This is a discussion on Gear Case Lift Plates? within the Holz Racing Products forums, part of the Supporting Vendors category; I was just wondering if any one has got any of these bc i have no idea what they do... i was looking at a ...
Holz Racing Products - Lynden, WA - (360) 398-7006 |
I was just wondering if any one has got any of these bc i have no idea what they do... i was looking at a set and was just wondering if they were worth buyin.
| Sponsored Links | ||
Re: Gear Case Lift Plates?
This is copied right from our web site:
"Gearcase Lift Plates (AKA: Motor Mount Spacers) Lifts the front of the motor and transmission cases for better ground clearance. The stock motor mount location allows the motor and transmission cases to hang below the bottom of the frame rails. The Holz Racing Products Gearcase Lift Plates will help to better protect the underside of your expensive gearcase housings from impact by raising them out of harms way. ..A perfect addition to our already popular Billet Motor Mount set" The front of the transmission actually hangs below the frame rail about 1/8" This will help keep you from smacking it on a rock. These literally just came out RZR, RZR-S, RZR-4 Gearcase Lift Plates [618014] - $18.95 : Holz Racing Products, Race Proven Engineering They're only $18.95 a set, pretty cheap insurance |
Why is there not a third plate for the rear mount?
Inquiring minds want to know "why or why not"?
All the drive train components are 1st bolted together -- engine/trans/transfercase and rear end. Then - This assembly is mounted to the frame - Triangulated - In 3 points. 2 mounts are forward and one mount is centered and rearward. This 3rd mount is attached to the rear end - On top of the case. By raising the 2 front mounts - The complete drivetrain assembly then pivots on the rear mount. Looks like their approach/kit brings all the cases up just enough for frame protection instead of the other way around. Just thinkin out loud ............ ![]()
i have them and their easy to install...getting the eng up was a little tricky but dont need alot
I figured the rear was a pivot point for the forward two but why not raise the rear?
it has a throught bolt i dont know how they could change that one...
#8
The issue of the rear diff housing and CV hitting against the frame can be fixed by upgrading to our billet motor mounts. The stock rubber damped mounts are too soft therefore allowing the diff/drivetrain to move excessivley under load. This leads to more problems than just the diff hitting the frame. 2 different issues. 2 fixes. Same general location. I hear the question often "will this harm my drive line angle?" The answer is NO.
Code: RZRforum, 10% off all web orders 360-398-7006 |
#9
The issue of the rear diff housing and CV hitting against the frame can be fixed by upgrading to our billet motor mounts. The stock rubber damped mounts are too soft therefore allowing the diff/drivetrain to move excessivley under load. This leads to more problems than just the diff hitting the frame. 2 different issues. 2 fixes. Same general location. I hear the question often "will this harm my drive line angle?" The answer is NO. I had my first ride with them....they are great for the peace of mind! I got em after I smacked my transfer case through an aluminum skid plate hard enough to cause a small leak in the seal. Now I have to pull the motor and tranny to fix it.....lol Just getting these are well worth it IMHO. How much are the stage 3 BB kits again?
| Thread Tools | |
| Display Modes | |
| Front gear case | KEVIN@LASER | Engine and Drivetrain | 11 | February 15th, 2010 10:44 AM |
| rear gear case seal leak | flyhigh | Engine and Drivetrain | 8 | October 2nd, 2009 08:06 PM |
| 09 RZR Gear Case Complete | wheelman20012002 | RZR's and Parts | 2 | September 26th, 2009 12:06 PM |
| Front Gear Case | wheelman20012002 | RZR's and Parts | 2 | September 23rd, 2009 01:12 AM |
| Front Gear Case 4WD Unit | Mild Mike | General RZR Discussion | 17 | May 25th, 2009 08:58 PM |
