Optima or Odessy Battery for RZR
Old March 14th, 2008, 08:51 AM
cisco kid cisco kid is offline
Need input to run my 5 85W lights, regural driving and rear light + light Whip.
When I am running all lights and going at high speeds, still draw downs the original battery and RZR will DIE ;-(
Optima or Odessy battery. Red or Yellow top
Part number of the better one and does it fit into the same space as the original one ;-)
Thousand Palms , CA
RZR #23
07 700XP
08 800RZR
Re: Optima or Odessy Battery for RZR
Old March 14th, 2008, 09:57 AM
LTZ470 LTZ470 is offline
My RZR: Gen 1
A lot of the guy's with optima have been having problems...I bought the Odyssey 925L off Ebay for $149 delivered to my door...stood it up sideways in the original bracket but i cut the brace on the front of the original bracket and bent it out so it would accept the 925 Odyssey Battery...have not had any problems at all...just got back from Glamis night riding each night and I thought I would hook it up and charge it back up as I figured it would be drawn down...it was fully charged when I hooked it up....so I checked the voltage and it was 13.0 which is good...so the Odyssey will hold it's charge and stay charged on the RZR I just don't like the extra weight I think it is like 25 lbs and the stocker is 11 lbs?, but it is down low for COG....
Old March 14th, 2008, 10:21 AM
Cole, I like that you tried it in Glamis that where I had my problem, do you have the link to Ebay on that Odyssey Battery 925L for $149
Thanks ;-)
Old March 14th, 2008, 11:20 AM
bluesti's Avatar
bluesti bluesti is offline
In Over My Head
First Name: Matt
My RZR: Red 2008
Same exact thread post? Check.
Same exact reply? Check.
lol... I wish all the RZR folks could "come together" and have ALL the info in one place...
Old March 14th, 2008, 11:42 AM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
what are the problems with optima???
Old March 14th, 2008, 12:07 PM
My RZR: Gen 1
Search Google: Optima Battery Failure...also I talked to a couple of guys that have had problems with the Optima, they said they must be making them cheaper or by a different method now...I don't know anything about batteries, but I do know that my children left my lights on the RZR on until the Odyssey was completely discharged...I charged it over night and it has never looked back if you did that to a Wet Cell Battery (Which I have a couple of times) it would never come back...so I am really pleased with the Odyssey....
Old March 14th, 2008, 02:23 PM
No input on post? Check
Jest noise? Check
Inside both forums? Check
LOL.......................
All's well in the fun of RZR, jest trying to get info ;-)
Old March 14th, 2008, 02:29 PM
txmd500's Avatar
txmd500 txmd500 is offline
I installed a Odessy PC1200 here's the link to the post. I have removed the photos due size.
http://www.rzrforums.net/projects-ho...0-install.html
Old March 17th, 2008, 09:55 PM
mnibusa's Avatar
mnibusa mnibusa is offline
I thought this was quite funny! the RZR only has 500 Watts total running power. How are you going to put 425 Watts of lights on it? You need HID's
You could install a truck battery in it and it still won't charge!
  #10 (permalink)
Old March 17th, 2008, 11:37 PM
hids use about 30 to 35 watts each GO HID!!!!!!
2006 silverado 2500 hd
2006 additude toy hauler
2008 polaris rzr
2006 suzuki ltr450
2005 kawisaki kfx700
2003 suzuki z400
2003 honda ex250
  #11 (permalink)
Old March 18th, 2008, 07:57 AM
Sorry all lights are 35w input and 85w output ;-)
  #12 (permalink)
Old March 18th, 2008, 09:50 AM
Johnny's Avatar
Johnny Johnny is offline
UTVCRAP*****
First Name: Johnny
My RZR: the red one
um either way you go with huge draws like you guys are talking about a battery made out of gold still wont work you cant get out of them any more then you put in so you need to use a charger and charge them at night and the odessy you need a charger that will charge like the 3 AMP SUPER CHARGER its really called a "super charger" the battery tenders dont put out enough juice at 800 mh so if you need juice use a good charger when you pull back into camp after running lights and or the 20000 watt stereo system then youll always be ready to rock we dont stock them at the store but we can order some up if you guys need them it think they are about 59.00
www.utvcrap.com 623-934-3070
623.934.3070
  #13 (permalink)
Old March 19th, 2008, 01:05 AM
i always on the way back at night cut the tunes out and only run 1 set of lights to let it build back up but i also bring my charger too just incase cus some times you forget and run it all...lol and yep if you use large draws it wont get a full charge
  #14 (permalink)
Old March 19th, 2008, 07:02 AM
Crowdog's Avatar
Crowdog Crowdog is offline
First Name: Jon
I have installed a voltmeter in mine to keep track of things. So far what I have noticed is the fan is the biggest draw.
I will be installing a water temp gauge to keep track of temps. It does seem like the fan comes on quite often.
www.UTVGuide.net
  #15 (permalink)
Old March 21st, 2008, 09:31 PM
bluesti's Avatar
In Over My Head
First Name: Matt
My RZR: Red 2008
I just ordered the Odyssey PC925 on Ebay... I'm sure it will work great!
