Tail light wiring schematic - Page 3 - Polaris RZR Forum - RZR Forums.net
post #31 of 80 Old March 20th, 2010, 08:47 PM
hooversxs's Avatar
First Name: Steve
My RZR: 2008 RZR
Member #4063
View hooversxs's Photo Gallery(38)
Re: Tail light wiring schematic
Originally Posted by HawkEng View Post
Go to O'Reilly's or AutoZone and get a standard auto relay. $5 or so. They also sell them at Radio Shack. Here is the wiring. The 4 wires going back to tail lights are:
brown - ground
blue - work light positive
orange and red/yellow for tail and brake.
The relay has numbers on the bottom side and here is how to wire it:
relay 85 and 30 tied together to red/yellow
relay 87
relay 87a to red
relay 86 to orange
This will make the tail lights come on with the key on and/or headlights. Then the brake pedal will activate the new brake lights
I hate to be a tard but you just "spliced" into these lines to run the relay. This keep the tail lights functioning as normal, right...?
RZR Tech +3 suspension
Makin' Trax MT2 Shocks W/ Progressive Springs
hooversxs is offline
post #32 of 80 Old March 21st, 2010, 05:29 AM Thread Starter
HawkEng's Avatar
First Name: Jason
My RZR: Turbo Apex RZR & Z1 RZR
Member #747
View HawkEng's Photo Gallery(0)
yes, works as designed plus the new tail lights. I solder all connections to keep water from causing a problem later.
I specialize in APEX and Z1 conversion kits for the 800. Z1 kits for the 900xp, XP1000, and 1k Turbo. We have a Z1 waterproof belt cover too.
573-579-8295. Check out our custom coach builds too. www.hawkengineering.com.
HawkEng is offline
post #33 of 80 Old March 21st, 2010, 06:39 AM
rich wit's Avatar
My RZR: 09 rzr camo edition
Member #14208
View rich wit's Photo Gallery(0)
thanks steve, i think i know what to do now. i read another thread, that the rzr tail lights work off the ground, not like a car where positive is sent to the tail and brake lights. i should be able to tap into the ground and install a switch to break it and that should kill the lights. thanks again , rich
rich wit is offline
post #34 of 80 Old March 21st, 2010, 12:29 PM
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
Feedback Score: 19 reviews
I want to add a LED tail/brake light assembly at the center of my Polaris hard top roof. Would the relay work for this application? It is a single ground wire and hot of each of the brake and tail lights.
quadnkev is offline
post #35 of 80 Old March 22nd, 2010, 04:00 AM Thread Starter
HawkEng's Avatar
First Name: Jason
Member #747
Look at post #20 I did. There is a wiring diagram I did that is correct. I had a wire wrong on the first post.
http://www.rzrforums.net/lighting-st...hematic-2.html
Yes, this is the way to another break/tail light to a rzr.
No, it is not a single ground and hot like you would think. You have to use a relay like the wiring diagram shows.
HawkEng is offline
post #36 of 80 Old March 22nd, 2010, 06:47 AM
fatbrothers's Avatar
First Name: Jeff
My RZR: 09 RZR
Member #11969
View fatbrothers's Photo Gallery(4)
Thanks Hawk.................Just the information I needed .
Ride safe .
Jeff
fatbrothers is offline
post #37 of 80 Old April 4th, 2010, 08:34 PM
Bobholthaus's Avatar
My RZR: '10 Standard
Member #14030
View Bobholthaus's Photo Gallery(0)
So if I wanted my brake lights to work all of the time but the taillights to only be on with the headlight switch, can you please explain to me what I need to do? I do understand standard auto wiring, but can someone please explain what it really taking place w/ the stock wiring (how it's really working with only one ground wire serving two lights?) thanks.
Bobholthaus is offline
post #38 of 80 Old April 25th, 2010, 07:45 PM
Member #14030
Bump - I understand the attachment in this thread, but I still would like to know how to use this same wiring but only have the taillights on with the headlight switch (as I'm going to wire in separate running lights on their own switch). I'll also use this schematic to wire the 7 round trailer hitch plug I plan on adding to the RZR. Thanks in advance.
2010 RZR, Polaris SIXr Black Rims with 26" Bighorns, Sport Top, Rearview Mirror, Front & Rear Brushguards (Line-X'd), 2" Receiver hitch, HID Headlights (DDM Tuning 55 watt), LED Backup Light, LED Dome Light, LED Bed Light, LED Running Lights, Warn 3.0 RT Winch, Custom Drink Holders, Polaris Glacier II Plow, SuperATV Cage Support bars; bob@holthaustech.com, 314-680-2624, St. Louis, MO
post #39 of 80 Old April 29th, 2010, 08:51 AM
Craig_c's Avatar
Member #11066
View Craig_c's Photo Gallery(0)
Polaris ran the wiring this way since the brakes run off a pressure switch that also functions as a starter override.
Now my questions are....Are the wire colors on a 09 and up the same colors?
Has anyone verified that this will work for just putting LED bulbs in the factory taillights?
Craig_c is offline
post #40 of 80 Old May 13th, 2010, 06:24 AM
Look'n 4 da deep stuff!
Cordachine's Avatar
First Name: Don
My RZR: 08 Red Submarine
Member #2636
View Cordachine's Photo Gallery(0)
Bump for last question. Is the wiring the same for LED tails?
08 Popo RZR
RZR: 30" Mudzillas on 14" SS108 4K Promark Winch K&N Apollo 3" Xtreme Lift HL springs Custom snorkel Deluxe front/rear bumpers Rock slider nerf bar Sport roof FMF pipe 1 1/2" Wheel spacers 4 pt harness RZRFORUMS.NET flag Dynatek CDI & Controller Odyssey battery DDP clutch Fusion IP500 Polk Audio MM651UM, 55w 6k VVME HID
Cordachine is offline
post #41 of 80 Old May 13th, 2010, 07:49 AM
Member #14030
I'm going to monkey with this in the coming week or so. I'd like to run LED tails so I was thinking of using the diagram above to actually rewire the factory tail/brake lights. I also want the taillights to only be on with the headlights, so I need to figure out how to do that as well. I'll let you know when I'm finished. Thanks.
post #42 of 80 Old July 4th, 2010, 12:35 PM
e-wa's Avatar
My RZR: )8'RZR w/2010 RZR S Motor Polaris LT kit w/AFCO Silver series shocks
Member #666
View e-wa's Photo Gallery(0)
I installed my Pete's racing rear light bar, amber/red/wht lights. I couldn't get the running lights to light without pushing the brake pedal. I just ran a seperate wire to the ambers and wired the relay like the diagrahm. Brake lights work fine, just no running lights going through the realy.
e-wa is offline
post #43 of 80 Old July 4th, 2010, 04:58 PM
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
I installed the relay for the brake lights and swapped the brown wire and red/yellow wires at the rear sockets
and stubbed out after the relay for my high level LED brake/tail light and it works good.
quadnkev is offline
post #44 of 80 Old July 6th, 2010, 07:05 AM
Member #14030
Please see the schematic that I put together. I haven't wired this yet, but I think it's all going to work. I may need to swap the wires inside the oem sockets as is mentioned on another post. I should be able to finalize all of this wiring in the next week or two and then I will post my final results. Thanks.
File Type: pdf 100706 - RZR Relay Wiring Schematic.pdf (26.7 KB, 567 views)
post #45 of 80 Old August 5th, 2010, 07:55 PM
GroundsKeeper Willie's Avatar
First Name: Shaun
My RZR: red 2010 standard
Member #16220
View GroundsKeeper Willie's Photo Gallery(10)
Works Awesome!! Thanks for info... i wired my trailer plug today and added LED I.D light at top of rear cage... My trailer is all LED lights so hardly no load at all...
this site rocks!
GroundsKeeper Willie is offline
help with light wiring TOE-B RZR-S Specific Discussion 2 November 11th, 2009 02:20 PM
tail light switch rzrs24 General RZR Discussion 1 November 3rd, 2009 08:12 AM
08 Wiring Schematic Stumpduster Lighting, Stereo and Electrical 3 May 7th, 2009 05:48 PM
LED tail light bulb strracerx Lighting, Stereo and Electrical 19 November 4th, 2008 08:03 PM
LED tail light relay wiring dune-addict Lighting, Stereo and Electrical 0 April 20th, 2008 12:56 AM
