Red Top, Blue Top, And Yellow Top Optimas - Polaris RZR Forum - RZR Forums.net
This is a discussion on Red Top, Blue Top, And Yellow Top Optimas within the Lighting, Stereo and Electrical forums, part of the Technical category; I have read a ton of misinformation on the differences in optima batteries and was confused myself so here yall go, straight from optima: What ...
Old October 23rd, 2009, 12:22 PM   #1
hbchad's Avatar
First Name: Hudson
My RZR: 08 800
Member #9966
View hbchad's Photo Gallery(6)
What is the difference between RedTop, YellowTop and BlueTop batteries?
RedTop: Use this for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed. This would describe most stock vehicles.
* Automotive and RV under-hood starting
* Heavy equipment where starting is the primary function
* Diesel powered vehicles with no aftermarket electronics
YellowTop: Use this when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles without alternators. This also includes vehicles with significant electrical loads that may exceed the average alternator output (for example aftermarket audio system, GPS, chargers, winch, snowplow, inverters, drag cars). This can also include vehicles that have a lot of electronics from the factory, such as a minivan with power sliding doors and a DVD player, especially if the DVD player is used when the engine isn’t running.
* Racing vehicles without a charging system (alternator or generator)
* Dedicated drag racing vehicles
* Diesel powered vehicles with aftermarket electronics
* Car audio/video applications exceeding 250 watts over the OE system
* Vehicles or heavy equipment with inverters, hydraulics, winches or other accessories
* Electric vehicles
BlueTop: The BlueTop starting battery (dark gray case) is to be used when a dedicated starting battery is required and it should never be used for cycling duty. The dual purpose BlueTop (light gray case) can be used for both starting and deep cycling; it is a true deep cycle battery with extremely high cranking power.
* Trolling motors, marine applications with heavy electrical accessories and RVs should use a dual purpose BlueTop (which is both a starting and deep cycle battery)
* Use a BlueTop starting battery for marine applications and RVs when the battery’s only function is engine starting
Note: The difference between BlueTop and YellowTop deep cycle batteries is that BlueTop batteries have both automotive (SAE) posts and threaded posts, while YellowTops (other than D31T) only have SAE posts.
If you ever get confused on the color tops just remember: if it has a dark gray case then it is a starting battery; if it has a light gray case then it is a deep cycle (dual purpose) battery.
Optima Battery FAQ - Frequently Asked Questions
Hope this helps to clear everyone up!
2012 rzr-s
31" Outlaws
2012 ranger crew
6" Outkast Lift
Sitting on blocks! Need some tires!
WTB: 34" Terminators
hbchad is offline   Reply With Quote
Old October 23rd, 2009, 01:01 PM   #2
mnrzr-s's Avatar
First Name: Jon
My RZR: 2009 LE Nuclear Sunset
Member #7165
View mnrzr-s's Photo Gallery(1)
Re: Red Top, Blue Top, And Yellow Top Optimas
Very good info. Thanks
mnrzr-s is offline   Reply With Quote
Old October 23rd, 2009, 01:45 PM   #3
quickster47's Avatar
First Name: Carl
My RZR: 2010 RZR-S Orange
Member #9318
View quickster47's Photo Gallery(0)
That is great information and much appreciated.
Carl
quickster47 is offline   Reply With Quote
Old October 23rd, 2009, 08:44 PM   #4
im4seven's Avatar
First Name: Jim
My RZR: 2009 Nuclear Sunset
Member #3702
View im4seven's Photo Gallery(0)
Ok, so red top with dark case for stock w/ winch, and red w/ light gray if you have killer lights and electronics?
im4seven is offline   Reply With Quote
Old October 25th, 2009, 10:38 AM   #5
hbchad's Avatar
First Name: Hudson
My RZR: 08 800
Member #9966
There's no red top/light grey. You go to yellow top/light grey. You don't need the extra cranking amps that the red top provides, so rarely will it be a benefit on a rzr. Typically you would want the ability to deep cycle without damage...
Basically, for most RZR applications, the yellow top or the blue top w/light grey case is the way to go...
2012 rzr-s
31" Outlaws
2012 ranger crew
6" Outkast Lift
Old October 25th, 2009, 11:08 AM   #6
RZRider's Avatar
First Name: Al
My RZR: 16 Platinum XP1000
Member #482
View RZRider's Photo Gallery(0)
Good Info, Thanks!!
Keep It Wet and Dirty!
http://www.polaris.com/en-us/rider-s...n-road-recalls
RZRider is offline   Reply With Quote
Old November 2nd, 2009, 01:42 PM   #7
ygder77's Avatar
Member #9561
View ygder77's Photo Gallery(0)
Great info , thanxxxx
ygder77 is offline   Reply With Quote
blue top vs yellow top
difference between optima blue top and red top
difference between red top and blue top optima batteries
difference between red top yellow top blue top
do rvs use blue or yellow optimas
optima yellow top vs redtop vs blue top
polaris ranger crew blue top optima
rzr red or yellow optima
the difference between yellow and red top optima batteries
what is the differance between red and yellow top optima batter
what is the difference between a red top and yellow top optima battery
what is the difference between optima yellow and blue
whats the difference between light and dark grey blue top optima
where do you find a blue and yellow top
yellow top vs red vs blue top optima
The yellow cab RZR S pixel RZRForums Members' Rides 6 September 30th, 2009 01:04 AM
Blue Xenon bulbs razrpilot Lighting, Stereo and Electrical 1 July 22nd, 2009 05:23 AM
RPM battery box with Optima Yellow 4sale ... twvette Polaris RZR Parts For Sale 0 February 1st, 2009 10:04 AM
Royal Blue 12-28 phatpounder02 RZR and UTV Video's 1 December 30th, 2008 10:11 AM
Odyssey or Yellow top? BigSilly450X General RZR Discussion 38 December 5th, 2008 06:12 PM
