Stock Battery Replacement questions... - Polaris RZR Forum - RZR Forums.net
post #1 of 20 Old April 12th, 2010, 09:11 AM Thread Starter
Look'n 4 da deep stuff!
Cordachine's Avatar
First Name: Don
My RZR: 08 Red Submarine
Member #2636
View Cordachine's Photo Gallery(0)
Well, i went out to the barn yesterday to discover that the battery on the RZR is dead...really dead...Since I have to put a new one in, it might as well be a good one...but which one? I have seen some posts about Odyssey and Optima battery's, but I know nothing about what spec battery I need. My biggest draw is my winch and other than that, in the future I would like to run HID headlights and some LED's as well as a stereo.
What do you guys recommend for brand of battery?
Anything specific I should be looking for as a spec on the battery to power my winch and future accessories?
Thanks for the help!
08 Popo RZR
RZR: 30" Mudzillas on 14" SS108 4K Promark Winch K&N Apollo 3" Xtreme Lift HL springs Custom snorkel Deluxe front/rear bumpers Rock slider nerf bar Sport roof FMF pipe 1 1/2" Wheel spacers 4 pt harness RZRFORUMS.NET flag Dynatek CDI & Controller Odyssey battery DDP clutch Fusion IP500 Polk Audio MM651UM, 55w 6k VVME HID
Cordachine is offline
post #2 of 20 Old April 12th, 2010, 09:14 AM
jklein322's Avatar
First Name: Jim
My RZR: 2016 XPTurbo
Member #2348
View jklein322's Photo Gallery(19)
Re: Stock Battery Replacement questions...
Odyssey 925, slips right in place of the stock one.
Jim
Phoenix Arizona
2014 XP1K
WWW.UTVINC.COM
timaz@cableone.net or TAGTEAM 928-273-4249
jklein322 is offline
post #3 of 20 Old April 12th, 2010, 11:24 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
X2....Get an Odyysey PC925L, it will easily run the accesories that you mentioned. I have one, as do most guys I ride with. No issues for any of us! Due to the Odyysey being heavier, if you do any jumping,you will need some added support or you will crack the plastic battery box. I added an 1/8" aluminum piece under mine to support it. I have a thread I started on it. I am at work on my phone so I cant help ya find it....do an advanced search for my post using the word Odyysey.
MotoXXX is offline
post #4 of 20 Old April 12th, 2010, 12:42 PM
Gerry Roach's Avatar
My RZR: 2015 900 Trail
Member #4773
View Gerry Roach's Photo Gallery(0)
so do I understand the Odyssey 925 is the same dimentions of the OEM battery with the same hookups only it's heavier? Any idea how much heavier? What I was wondering about was would a aftermarket battery holder be needed?
Gerry Roach is offline
post #5 of 20 Old April 12th, 2010, 01:09 PM
aka: Bad Influence
loboboy's Avatar
First Name: BAD INFLUENCE
My RZR: 2012 RZR900XP
Member #12630
View loboboy's Photo Gallery(3)
it is the same size if you set it on its edge which you can do with an odessey. It is an AGM (absorbed glass matt) battery that can be postitioned in anyway.
loboboy is offline
post #6 of 20 Old April 12th, 2010, 01:30 PM
jklein322's Avatar
First Name: Jim
Member #2348
I use the stock battery box for the past 2 years. Do some jumping, lots of duning. No issues at all!
Jim
Phoenix Arizona
2014 XP1K
WWW.UTVINC.COM
post #7 of 20 Old April 12th, 2010, 01:53 PM
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
This is the holder I purchased. Actually less than I paid. It's nice because it's bent with tab's to specifically hold this battery.
Odyssey Batteries Aluminum side mount hold down for the PC925 series P/N- HD925SM - Can be used on all PC925 models: PC925, PC925 T, PC925 MJT, PC925 MJ, PC925 L, PC925 LMJ
bagman is offline
post #8 of 20 Old April 12th, 2010, 01:56 PM
MotoXXX's Avatar
First Name: Jeff
Member #4542
It is a little taller than the stock battery after you install it on its side. All you need is a small spacer or a few washers under the hold down bar and it works fine.
As for the plastic box breaking, both Johnnycat8 & Giff-Turbo RZR have had theirs break. I put my support piece in during my battery install. I learned about the problem from their misfortune
MotoXXX is offline
post #9 of 20 Old April 12th, 2010, 02:26 PM
Old West Reenactor
Gunfighterdusty's Avatar
First Name: Dusty (Another Mike who uses his middle name cause there's enough Mikes here now)
My RZR: Red 08 & Green 08
Member #2916
View Gunfighterdusty's Photo Gallery(29) Send a message via AIM to Gunfighterdusty Send a message via Skype™ to Gunfighterdusty
I went with yellow top optima cause I run a stereo, winch, pwr strng, gps & so on.
08 RZR DFR Air Box, Fuel Control, Throtle body, Stage 2 clutch, Header & exhaust, HID head lights, Elka Shocks, 2in lift, 2" spacers, soft top, glove box, half windshield, winch, Power steering, Polaris 14in wheels Goodyear MTR, ITP SS wheels w/smothies & paddles, air conditioning, some tunes and a smile & 08 stock green RZR:greenrzr:, half windshield, hard top, headache net, HID head lights, UMP air fltr & adding goodies to it as time goes on. I think that's it. Forced to Retire Finish Blade & more... Local 12, I.U.O.E. Ventura.
Gunfighterdusty is offline
post #10 of 20 Old April 12th, 2010, 04:10 PM
E.man's Avatar
First Name: Charlie
My RZR: Green 08
Member #740
View E.man's Photo Gallery(0)
I have the Odyssey 925 also, couldnt be happier. You don't have to have the L model by the way, I don't, and the cables reach just fine. It is a little taller than the stock battery, but it fits.
E.man is offline
post #11 of 20 Old April 12th, 2010, 04:27 PM
guy48065's Avatar
Member #309
Feedback Score: 16 reviews
Don if you have a "Gen1" rzr these won't fit your steel battery box. You can get an aftermarket metal box as mentioned above, or a molded Ranger box (cheap, drops right in).
The Gen1 box will only accept the stock-size battery. Too bad really--it's very well made.
guy48065 is offline
post #12 of 20 Old April 12th, 2010, 08:34 PM
aka: Bad Influence
loboboy's Avatar
Member #12630
[/quote]
It is a little taller than the stock battery after you install it on its side. [/QUOTE]
not on a rzr 4. it is same size. I dropped mine in and used the stock rubber strap and hooked up the cables. works like a champ with 4 40W HIDs plus the HID stock conversion I never saw the battery indicator come on. next i will be adding the tribal 30" led bar as well.
loboboy is offline
post #13 of 20 Old April 13th, 2010, 04:33 AM Thread Starter
Cordachine's Avatar
First Name: Don
Member #2636
Right on! Good info all. I seem to understand here that the Odyssey is the way to go.
Thanks Mark for pointing out the battery box!
08 Popo RZR
post #14 of 20 Old April 13th, 2010, 06:50 AM
Family Rzr
410fortune's Avatar
First Name: Jamie
My RZR: 2009 RZR S
Member #8045
View 410fortune's Photo Gallery(0)
picked up a Odessey PC925 yesterday from Batteries Plus... they have a 10% off coupon on their website it retails in Denver for $185... cheapest I could find online was $165 with free shipping... with the 10% off coupon we were right at $185 after tax... so I could have saved maybe $20 and waited a week, instead we got ours in town.
I told the manager he should start stocking more of these... they will be selling
Thing is huge compared to stock, its the size of two stockers, lay it on its side and it fits our S perfectly...
1988 Bronco II, 5.0L Gt-40p, 4r70w, 35" MTZ, dual ARBs, long travel
2007 FJ cruiser, 3" OME, dual ARBs, 4.56, 33" MTR
2005 (2ea) 900 RMK, 159", modified
2009 Rzr S - way too stock
410fortune is offline
post #15 of 20 Old April 13th, 2010, 09:34 AM
guy48065's Avatar
Member #309
FYI the battery shown in my photo above is the same size, type (AGM) and rating as the Odyssey, is made in the USA, but costs 1/2.
Google "Magna ETX30L" and take your pick. Bought mine at Battery Giant but I've also seen them at some Meijers stores.
guy48065 is offline
Tags
battery
Replacement Frame questions sf-RZR RZR-S Specific Discussion 1 May 14th, 2010 10:55 AM
Replacement Frame Questions sf-RZR Roll Cages and Safety Equipment 3 September 13th, 2009 04:22 PM
Replacement Frame questions sf-RZR General RZR Discussion 0 September 7th, 2009 08:58 PM
Boot replacement questions GreenHornet RZR-S Specific Discussion 8 July 12th, 2009 05:59 PM
Best Replacement Battery? azrzrguy Engine and Drivetrain 13 March 15th, 2009 08:32 PM
