Battery Problems - Polaris RZR Forum - RZR Forums.net
Battery Problems
This is a discussion on Battery Problems within the Lighting, Stereo and Electrical forums, part of the Technical category; OK for some reason if I let my RZR sit say over a week the battery will become completly dead. Nothing is on the key ...
Old July 9th, 2010, 09:21 PM   #1
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
Battery Problems
OK for some reason if I let my RZR sit say over a week the battery will become completly dead. Nothing is on the key is off and stereo what the hell is goin on? I put on trickle charger and it wont charge it it says abort. Also Ive noticed my battery light flashing severeal time while I ride a while I didnt know if it had anything to do with this. This time im goin to Wal Mart these batterys are high.
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
HivoltageRZR is offline   Reply With Quote
Old July 9th, 2010, 09:33 PM   #2
King of crash!
Member #787
Re: Battery Problems
clock ...ecm and stereo memory all drain 24/7
Old July 9th, 2010, 09:38 PM   #3
My RZR: Gen 3
Member #2522
so if it wont charge on a trickle charger its toast right? Napa or everstart? Also should I get a little bigger battery?
Old July 9th, 2010, 09:41 PM   #4
King of crash!
Member #787
some times a trickel wont bring them back a pulse or digital charger might work.... but stock batterys are not the best. interstae diehard are both good for a stock equal
Old July 10th, 2010, 09:57 PM   #5
My RZR: Gen 3
Member #2522
Wow went to Napa today and bought there battery and it was $110. Anyways would my battery tray being full of sand and mud make my battery die so early?
Old July 10th, 2010, 10:21 PM   #6
rzrnaz's Avatar
My RZR: 2014 XP4k
Member #1446
View rzrnaz's Photo Gallery(0)
Shouldn't have any effect.
rzrnaz is offline   Reply With Quote
Old July 10th, 2010, 10:47 PM   #7
chloeedad's Avatar
First Name: Gary
My RZR: 2010 RZR S Pearl White
Member #10250
View chloeedad's Photo Gallery(0)
Change over to an Odyssey and call it done...
2010 Polaris RZR S Pearl White
3" Catvos Lift
30" Mud Lite xxl on 14" ITP Rims
Dirty Dawg Clutch
2-Tow Ropes for the RHINO"S
chloeedad is offline   Reply With Quote
Old July 10th, 2010, 10:59 PM   #8
rzrnaz's Avatar
My RZR: 2014 XP4k
Member #1446
Odyssey's kick butt. Just waiting a reasonable amount of time before canning my '10 stock battery for an Odyssey. First sign of any issue and it's off to the recycling bin for the stock battery.
Old July 10th, 2010, 11:23 PM   #9
chloeedad's Avatar
First Name: Gary
Member #10250
My stock one died after a hard day of winch use...I cut my battery tray out and went with a blue top deep cycle...no more issues running stereo with amp, lights and winch at the same time...
3" Catvos Lift
Dirty Dawg Clutch
Old July 11th, 2010, 06:14 AM   #10
My RZR: Gen 3
Member #2522
would this Napa battery be better than stock? How much are Odyssey?
Old July 11th, 2010, 10:34 AM   #11
rzrnaz's Avatar
My RZR: 2014 XP4k
Member #1446
NAPA would likely be better than stock. Last Odyssey I bought was about $169. Pricey, but it's an AGM battery, can be mounted in any position, and really can pump out a lot of current and volts for a long time.
Old July 23rd, 2010, 07:13 PM   #12
Sand Pimp
DunerRZR's Avatar
First Name: Jeremy
My RZR: 2011 RZR XP LE
Member #10418
View DunerRZR's Photo Gallery(33)
maybe u should change ur name to LOWvoltageRZR
sorry
2011 RZR XP LE
2011 Megacab Cummins
2007 Weekend Warrior SLC 3705
DunerRZR is offline   Reply With Quote
Old December 23rd, 2010, 05:29 PM   #13
keith88jrfan's Avatar
First Name: Keith
My RZR: 2011 RZR XP
Member #5873
View keith88jrfan's Photo Gallery(0)
ODYSSEE
keith88jrfan is offline   Reply With Quote
Old December 23rd, 2010, 05:41 PM   #14
Waistdeep's Avatar
My RZR: 2011 RZR Camo
Member #18687
View Waistdeep's Photo Gallery(0)
put a second battery in mine with a disconnect so that my secondary battery which runs all accesories will be the one dropping the ball not my main which runs the ride
Waistdeep is offline   Reply With Quote
Old December 28th, 2010, 12:44 PM   #15
diagdude's Avatar
Member #21210
View diagdude's Photo Gallery(0)
All Polaris vehicles should be stored with the battery disconnected, as the ECU draws a small amount of power even with the key off. The not so good factory batteries only compound this problem.
The only real fix is to buy a good battery, and keep it disconnected if the RZR doesn't see a lot of use. The easiest way to accomplish this without having to drag out a 10mm socket every time you want to disconnect/reconnect the battery would be to buy a battery disconnect.
diagdude is offline   Reply With Quote
2010 ranger xp battery problems
2012 polaris rzr napa battery
batteries polaris ranger napa
battery problem
battery symbol flashing on polaris 08 razr
napa atv batterie review
polaris battery problems
polaris ranger battery problems
polaris razor battery problems
polaris rzr battery issues
polaris rzr battery problems
problems with polaris r z r
rzr battery runs down after i wash it
rzr forum battery problems
Battery problems 08RZRCBNFBR Lighting, Stereo and Electrical 13 May 4th, 2012 09:42 AM
PAC200 Battery Isolator Problems odmiese Lighting, Stereo and Electrical 0 March 27th, 2010 08:53 AM
battery problems bchaney304 Engine and Drivetrain 2 July 25th, 2009 08:18 AM
battery problems bchaney304 General RZR Discussion 2 July 1st, 2009 08:23 PM
Battery problems rogerpjr Lighting, Stereo and Electrical 10 May 13th, 2009 01:44 PM
