is anyone running an aftermarket battery on their razor? i have been looking at the odyssey batteries. what other kinds are yall running? looking for stock size battery but high output. thanks
after doing a search on here i found where some people are using a odyssey battery but its not fitting in the stock location. sorry for another post asking bout these batteries guys. should have done the search first. still need to know a part number for a direct replacement for the stock battery with an odyssey battery or is there such a thing.
i droped my oddesy 925 right in .....mine is a 2nd gen rzr no cutting just turned it on its side and hooked it up took 5 min to do....stock battery hold down also 0 as in no modifacations at all
yep,a 925 drops right in. i bent the battery strap slightly to fit better and i trimmed the 'ears' of the battery box towards the back of the RZR to make it easier to get the bolts into the battery.
i got the battery trey from sidexsidesports. then i got an exide o6 battery (basically the same as an optima. do not let anyone in fooling you that the battery trey drops right in. mine was a pain had to move wiring harness and cut out factory box. the exide is taller than an optima so the bar that holds the battery in place doesn't fit perfect i used several zip ties and fashioned me a bolt. it has worked great. i am running 5 piaa lights, winch, 200w amp speakers and ipod. i will soon add a cigarette lighter seeing as it is hard as hell to light one running 30+ mph in the woods...haha
You got a totally different battery than was being discussed. The Odyssey is also completely different than the Optima and Orbital(Exide). The Orbital has a larger outer casing and will not drop right in place. The Optima won't either without cutting out the plastic OEM case in the Gen2 and using one of the aftermarket metal brackets.
The Odyssey 925 is about 40% smaller than either the Optima or Orbital and literally drops right into the Gen2 battery tray. You only have to do minor trimming of plastic on the backside to make the terminals easier to access.
I prefer the Odyssey batteries over the Optima and Orbital for the size and the warranty(3year replacment) and just overall quality.
yep. optima is like a full size car battery. Either red, blue or yellow.
Odessy is 2/3 the size and more power cranking power then an optima, but maybe less reserve time due to size.
My customer had an Interstate Batt rep (optima) come into his shop to get him to swap battery lines. They tested the optima and it put out around 850 amps. The Odessy pc925 put out 1127. The rep was shocked, took his battery and went home. Both are good, we've used both. It's like Ford or Chevy. All preference
I did it in a gen 2, i don't think that changed between the gen's. Post a pic of your battery tray and i'll tell you for sure. It has WAY more reserve then stock. It has more cranking power then your diesel truck battery so when it is running low, it'll still get ya going.
ok here are specs for the orbital, odyssey and Optima batteries you all are using. some manufacturers listed more info than others. keep in mind the odyssey 925 is half the size of both the optima and orbital batteries and half the weight. I am also including an odyssey model at the bottom that is the same size as the optima and orbital just to put things into propper perspective..I am probably biased as I use odysseys in everything and have had 100% perfect luck with every one I have purchased. I dont know how many of you want to haul around a full sized car battery under your seat in a utv ( LOL) but thats what both the optima and orbital are.
optima yellow top MODEL NUMBER D34/78 R
Cold Cranking Amps @ 0F 750
Cranking Amps @ 32F 870
Reserve Capacity 120min
PHYSICAL SPECS
Length 10" 9 5/16"
Width 6 7/8"
Height 7 13/16"
Minimum Weight (lbs) 43.5
Odyssey PC 925 Specs:
925 cranking amps for 5 seconds
870 cranking amps for 10 seconds
765 cranking amps for 20 seconds
Short circuit current over 2400A
28 amp hours
50 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
Length 6 15/32"
Width 6 7/8"
Height 4 7/8"
Weighs 24 lbs
Odyssey design:
Rugged Drycell sealed design
Military grade
Vibration resistant
60% more starting power
Deep discharge reserve power
2 year storage life
8-12 year design life
Can be mounted in any orientation
Exide orbital
BCI Group Size 34
Part Number ORB34DC-36
CCA 750 at 0° F
CA 925 at 32° F
Reserve Capacity minutes @ 25 Amps. 100 min
Dimensions (in.) Pallet
Load Qty
27½ in.
Length 10 1/8
Width 7
Height 8
weight 41lbs
odyssey PC 1500 T
CA: 1,500 at 80°F
CCA: 880A at 0°F
CA: 1,050 at 32°F
Reserve capacity: 135 minutes
Short circuit current: 3,100A
Design life: 12 years
Typical service life: 6 to 8 years
Operation temperature range: -40°F to 176°F
length 10.85in
width 6.99in
height 7.82
weight 58lbs
Make sure and get the 925L as it puts the positive and negative terminals on the same sides as polaris has it stock. I'll be ordering mine once I recover from buying the gps, power cable for it, amp, speakers, ipod, otterbox, ram mount for the ipod, and the amp cables!
did replaceing the battery (using the odessey 925) fix the problem of the low battery indicator flashing when running at night with headlights and stereo on?
Not for me. It helped hugely but just once my warning light did return. Riding at night with both stock & a pr. of 55W running lights on. Going somewhat slow but in HIGH gear. If I had been in Low, or going faster, I'm sure it wouldn't have happened.
RPM battery box is well made. Holds battery tight. Using full size Optima blue top 34mdc-8016. Plenty of connection options. High reserve capacity for lights, winch, ect.k:
read somewhere that someone used another type of battery that compares to the 925, the etx30L, it is almost half the price of 925
maybe a battery guru can comment?
I copied this from a Mazda racing forum
"I thought I would share some experience with you all. As most of you know I rep a line of batteries from the EAST PENN company and have touted how great our AGM batteries are. Well.....I recently had a jobber that was stocking the Odyssey battery line "because they are so powerful". I argued with him that our were just as good and even did a little test to prove it. I carry with me a OTC 3167 battery tester that shows CCA's at the end of a battery test and tested both our ETX30L and his PC925. The results were 558 CCA's for our ETX30L and 502 CCA's for his "bad ass PC925". He was humbled......I was estaticnd qouted this"
I have that battery. Same type and rating as the Odyssey but costs about $80 and is made in USA. I'm very happy with it and used the money I saved to buy a set of HID lights. With the money I saved by buying a Ranger battery box instead of the RPM box I bought a nice Grant steering wheel.
before you go replacing all these batteries you might want to check the output of your alternator i have heard some cases of the alternator putting out way below what it is rated at. I also know they make a higher output alternator for the RZR that might be cheaper then replacing the battery when you have a perfectly good RZR stock battery just something to think about
Hello, Ive been watching this forum for a while now and have made only madeone post in the past. That know one resonded to. I purchased an Oyssey 925L battery today. The cost was $158.45 including shipping from tnrbatteries.com. I have a RZRS on order and will add a whinch, lights, and stereo after I receive it. I've learned much information from this forum. Thank you for all the info. Hopfully this helps.
The ETX30L SEALED AGM BATTERY:
EXTREME MAGNA POWER POWERSPORTS BATTERY WITH AGM (ABSORBED GLASS MAT) CONSTRUCTION. READY TO INSTALL. WON'T SPILL OR LEAK. IDEAL FOR ANGLED INSTALLATIONS. ADVANCED VIBRATION RESISTANT DESIGN. NON-SPILLABLE BATTERY. FACTORY ACTIVATED. SIZE - 6-1/2" WIDE X 7" TALL X 5" DEEP. MADE IN USA WITH 365 CCA OF POWER.
The Odyssey - Battery PC925, with Terminals & without metal jacket, 925 cranking amps, 53 minute reserve capacity with 25amp load, (7.05'W x 6.64'L x 5.04'H), 26lbs
The Polaris (YUASA) YTX20HL-BS:
12 volt, 18 Ah SLA Battery for motorcycles, snowmobiles, and jet skis.
Dimensions:Length:6.88", Width:3.44", Height (including terminals):5.96", B1 terminals, 230CCA, Weight 15 lbs
The Odyssey has more CCA's but the ETX still has more than the Polaris.
The Odyssey 925 has 380 CCA's which is a little stronger than the
Exreme. The advantage that the 925 has is it's deep cycle ability, which
the Extreme does not have as it is a starting battery. The Odyssey 925
is both a starting and a deep cycle combined, that's one of the reasons
it's so freaking expensive, but it's also an exceptionally high quality
product. True, it only has about half the reserve time of an Optima,
but it's also only about half the weight. I cant imagine adding almost fifty
pounds of unsprung weight under my seat, no thanks, but then again I
don't have all of the gadgets that some guys have added on that need
power.
Related Threads
3.1M posts
141.5K members
Since 2007
