 September 20th, 2009 06:02 PM
rzr s needs some power bigguyrides RZR-S Specific Discussion 9 March 3rd, 2009 08:51 AM
