razor will not start - Polaris RZR Forum - RZR Forums.net
This is a discussion on razor will not start within the General RZR Discussion forums, part of the General RZR category; help. razor has been hard to start recently. today its dead. dash lights up and headlights work but it just clicks when key is turned. ...
Old December 15th, 2012, 02:40 PM   #1
kave's Avatar
Member #47140
View kave's Photo Gallery(0)
help. razor has been hard to start recently. today its dead. dash lights up and headlights work but it just clicks when key is turned. put a new battery on and did not help. any suggestions to keep me out of the dealership. its a 2009 razor s. thanks and merry christmas.
kave is offline   Reply With Quote
Old December 15th, 2012, 03:18 PM   #2
toomanytoys's Avatar
My RZR: 2010 RZR 800 LE
Member #47688
View toomanytoys's Photo Gallery(0)
Re: razor will not start
check the solenoid
toomanytoys is offline   Reply With Quote
Old December 15th, 2012, 04:00 PM   #3
GroundsKeeper Willie's Avatar
First Name: Shaun
My RZR: red 2010 standard
Member #16220
View GroundsKeeper Willie's Photo Gallery(10)
ditto on solenoid, or if its not working and has no signal to start check brake pressure switch, or might be starter itself....
2010 RZR standard, 14" vision wheels, Pro Comp Tires, Racertech Lift (Awesome), Led driving lights, rear storage box and gas can holders..Polaris map bag, UTV inc harness's
GroundsKeeper Willie is offline   Reply With Quote
Old December 15th, 2012, 10:09 PM   #4
switzomatic's Avatar
Member #38370
View switzomatic's Photo Gallery(0)
If not the solenoid then chances are the starter is shot. There's a bearing in the cover for the armature shaft that goes bad and then the starter won't work or seems sluggish (like a weak battery). You can get rebuild kits off ebay cheap but if the bearing is really toasted it's practically impossible to get it out of the cover without doing damage (that's what I ran into and had to get a new starter). Funny thing about it is according to the factory service manual if the bearing is bad it says to replace the cover/bearing assembly. Guess what you can't get from Polaris, the manufacturer of the starter, or any aftermarket places? Yep, the cover/bearing assembly-lol
09 RZR 800 Camo J-Strong Roof/Light Bar
3" Roktek Lift/12" STI beadlocks w/ 30" Mambas
Walker Evans shocks Big Gun exhaust/EPI clutch
UTV tilting windshield/rear roll-up shield
Full two-piece doors UTV airbox w/snorkels
Too many other odds and ends
2010 Scrambler 500 HO
Lifted 07 Ram Big Horn Hemi Crew 4x4 to haul 'em
switzomatic is offline   Reply With Quote
Old January 3rd, 2013, 06:36 AM   #5
cabyrd57's Avatar
First Name: byrd
My RZR: 2012 RZRS 800
Member #27772
View cabyrd57's Photo Gallery(0)
X2, i bought a rebuild kit also. I finally did get the bearing out of my armature, but the shaft was so scared up that it would not work, those bearings in the starters are a joke, like Mickey Mouse stuff. I thought i was never going to get that small bearing out after it was seized in there. If starter goes out, just buy a new one. JMO
14XP 1K,
RZRS, 28 rad laws, 3" catvos, offroad soundsystem, vipermax 5000, SOLD
cabyrd57 is offline   Reply With Quote
Old January 3rd, 2013, 08:33 AM   #6
6skinner
Orangemadness12's Avatar
First Name: Dave
My RZR: 2012 rzr s orange madness
Member #30843
View Orangemadness12's Photo Gallery(0)
Most likely the starter solenoid, I replaced one not long ago, mine would just click and my first thought was starter solenoid, replaced it and no problems since.
14 scrambler 1000, 28 mega mayhems on 14" sixr wheels, qsc clutched on hardest setting
14 Ace, 26" pro comp extremes on 14" msa m17 elixer wheels, total blast!
And a 600rwhp 03 powerstroke on 37" mud grapplers to haul it all
13 fx4 a/p on 35"grapplers, 6.2l
Orangemadness12 is offline   Reply With Quote
2010 polaris razor 800 will not start
2011 polaris rzr 800 will not start, just click
2012 polaris rzr wont start , just clicks once
can i start a polaris rzr when the starter is seized
discovery 800 utv wont start
my 800 2011 razor won't start just one click
my coleman 800 utv will not start, i replaced the starter solinoid now what
polaris ace wont start
polaris razor will not start
polaris rzr will not start
razer will not launch
razerrzrs wornt start
razor 800 efi my car will not start
will polaris replace my razor that can't be fixed
Razor / Razor S Cages @ Black Rhino BlackRhinoSteven Black Rhino Performance 11 September 24th, 2012 05:41 PM
Razor no start,hooked up battery backwards,codes 51,52 Mapixyona Engine and Drivetrain 6 September 9th, 2012 02:38 PM
engine start/die, start die, give throttle pop/backfire then clean up RacerSam RZR 800 Specific Discussion 10 August 2nd, 2012 09:11 PM
Looking for Razor S Suspension for Razor Great Dane Bonnie RZR-S Specific Discussion 0 February 27th, 2011 05:33 PM
