Hcr racing rzr xp-1000 long travel suspension kit - Polaris RZR Forum - RZR Forums.net
This is a discussion on Hcr racing rzr xp-1000 long travel suspension kit within the HCR Racing forums, part of the Supporting Vendors category; HCR RACING XP-1000 LONG TRAVEL SUSPENSION The unveiling of the 2014 Polaris RZR XP1000 set a new standard for performance in the UTV industry. Hot ...
Go Back   Polaris RZR Forum - RZR Forums.net > Supporting Vendors > HCR Racing
HCR Racing HCR Racing - Cedar City, UT - 435-865-9280
Old September 24th, 2013, 12:07 AM   #1
HCRRacing's Avatar
Member #22675
View HCRRacing's Photo Gallery(0)
The unveiling of the 2014 Polaris RZR XP1000 set a new standard for performance in the UTV industry. Hot on the heels of its initial release, HCR Racing proudly introduces the biggest, baddest bolt-on suspension upgrade your money can buy. The engineers at HCR designed a boxed A-arm and rear trailing arm system built to withstand the beatings of rigorous off-road riding. CNC’d suspension mounting points and a bolt-on shock tower increase the strength and rigidity of the stock chassis.
A suspension system is nothing without a great damper, which is why HCR chose King 2.5” reservoir shocks. The kit comes with a unique black body/titanium anodized shock finish and silver painted springs to stand out in a sea of stock equipment. The track width has been increased by 4” on each side, with a 3” longer wheelbase and arched rear radius rods for increased ground clearance. Summers Brothers 4340 Racing axles come standard with the kit, which cycles an incredible 21”+ of wheel travel! The suspension system is made to work with aftermarket wheels, as the stock Polaris wheels will not clear the front arms.
HCR Racing will also offer an OEM replacement kit. Utilizing the stock shocks and OEM geometry, the RZR-05300 XP-1000 OEM Kit will bolt directly to the stock machine, giving a much stronger suspension setup without breaking the bank. The $3,499 kit provides an added 1.25” of ground clearance from the upgraded arm design as well.
Every HCR Racing Long Travel kit goes through extensive testing in real-world driving conditions. Using many of the trails and terrain made famous by the toughest North-American off-road races in history, each kit comes with finely tuned, proprietary shock settings that are specific to HCR. A company that prides itself on its fit and finish, HCR produces each kit in-house with meticulous attention to detail and decades of fabrication and racing experience.
HCR Racing's RZR XP 1000 Long Travel Kit includes:
Custom-Tuned King 2.5” Internal Bypass shocks with finned remote reservoirs- standard with every kit
4" wider per side for maximum travel and stability
3" longer wheelbase for better high speed stability, hill climbing, and descents
Achieves 21"+ of wheel travel, providing the smoothest ride and best articulation of any LT kit
King Shocks billet compression adjusters - 30% Adjustment Range
Summers Brothers’ Racing 4340 Extended Axles
Laser Cut construction for precise fit and finish
Front bolt-on shock tower for an improved motion ratio and shock angle
CNC'd 4130 mounting points for increased integrity
High Clearance Boxed A-Arm Design- Each piece is Tig Welded by hand for strength and aesthetics
OEM ball joints to maximize lowspeed steering ease & smooth travel with less maintenance
High-Clearance Rear Trailing Arms provide an increase of 1.25” in ground clearance
High-Clearance Rear Boxed Radius Rods providing increased ground clearance and strength
Straight Rear Radius Rods available for race and dune car application
100% Bolt-on installation using factory mounting points
Larger front tube mounts are 1.25” in diameter with Delrin bushings for increased strength and durability
$7999
100% Proudly made in the U.S.A.
HCRRacing is offline   Reply With Quote
Old September 24th, 2013, 08:20 AM   #2
Everyone Suck Balls.
mikehoncho's Avatar
First Name: mike honcho
My RZR: RZR 170
Member #59427
View mikehoncho's Photo Gallery(0)
Re: Hcr racing rzr xp-1000 long travel suspension kit
Do you install this, if the Xp was brought to your shop? How much for installation?
mikehoncho is offline   Reply With Quote
Old September 24th, 2013, 02:40 PM   #3
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
saw some of these kits at the sands sports show this weekend.
very nice!
Does the 3" longer wheel base come from adding 1.5" both front and back?
Old September 24th, 2013, 06:56 PM   #4
HCRRacing's Avatar
Member #22675
yes we can do installation for an additional $500.00
The added wheel base is 2” in front and only 1” in rear so we do not change the factory angle. 3” total is added
Old September 24th, 2013, 06:59 PM   #5
Feedback Score: 17 reviews
FJK's Avatar
First Name: Frank
Member #8689
View FJK's Photo Gallery(279)
Sweet set up !
FJK is offline   Reply With Quote
Old September 24th, 2013, 07:19 PM   #6
HCRRacing's Avatar
Member #22675
Quote: Originally Posted by FJK View Post
Sweet set up !
Thanks FJK! We're definitely proud of this one!
Old September 24th, 2013, 08:35 PM   #7
Feedback Score: 14 reviews
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
seen it..BAD ASS!!
2014 PACE OFF ROAD BUILD Z1 complete
2016 XPT for US! Trail car
DC IMPORT SERVICE INC
Manteca Ca
dartersracing is offline   Reply With Quote
Old September 25th, 2013, 01:57 AM   #8
saqer's Avatar
First Name: dubai turbo
My RZR: xp
Member #5960
View saqer's Photo Gallery(0)
how mush lbs over stock is it ?
saqer is offline   Reply With Quote
Old September 25th, 2013, 11:20 AM   #9
gridman's Avatar
First Name: Pat
Member #9782
View gridman's Photo Gallery(0)
These kits were everywhere at the show they look awesome on the car but I say way to heavy for the sand guys but could be a great thing for the TURBO manufactures
gridman is offline   Reply With Quote
Old September 25th, 2013, 11:28 AM   #10
Standard Vendors
KB Motorsports's Avatar
First Name: KB Motorsports
My RZR: XP1000
Member #19990
View KB Motorsports's Photo Gallery(0)
Do you have any videos of your suspension kit in motion?
KB Motorsports is offline   Reply With Quote
Old September 25th, 2013, 11:44 AM   #11
Feedback Score: 8 reviews
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
View milosusa's Photo Gallery(27)
Sorry, little out of topic, but I will really like to see the test with your LT suspension on XP900 against stock XP1000.
Your suspensions really look a great.
milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline   Reply With Quote
Old September 25th, 2013, 04:50 PM   #12
dezertrzr's Avatar
Member #1669
View dezertrzr's Photo Gallery(2)
what material are they made out of?? how thick? whats the overall weight over stock??
dezertrzr is offline   Reply With Quote
Old September 25th, 2013, 05:07 PM   #13
Pumpjockey's Avatar
My RZR: 2013 900 XP LE
Member #49191
View Pumpjockey's Photo Gallery(0)
I have the HCR long travel on my 900 and it is no problem in the sand. I like it way better than the stock suspension.The 1000 will ride alot better with the HCR kit.I wish I had a 1000. Maybe later.
Pumpjockey is offline   Reply With Quote
Old September 26th, 2013, 04:13 PM   #14
Premium Member Premium Member
ALBAPAT's Avatar
Member #19746
View ALBAPAT's Photo Gallery(0)
Any idea on weight vs stock?
ALBAPAT is offline   Reply With Quote
Old September 26th, 2013, 04:23 PM   #15
rrose's Avatar
First Name: Ryan
My RZR: '09 RZR-s
Member #6011
View rrose's Photo Gallery(0)
Damon - this kit is amazing!
What's the deal with it not clearing the stock wheels? Do you need a different offset or a larger diameter wheel?
2009 RZR-S, Latest Concepts & Designs Custom Cage/Front Bumper, Race Radio, Intercom & 5" Color GPS, Holz/Kroyer Race Motor w/ Crankworks Crank (92hp), Muzzy Dual Exhaust, UMP Intake, DynaTek Coil, HCR Long Travel Kit w/ King Shocks, OMF Beadlocks, Beard Seats, Rigid Industries 30" E-Series & 10" SR-Series LED Light Bars, XP Headlight Conversion, Dakota Digital Dash, FUTV UHMW 1/2" Skid Plate w/ Thunder Hawk Skid Plate Support..... and on and on!
rrose is offline   Reply With Quote
Tags
hcr racing, king of the hammers, long travel, xp1000, xp1k
hcr
hcr long travel
hcr long travel rzr 1000
hcr racing suspentsion setup
hcr suspension upgrade for rzr 1000
polaris rzr 1000 long travel suspension
polaris rzr hcr long travel
polaris rzr xp1000 long travel suspension
rzr 1000 long travel kit
rzr 1000 long travel kits
rzr 1000 suspension kit
rzr xp 1000 long travel suspension
Long travel suspension? Ok_State_RZR Suspension 20 April 22nd, 2011 11:53 AM
Long Travel Suspension jmowens RZR XP 900 1 April 5th, 2011 05:22 PM
WTB RZR long travel suspension CATVOSRZR Polaris RZR Parts For Sale 3 May 2nd, 2010 04:15 PM
Want long travel suspension for rzr racejunkie Want to Buy 3 July 14th, 2009 11:49 AM
rzr s or a rzr with long travel suspension Blu du General RZR Discussion 23 June 11th, 2009 02:16 PM
