odyssey battery on razor?
This is a discussion on odyssey battery on razor? within the Lighting, Stereo and Electrical forums, part of the Technical category; is anyone running an aftermarket battery on their razor? i have been looking at the odyssey batteries. what other kinds are yall running? looking for ...
Old June 21st, 2008, 06:44 PM
gettherefast's Avatar
First Name: ashley
My RZR: 2008
Member #2957
View gettherefast's Photo Gallery(0)
is anyone running an aftermarket battery on their razor? i have been looking at the odyssey batteries. what other kinds are yall running? looking for stock size battery but high output. thanks
Old June 21st, 2008, 08:37 PM
First Name: ashley
My RZR: 2008
Member #2957
Re: odyssey battery on razor?
after doing a search on here i found where some people are using a odyssey battery but its not fitting in the stock location. sorry for another post asking bout these batteries guys. should have done the search first. still need to know a part number for a direct replacement for the stock battery with an odyssey battery or is there such a thing.
Old June 22nd, 2008, 06:02 AM
wirehap's Avatar
HAP
First Name: HAP
My RZR: 0 ride with a friend
Member #2906
View wirehap's Photo Gallery(0)
In the newest sxs magazine there is a replacement battery and box for the rzr. looks like a good product.
HAP
Old June 22nd, 2008, 12:46 PM
Feedback Score: 4 reviews
Member #787
View johnnycat8's Photo Gallery(53) Send a message via Yahoo to johnnycat8
i droped my oddesy 925 right in .....mine is a 2nd gen rzr no cutting just turned it on its side and hooked it up took 5 min to do....stock battery hold down also 0 as in no modifacations at all
2006 silverado 2500 hd
2006 additude toyhauler
2008 ww toyhauler
2008 polaris rzr-dirty
2006 suzuki ltr450-fast
2005 kawisaki kfx700-comfy
2003 honda ex250-easy
Old June 22nd, 2008, 02:38 PM
SSVworks's Avatar
SSV Works
Member #707
View SSVworks's Photo Gallery(0)
yep,a 925 drops right in. i bent the battery strap slightly to fit better and i trimmed the 'ears' of the battery box towards the back of the RZR to make it easier to get the bolts into the battery.
Old June 22nd, 2008, 03:20 PM
PerryMason's Avatar
First Name: Steve
Member #1575
View PerryMason's Photo Gallery(0)
CA Re: odyssey battery on razor?
I am happy with my Optima yellow top. I got an aftermarket holder on ebay.
Old June 24th, 2008, 10:23 AM
acrijos's Avatar
Member #2248
View acrijos's Photo Gallery(0)
EMP sells a replacement battery holder for a full size Optima.
  #8
Old June 24th, 2008, 10:40 AM
agentzoey's Avatar
My RZR: Gen 1
Member #2081
View agentzoey's Photo Gallery(0)
So, which one is a 925? Yellow, Red or Blue?
  #9
Old June 24th, 2008, 01:06 PM
firehawk001's Avatar
First Name: Darr
Member #2090
View firehawk001's Photo Gallery(0)
i got the battery trey from sidexsidesports. then i got an exide o6 battery (basically the same as an optima. do not let anyone in fooling you that the battery trey drops right in. mine was a pain had to move wiring harness and cut out factory box. the exide is taller than an optima so the bar that holds the battery in place doesn't fit perfect i used several zip ties and fashioned me a bolt. it has worked great. i am running 5 piaa lights, winch, 200w amp speakers and ipod. i will soon add a cigarette lighter seeing as it is hard as hell to light one running 30+ mph in the woods...haha
  #10
Old June 24th, 2008, 03:09 PM
RZRARMY's Avatar
My RZR: 2008 RZR
Member #2837
View RZRARMY's Photo Gallery(0)
You got a totally different battery than was being discussed. The Odyssey is also completely different than the Optima and Orbital(Exide). The Orbital has a larger outer casing and will not drop right in place. The Optima won't either without cutting out the plastic OEM case in the Gen2 and using one of the aftermarket metal brackets.
The Odyssey 925 is about 40% smaller than either the Optima or Orbital and literally drops right into the Gen2 battery tray. You only have to do minor trimming of plastic on the backside to make the terminals easier to access.
I prefer the Odyssey batteries over the Optima and Orbital for the size and the warranty(3year replacment) and just overall quality.
  #11
Old June 25th, 2008, 05:23 AM
agentzoey's Avatar
My RZR: Gen 1
Member #2081
So, which one is the optima 925?
  #12
Old June 25th, 2008, 01:01 PM
TEXMudder's Avatar
Member #1840
View TEXMudder's Photo Gallery(0)
There is no optima 925. There is an odyssey 925 seen here: ODYSSEY Batteries - Battery Specifications
  #13
Old June 26th, 2008, 05:22 AM
agentzoey's Avatar
My RZR: Gen 1
Member #2081
Oh, I thought we were talking the same thing. The optima is a different battery all together.
  #14
Old June 26th, 2008, 07:09 AM
SSVworks's Avatar
SSV Works
Member #707
yep. optima is like a full size car battery. Either red, blue or yellow.
Odessy is 2/3 the size and more power cranking power then an optima, but maybe less reserve time due to size.
My customer had an Interstate Batt rep (optima) come into his shop to get him to swap battery lines. They tested the optima and it put out around 850 amps. The Odessy pc925 put out 1127. The rep was shocked, took his battery and went home. Both are good, we've used both. It's like Ford or Chevy. All preference
  #15
Old June 27th, 2008, 08:28 AM
agentzoey's Avatar
My RZR: Gen 1
Member #2081
So, will the odyssy 925 fit in the Gen 1? Also, does it have more reserve than the stocker?
Bookmarks
Aluminum Odyssey 925 battery box for gen1 twvette General RZR Discussion 0 January 31st, 2009 04:46 PM
Odyssey 925 and Alternator enough? RockRazr Lighting, Stereo and Electrical 9 January 1st, 2009 07:25 PM
Odyssey 925 and Alternator enough RockRazr Lighting, Stereo and Electrical 0 December 31st, 2008 07:13 AM
Odyssey PC925L Battery Charger? BigSilly450X General RZR Discussion 9 December 26th, 2008 03:20 PM
Odyssey or Yellow top? BigSilly450X General RZR Discussion 38 December 5th, 2008 05:12 PM
