Battery/Low Voltage/Volt Reg Question - Polaris RZR Forum - RZR Forums.net
This is a discussion on Battery/Low Voltage/Volt Reg Question within the Lighting, Stereo and Electrical forums, part of the Technical category; Hi all. I did do a bunch of research on this site before posting, so bear with me here...... 08 RZR, stock battery, under seat ...
Old November 11th, 2009, 08:04 PM   #1
Rzr spy
grant22's Avatar
First Name: Grant
My RZR: Currently Rzr Free
Member #1714
View grant22's Photo Gallery(0)
08 RZR, stock battery, under seat volt reg, factory radio (with no other aux electrical loads).
My battery icon flashes quite a bit (at least once a ride). My RZR is always on a battery tender, has no other lights or anything, and the icon flashing occurs regardless of outside temp. I get a full charge out of my battery when on the tender, and the icon stops flashing as soon as I turn the radio off and increase my speed a little.
I intend on repl my battery (when needed) with an odyssey and have already bought a bracket to relocate the VR. (the plug and play harness extension supplier is done making them, tho).
Any ideas on what's up and what I should look at next? THANKS!
grant22 is offline   Reply With Quote
Old November 11th, 2009, 08:19 PM   #2
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: Battery/Low Voltage/Volt Reg Question
The stator is not putting out enough charge to run the radio when at slow speeds, hence speeding up or turning off the radio cures problem. This could be due to faulty regulator, a poor connection (dirty),bad ground,over heating regulator or an aging battery. I would check and clean all connectors from harness to voltage reg and check battery connections and ground. Also if you have a multimeter check how much load the radio is pulling
XP1000 Titanium Black
RZR 800 put out to pasture
1 Limey in a world of Yanks
rjsmith is offline   Reply With Quote
Old November 11th, 2009, 08:26 PM   #3
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Thanks RJ......I'll check all that tomorrow.
Do you think a higher amp-hour batt like the odyssey would solve the low output problem? Also, it sounds like, on this site, the VR relocation doesn't help much.....would you agree?
Old November 11th, 2009, 08:30 PM   #4
King of crash!
Member #787
their was no factory radio polaris makes a add on but not a stock one....i wonder if they ran the power off the stock fuse block or ass terminall...... id re run the power to the battery and see if that fixes it... to much draw off the factory fuse box takes power from the ecm and fuel pump and can cause the light to flash
Old November 11th, 2009, 08:45 PM   #5
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Great idea......I'll check into that, too.
(btw, by factory radio, I mean Polaris Advertises it as "pure Polaris," they sell it, and install it without voiding the warranty.)
THANKS RJ & JohnnyCat!
Old November 11th, 2009, 08:49 PM   #6
rjsmith's Avatar
First Name: Ralph
Member #4388
I disagree, i think the VR relocation helps quite a bit, problem is that damage can be done to VRs if they are constantly overheated and people might be relocating a damaged VR.
A new battery will only help the system if the old battery is defective and drawing too much due to an internal short. Having said that a higher capacity battery will allow you to run more load for longer before an over taxed stator situation arises.
Old November 11th, 2009, 08:59 PM   #7
King of crash!
Member #787
x2 on moving the vr.... mine has over heated and shut down a few times im going to move it just not sure were yet i have a few places im thinking of...
Old November 11th, 2009, 09:22 PM   #8
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Sooooooooooo, I know where to get a VR and the bracket is already in my mits.....
Where can I get a plug and play harness? Autotrend no longer makes that harness due to decreased demand.
I don't want to cut, solder/splice if not necessary.
Old November 11th, 2009, 09:24 PM   #9
King of crash!
Member #787
dont they still sell the conectors? wire is easy to get
Old November 11th, 2009, 09:33 PM   #10
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Yes, but I'd have to buy a special crimper that would only get used for this one project (unless you all think my normal/standard crimper can get the job done). Lemme know if that special packard crimper aint so special.......
Thx All...
Old November 11th, 2009, 09:37 PM   #11
King of crash!
Member #787
cant answer that one unless i saw it... just solder the wires to their terminals??? their has to be a way...
Old November 11th, 2009, 09:56 PM   #12
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
That's a good idear! Solder it will be!
Old November 11th, 2009, 11:00 PM   #13
De Oppresso Liber
LouDiamond's Avatar
First Name: Scott
My RZR: 09 RZR
Member #3259
Have you checked with UTVCrap yet? I think they might have what you are looking for.
LouDiamond is offline   Reply With Quote
Old November 12th, 2009, 09:18 AM   #14
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
I'll check that, Lou. Thx.
Any luck with your WER's yet?
Old November 12th, 2009, 09:26 AM   #15
De Oppresso Liber
LouDiamond's Avatar
First Name: Scott
My RZR: 09 RZR
Member #3259
I've got a few people looking at them at the moment. Hopefully I'll have them sold in a day or two.
I was digging around UTVCraps website/forum and I couldn't find the harness so I may be wrong on that one so give them a call and ask. I could have sworn I saw another vendor offering a VR relocation harness just recently. Have you actually called auto trend to see if they have any on the shelf or perhaps they you might convince them to build you one?
batery low voltage polasris
checking razor quad low voltage to motor
high voltage
low volts on rzr battery
polaris battery low
polaris battery voltage
polaris razor battery symbol
polaris razor low voltage
polaris razor voltage output and draw
polaris rzr high voltage from reg
polaris rzr low voltage at battery
rzr low voltage
rzr low voltage icon
rzr makes no voltage to battery?
rzr with low voltage
Battery Tender Question digitalhearing Lighting, Stereo and Electrical 20 May 26th, 2014 11:42 PM
what is the 9 volt battery plug for? Rudamus Mudba Forum Help, Questions and Info 12 November 11th, 2009 07:48 AM
Battery over heated question on fix AntRambo1981 General RZR Discussion 8 April 15th, 2009 03:49 PM
Alternator, Battery Question kx45fox Lighting, Stereo and Electrical 28 January 7th, 2009 07:19 AM
9 Volt Battery Connection knockerm Lighting, Stereo and Electrical 1 March 27th, 2008 04:35 PM
