water temperature? |
March 30th, 2008, 11:19 PM
water temperature?
i am going to buy a water temp gauge and need to know what the operating temperature of the rzz is. also what is the max psi should oil pressure be at? thanks.
Re: water temperature? |
April 1st, 2008, 11:00 PM
kinda need help here, no one has a temp gauge? or oil pressure gauge?
April 1st, 2008, 11:16 PM
180 is what is in the manual
April 2nd, 2008, 12:18 AM
First Name: JASON
Mine runs between 190 and 210 with temp sending unit in front by radiator
