This is a discussion on odyssey battery on razor? within the Lighting, Stereo and Electrical forums, part of the Technical category; I did it in a gen 2, i don't think that changed between the gen's. Post a pic of your battery tray and i'll tell ...
#16
Re: odyssey battery on razor?
I did it in a gen 2, i don't think that changed between the gen's. Post a pic of your battery tray and i'll tell you for sure. It has WAY more reserve then stock. It has more cranking power then your diesel truck battery so when it is running low, it'll still get ya going.
| Sponsored Links | ||
#17
ok here are specs for the orbital, odyssey and Optima batteries you all are using. some manufacturers listed more info than others. keep in mind the odyssey 925 is half the size of both the optima and orbital batteries and half the weight. I am also including an odyssey model at the bottom that is the same size as the optima and orbital just to put things into propper perspective..I am probably biased as I use odysseys in everything and have had 100% perfect luck with every one I have purchased. I dont know how many of you want to haul around a full sized car battery under your seat in a utv ( LOL) but thats what both the optima and orbital are.
optima yellow top MODEL NUMBER D34/78 R Cold Cranking Amps @ 0F 750 Cranking Amps @ 32F 870 Reserve Capacity 120min PHYSICAL SPECS Length 10" 9 5/16" Width 6 7/8" Height 7 13/16" Minimum Weight (lbs) 43.5 Odyssey PC 925 Specs: 925 cranking amps for 5 seconds 870 cranking amps for 10 seconds 765 cranking amps for 20 seconds Short circuit current over 2400A 28 amp hours 50 minute reserve capacity with 25amp load Female brass terminal w/M6 SS bolt Length 6 15/32" Width 6 7/8" Height 4 7/8" Weighs 24 lbs Odyssey design: Rugged Drycell sealed design Military grade Vibration resistant 60% more starting power Deep discharge reserve power 2 year storage life 8-12 year design life Can be mounted in any orientation Exide orbital BCI Group Size 34 Part Number ORB34DC-36 CCA 750 at 0° F CA 925 at 32° F Reserve Capacity minutes @ 25 Amps. 100 min Dimensions (in.) Pallet Load Qty 27½ in. Length 10 1/8 Width 7 Height 8 weight 41lbs odyssey PC 1500 T CA: 1,500 at 80°F CCA: 880A at 0°F CA: 1,050 at 32°F Reserve capacity: 135 minutes Short circuit current: 3,100A Design life: 12 years Typical service life: 6 to 8 years Operation temperature range: -40°F to 176°F length 10.85in width 6.99in height 7.82 weight 58lbs |
#18
I just called Battries Battries, AKA Battries Plus, the Odyssey 925 runs about $180.00. Just FYI. I will be replacing mine in the next few weeks.
2008 Red Rzr, Elka Shocks,BS Sand Extreme Seats, Crow Belts, Custom Overhead Console with Icom F221s radio, Avcomm intercom, Avcomm HO500 headsets, Lowrance XOG GPS,XM Radio, 4 HID lights, Two Brothers Exhaust. |
#19
Make sure and get the 925L as it puts the positive and negative terminals on the same sides as polaris has it stock. I'll be ordering mine once I recover from buying the gps, power cable for it, amp, speakers, ipod, otterbox, ram mount for the ipod, and the amp cables!
Jeffro 08' Green Polaris Rzr (Gen 3) 26" ITP Mudlite XTR's on 12" Vision Bruiser Wheels Deluxe Front & Rear Brushguards 3500lb Polaris Winch |
#21
firerzr did you get an answer to... does the odessy 925 fix the problem of low battery indicator with headlights and stereo on?
If you don't own where you ride, but the government does, are you aware that it could be a "Wilderness Area" next year. Join the BlueRibbon Coalition or think about where, in your yard, your RZR lawn ornament might look best next summer! |
#22
Not for me. It helped hugely but just once my warning light did return. Riding at night with both stock & a pr. of 55W running lights on. Going somewhat slow but in HIGH gear. If I had been in Low, or going faster, I'm sure it wouldn't have happened.
_______________________________ Romeo, MI |
#23
RPM battery box is well made. Holds battery tight. Using full size Optima blue top 34mdc-8016. Plenty of connection options. High reserve capacity for lights, winch, ect.
#24
read somewhere that someone used another type of battery that compares to the 925, the etx30L, it is almost half the price of 925
maybe a battery guru can comment? I copied this from a Mazda racing forum "I thought I would share some experience with you all. As most of you know I rep a line of batteries from the EAST PENN company and have touted how great our AGM batteries are. Well.....I recently had a jobber that was stocking the Odyssey battery line "because they are so powerful". I argued with him that our were just as good and even did a little test to prove it. I carry with me a OTC 3167 battery tester that shows CCA's at the end of a battery test and tested both our ETX30L and his PC925. The results were 558 CCA's for our ETX30L and 502 CCA's for his "bad ass PC925". He was humbled......I was estaticnd qouted this" |
#26
before you go replacing all these batteries you might want to check the output of your alternator i have heard some cases of the alternator putting out way below what it is rated at. I also know they make a higher output alternator for the RZR that might be cheaper then replacing the battery when you have a perfectly good RZR stock battery just something to think about
#27
Anyone know about the high output alternator, or the box relocation in the 09 as an alternative to battery replacement for low charge indication.
#28
Hello, Ive been watching this forum for a while now and have made only madeone post in the past. That know one resonded to. I purchased an Oyssey 925L battery today. The cost was $158.45 including shipping from tnrbatteries.com. I have a RZRS on order and will add a whinch, lights, and stereo after I receive it. I've learned much information from this forum. Thank you for all the info. Hopfully this helps.
#29
_______________________________ Romeo, MI Last edited by guy48065; August 20th, 2008 at 07:43 PM. |
#30
The ETX30L SEALED AGM BATTERY:
EXTREME MAGNA POWER POWERSPORTS BATTERY WITH AGM (ABSORBED GLASS MAT) CONSTRUCTION. READY TO INSTALL. WON'T SPILL OR LEAK. IDEAL FOR ANGLED INSTALLATIONS. ADVANCED VIBRATION RESISTANT DESIGN. NON-SPILLABLE BATTERY. FACTORY ACTIVATED. SIZE - 6-1/2" WIDE X 7" TALL X 5" DEEP. MADE IN USA WITH 365 CCA OF POWER. The Odyssey - Battery PC925, with Terminals & without metal jacket, 925 cranking amps, 53 minute reserve capacity with 25amp load, (7.05'W x 6.64'L x 5.04'H), 26lbs The Polaris (YUASA) YTX20HL-BS: 12 volt, 18 Ah SLA Battery for motorcycles, snowmobiles, and jet skis. Dimensions:Length:6.88", Width:3.44", Height (including terminals):5.96", B1 terminals, 230CCA, Weight 15 lbs The Odyssey has more CCA's but the ETX still has more than the Polaris.
Thanks, Will 2008 With Odyssey 925 Battery, SuperATV Storage Bags, Maier Scooped Hood and Racer Tech 2" RZR Lift Kit and a 2009 RZR 170My 1953 Dodge M37 My Dodge Power Wagons |
| Visitors found this page by searching for these keywords: |
odyssey battery vs opitma battery winch,battery for polaris rzr,polaris rzr battery,BATTERY REPLACEMENT FOR POLARIS RZR,marine odyssey battery review,odessy battery,oddysey battery,discount battery for polaris rzr,polaris razor 800 battery location,looking for a polaris razor stero,polaris rzr superstart battery,optima batteries polaris razor 800,polaris rzr with 2 batteries,polaris razor battery,Polaris Batteries RZR,Interstate YIX30L battery,odyssey pc 925 polaris rzr,razor battery box dimensions,polaris rzr oddysee,location of battery on my polaris razor |
| Thread Tools | |
| Display Modes | |
| Aluminum Odyssey 925 battery box for gen1 | twvette | General RZR Discussion | 10 | January 8th, 2010 12:11 PM |
| Odyssey 925 and Alternator enough? | RockRazr | Lighting, Stereo and Electrical | 9 | January 1st, 2009 07:25 PM |
| Odyssey 925 and Alternator enough | RockRazr | Lighting, Stereo and Electrical | 0 | December 31st, 2008 07:13 AM |
| Odyssey PC925L Battery Charger? | BigSilly450X | General RZR Discussion | 9 | December 26th, 2008 03:20 PM |
| Odyssey or Yellow top? | BigSilly450X | General RZR Discussion | 38 | December 5th, 2008 05:12 PM |
