Throttle sticks and Drive hard to find sometimes
This is a discussion on Throttle sticks and Drive hard to find sometimes within the General RZR Discussion forums, part of the General RZR category; When it gets wet and cold outside do any of you have an issue with the throttle sticking wide open? Also do your RZR's grind ...
Old March 4th, 2009, 04:50 AM
Kennabeck's Avatar
Member #5156
View Kennabeck's Photo Gallery(0)
Also do your RZR's grind gears once in a while when you try and find forward or reverse?
I'm looking to see if this is a one off problem or if everyone has them.
Thanks.
Old March 4th, 2009, 06:16 PM
RZR-21's Avatar
RZR-21
My RZR: 08 RED RZR
Member #6064
View RZR-21's Photo Gallery(0)
Re: Throttle sticks and Drive hard to find sometimes
Yes mine stuck wide open last weekend. There is a upgraded cable you can get. Or try running the throttle cable along the radiator hoses back to the motor. Keeps it from freezing up. If your idling to high it will grind between gears.
Old March 4th, 2009, 06:50 PM
sr12345's Avatar
First Name: Sean
Member #1925
View sr12345's Photo Gallery(0)
There are plenty of other posts about this problem. One work-around, until you get yours fixed, is to simply start it in gear instead of park/neutral. This way you don't have to shift with the engine running.
Old March 5th, 2009, 04:43 AM
Kennabeck's Avatar
Member #5156
That was the plan until I started it (in gear) and the throttle stuck wide open and crashed into the barn.
These two don't go well together.
Old March 5th, 2009, 12:55 PM
IMF's Avatar
IMF IMF is offline
Member #5491
View IMF's Photo Gallery(0)
Wrong gear!................................Sorry, can't help not making the comment.
I had that transmission problem and at first thought it was just the detent ball and spring issues. Turned out they had to replace a couple gears. I go get it tomorrow and will have the parts list of what was actually needed. There is another thread on cable issues. Clean it good, use a good dry cable lube and seal up the ends to keep moisture and crap out.
Old March 7th, 2009, 07:08 PM
IMF's Avatar
IMF IMF is offline
Member #5491
Mine would not alway go into gear and would grind at times. the pretty much rebuilt the whole thing. Low and High gear, shifting arm, clutch yoke, bearings springs, seals, and of course the detent ball and spring. Dealer said the new gears have more bevel on the gears so he thinks the 09 has an upgrade.
Glad it was covered on warranty...with the top end and axle seal
Got it back today and plan for a ride tomorrow!
Old March 10th, 2009, 05:36 PM
wribbs's Avatar
My RZR: Red 2008
Member #1560
View wribbs's Photo Gallery(0)
I complained to my dealer about trouble shifting into gear and it was fixed under warranty. Maybe its a common issue?
Bookmarks
CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle LvDirtJunky Engine and Drivetrain 52 February 10th, 2010 10:42 AM
Can anyone tell me where i can find two of these? Hookie Want to Buy 4 February 20th, 2009 07:55 PM
Dealer cant find ?? dulcimer player General RZR Discussion 9 October 23rd, 2008 09:23 AM
Hard to find a RZR to purchase ckelsoe General RZR Discussion 22 July 13th, 2008 08:06 PM
Rzr hard to find! Jeffro General RZR Discussion 17 May 18th, 2008 07:27 PM
