Has anyone done a hih low beam headlight conversion?
This is a discussion on Has anyone done a hih low beam headlight conversion? within the Lighting, Stereo and Electrical forums, part of the Technical category; I have seen that the 2007 polaris rangers have high and low beams from the factory. Has anyone tried to use the polaris parts off ...
Old August 27th, 2009, 01:04 PM
Xcntry's Avatar
My RZR: 2008 Polaris RZR 50"
Member #7446
View Xcntry's Photo Gallery(0)
I have seen that the 2007 polaris rangers have high and low beams from the factory. Has anyone tried to use the polaris parts off the ranger to convert there rzr lights so they have high and low beams in the same light. I,d like to use all the oem conectors, bulbs and switch from the ranger. I am just wondering if anyone had tried this yet. I can't find a thread about it.
2008 RZR, Hard Top Sport Roof ,26" Big horn tires on 14"aluminum painted black rims,sony 6 disc cd player with satellite radio, rock slider nerf bars , windshield and rear window,crow 4 point harnesses, Roktek 3" lift kit.
Old August 27th, 2009, 01:38 PM
BlueSTI's Avatar
"The Belt Killer"
First Name: Matt
My RZR: Red 2008
Member #1401
View BlueSTI's Photo Gallery(20)
Re: Has anyone done a hih low beam headlight conversion?
There's some HID bulbs you can buy... I forget what size, but it has a mechanical motor set-up, that rotates a reflector around 180 degrees, to provide a higher beam out put... it would probably be easier to modify that bulb to fit in RZR, than the whole different set-up... I think it's the same size in a F-150.
-I may not be the fastest... but I'll be damned if I'm the slowest!
-I make up for power, by adding stickers and flashing lights.
Old August 27th, 2009, 02:02 PM
ohmartm's Avatar
Sand Blaster!!
Feedback Score: 5 reviews
First Name: Merle
My RZR: 11' XP
Member #1732
View ohmartm's Photo Gallery(17)
humm interesting!!! If you do it post pics!!
Old August 27th, 2009, 02:06 PM
410fortune's Avatar
Family Rzr
First Name: Jamie
My RZR: 2009 RZR S
Member #8045
View 410fortune's Photo Gallery(0)
the zenon HID hi/low projector uses a mechanical lens to block off the upper half of the projector circle for a low beam, then when you choose hi beams hte lens is opened fully. I have these projectors on my wifes FJ cruiser, they are VERY bright
the Polaris 700 setup is likely just a dual filament halogen bulb like a typical halogen caar sealed beam), not a lens controlled projector?
1988 Bronco II, 5.0L Gt-40p, 4r70w, 35" MTZ, dual ARBs, long travel
2007 FJ cruiser, 3" OME, dual ARBs, 4.56, 33" MTR
2005 (2ea) 900 RMK, 159", modified
2009 Rzr S - way too stock
Old August 27th, 2009, 04:38 PM
SXS Customs's Avatar
Member #8371
View SXS Customs's Photo Gallery(0)
No Hi/Low HID kits yet for the RZR.Ranger... we are working with our supplier to see if we can develop one to kit in the stock headlight assembly.
BTW thanks to all of that have ordered the HID Special that I have going on... Almost all sold out.
Old August 27th, 2009, 05:01 PM
2MANYTOYZ's Avatar
MX Kid
First Name: Curtis
My RZR: 09 RZR S
Member #5252
View 2MANYTOYZ's Photo Gallery(15)
I have heard NIght owl HID is suppoesed to come out with a HI/LO
LO stanard halogen
HI 35w HID
that would be the kit to get
MIXIN OIL & SMELLIN ROYAL
2008 low beam wire for fjcruiser
2009 polaris high and low beam hid kit
cbrxx projector lights
does polaris ranger have high low beams
hi beam for polaris xp
polaris high bean conversion
polaris ranger hi low beam
polaris ranger hi/low lights
polaris ranger high and low beam in italy
polaris ranger high beam lights
polaris rzr headlight hi /low beam conversion
projector light for polaris razor
rzr 570 high beam low beams
rzr hid kit hi lo projectors
rzr projector headlights
Lighting Information - Light Source and Beam Pattern Description Baja Designs Baja Designs 7 January 31st, 2011 10:24 AM
beadlock conversion? ocelotred05 Wheels and Tires 17 June 22nd, 2009 08:20 PM
HID Conversion Kit jake Polaris RZR Parts For Sale 4 May 18th, 2009 04:54 PM
Lighting Information - Light Source and Beam Pattern Description Baja Designs Lighting, Stereo and Electrical 0 February 17th, 2009 10:27 AM
RZR high and low beam lights thrillbilly9 Lighting, Stereo and Electrical 18 May 16th, 2008 08:50 AM
