Fused Power for Extra Lights
Old May 22nd, 2008, 07:03 PM
scorpio scorpio is offline
I just installed a set of pro comp 55 lights for my RZR. I tried using a fuse tap with the accessory fuse and not only couldn't I insert the fuse with tap into the fuse holder but the fuse box cover won't close with the wires coming off the fuse.
I would appreciate any detailed information on how others got a fused power supply for their lights, etc.
Pictures are very much appreciated.
Thank you
Re: Fused Power for Extra Lights
Old May 22nd, 2008, 07:28 PM
jackbenimble's Avatar
jackbenimble jackbenimble is offline
My RZR: 2008 3rd Gen
I found this thread useful:
What wires
Old May 22nd, 2008, 08:44 PM
guy48065's Avatar
guy48065 guy48065 is offline
There is a spot in the lower left corner of the fuseblock that is battery HOT. I connected here so I can run my winch even with the key OFF. If you prefer to run your accessories with the key ON, there is an orange accessory connector near the lighter plug for that connection. It is fused at 15A. and probably shouldn't be exceeded or you'll burn up your ignition switch.
The cover still snaps in place even with this wire run. It might be possible to hide the wire inside the block but I didn't think it was worth the trouble to take it apart to find out.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
