new light bar and HID lights
Old May 18th, 2008, 06:04 PM
strracerx's Avatar
strracerx strracerx is offline
I just finish my light bar and installed new HID lights. i also replaced the stock healights with HIDs and replaced the tail lights with LEDs. I can't wait for the next night ride in glamis.
Re: new light bar and HID lights
Old May 18th, 2008, 06:46 PM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
Niiiice.
My RZR Project
Keep It Wet and Dirty!
Old May 18th, 2008, 07:34 PM
Johnny's Avatar
Johnny Johnny is online now
UTVCRAP*****
First Name: Johnny
My RZR: the red one
youll be the leader with all that light
www.utvcrap.com 623-934-3070
623.934.3070
Old May 22nd, 2008, 03:19 PM
PerryMason's Avatar
PerryMason PerryMason is offline
First Name: Steve
You can also use those for sticker removal.
Old May 31st, 2008, 12:51 PM
mccoy mccoy is offline
What led light bulbs did you use in the tail lights?
Old May 31st, 2008, 03:11 PM
strracerx's Avatar
i bought the LEDs from the local kragen and soder in a resistor so that the brake lights would work.
Old May 31st, 2008, 04:43 PM
RonJ RonJ is offline
What type of battery are you running?
Old May 31st, 2008, 05:54 PM
strracerx's Avatar
the battery is still stock
Old June 1st, 2008, 05:20 PM
My RZR: Green '08
Good luck. Keep your eye on the instrument panel in Glamis for that low battery indicator.
  #10 (permalink)
Old June 1st, 2008, 06:01 PM
Dusty's Avatar
Dusty Dusty is offline
Everything he is using should use less power when illuminated, correct?
Otsego, Mi
08 Mean Green
  #11 (permalink)
Old June 1st, 2008, 06:31 PM
strracerx's Avatar
used it plenty of times at night all ready, no battery failure. As long as the wattage used does not surpass what the stator can produce, you should be fine. Thats assuming you take into consideration, head lights, brake lights, fan, instrumental display, and the wattage need to keep a positive charge.
i changed the headlights to a lower wattage, change the tail lights to LEDs, and since i run the lights at night, the RZR runs cooler, fan doesn't come on as often. I checked the volts on the battery with all the lights on and the fan, I am still getting 13 volts. Thats charging the battery and runing a load at the same time.
  #12 (permalink)
Old June 1st, 2008, 09:13 PM
txmd500's Avatar
txmd500 txmd500 is offline
Looks great :-) Did you build the light bar, if so what to make another one? :-)
  #13 (permalink)
Old June 1st, 2008, 10:02 PM
Did you wire the light bar to the stock light switch as well? When you turn it on, all 5 lights turn on? Do you get light flicker until they're fully operational? I have 3 HID Fuego HID's on my light bar, and when all 3 are connected I get light flicker until the RPMS are higher.
  #14 (permalink)
Old June 1st, 2008, 11:24 PM
strracerx's Avatar
i have a seperate switch for the roof lights. I figure if i blow a fuse or relay, i would have my stock lights still. i do not get any flicker on the HIDs, headlights or roof lights.
A flicker is usually the ballasts not getting enough power to ignite the bulbs. Ballast take a littl more volts to charge up and iluminate the bulbs. If you didn't take precuations and start saving energy by changing to HIDs on the headlights and LED tail lights, your stator might not produce enough power to get a nice crisp hum when you turn the HIDs on.
I would double check ground first, and then maybe add individual switches to each light, that way you can turn them on one by one. That way, each ballast will chrage up separatly and you won't get a flicker.
  #15 (permalink)
Old October 23rd, 2008, 05:14 PM
supersonictoys supersonictoys is offline
I know this is an old post but ,just curious if you used a relay when hooking up the overhead lights?
