LED tail light bulb
Old April 11th, 2008, 08:55 PM
strracerx's Avatar
strracerx strracerx is offline
LED tail light bulb
Has anyone used these yet? i jnstalled them and they light up, but not when the brakes are applied. any thoughts?
Re: LED tail light bulb
Old April 11th, 2008, 09:17 PM
TEXMudder TEXMudder is offline
Havent done mine yet, but if I remember correctly they are ground triggered which means you need a relay.
Old April 11th, 2008, 09:57 PM
martymoe's Avatar
martymoe martymoe is offline
Mad Scientist
First Name: Marty
some are using relays and some are using resistors. i did mine with a relay, and i really like em.
Old April 11th, 2008, 10:09 PM
andy071780's Avatar
andy071780 andy071780 is offline
First Name: Andy
My RZR: 2008 gen2
sounds like a HOW TO is in order.
"I THINK we can make it"
Old April 12th, 2008, 08:30 AM
guy48065's Avatar
guy48065 guy48065 is offline
Marty do you find the 50 lumens the LEDs put out (on HI) is adequate? The stock bulb is 400 lumens. When I installed them I was totally disappointed.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
Old April 12th, 2008, 04:06 PM
martymoe's Avatar
Mad Scientist
First Name: Marty
i'm not really sure.. mike sent me some mondo led bulbs i dont know how many lumens, but they look like regular bulbs until you hit the brake or turn them off and they have that instant led thing going.
there was an orage rzr with bulby melted taillights because of probably a ground fault. that's why i did them.
Old April 12th, 2008, 05:59 PM
strracerx's Avatar
can you explain on how you wire up with the realy? thanks.
Old April 12th, 2008, 06:20 PM
strracerx's Avatar
i found a topic using resistors, led tail lights
relay would seem better. also how bright will they be?
Old April 12th, 2008, 09:50 PM
guy48065's Avatar
Did he send you the same Autozone bulbs he wrote about or something different? I'd like to try something that works better but don't want to keep throwing money at it.
  #10 (permalink)
Old April 13th, 2008, 01:13 AM
martymoe's Avatar
Mad Scientist
First Name: Marty
one of the guys from prc wrote up a nice article on doing it with resistors, i put it in the troubleshooting wiki on extremerzr.com its under body:lighting:taillights:
he did a nice job of writing it up.
the leds mike sent are brighter than the ones from autozone, but i dont know where he got them. pm myers on prc and ask him
  #11 (permalink)
Old April 13th, 2008, 09:44 AM
guy48065's Avatar
PM sent. Thanks Marty--I didn't know we were talking about 2 different guys
  #12 (permalink)
Old April 20th, 2008, 09:12 PM
mac's Avatar
mac mac is offline
First Name: Marc
My RZR: 2008 RZR - GEN 3 - Red
I just ordered mine from the super bright led website, give them your credit card and voila.
Yeah thats a great post on How to !!! Thanks again to all for the help.
Need to save as many amps as possible......
I'll keep you posted on my success...... but sure it will be worth it !!
Mac
  #13 (permalink)
Old November 4th, 2008, 05:57 PM
rzrsrider rzrsrider is online now
hey everyone,
I tried this led mod using everything the same even the 3157 r led bulb but running lights work but i hit the brake lights and they stay the same. what else to try anyone have any idea.
  #14 (permalink)
Old November 4th, 2008, 07:10 PM
jeephreak's Avatar
jeephreak jeephreak is offline
First Name: 'phreak
My RZR: Gen 2
there is a write up -you have to cut the wire and solder in a resistor. I have the exact same LEDs and they work perfect with the modification.
You have to make sure you cut the right lead, and put the proper resistor on there. I'm an electrical moron and if I can do it ANYONE can!!!
Search the forum for LED's youll find the how to - also, try pulling the bulb out and twist it 180 degrees and insert it that way.
  #15 (permalink)
Old November 4th, 2008, 07:27 PM
i did it every step and when i hit the brake pedal no change in brightness. pin two the only differents is i usen a 390 instead of a 470 or some people used a 330. mine is a 2009 rzr-s does that make a difference? also could i have heated the resistor to much?
