Help play in my rear wheels!!!! - Polaris RZR Forum - RZR Forums.net
This is a discussion on Help play in my rear wheels!!!! within the General RZR Discussion forums, part of the General RZR category; My 2011 S has play in both rear wheels, it has 300 miles on the unit. The left rear wheel has 1/8" of play and ...
Old August 29th, 2012, 01:05 PM   #1
hoyt1967's Avatar
First Name: Jeff
Member #40577
View hoyt1967's Photo Gallery(0)
My 2011 S has play in both rear wheels, it has 300 miles on the unit. The left rear wheel has 1/8" of play and the right has 1/16" of play. IMO there should be NO play in either!!!! I replaced the left rear wheel bearing, I also installed 2 new cone washers and even tried 3, I have tried torque on the axle nut from 80lbs to 100lbs and it remains unchanged. The play is in the hub, or the axle and I'm not sure which one to start replacing. With this low of mileage neither should need to be replaced. I was hoping someone has run into this problem before, I contemplated trimming off a few thousenths off of the end of the hub, but I dont want to be buying more parts.
The play is NOT coming from bushings, ball joints etc. You can clearly see play is coming from the wheel bearing area, and again I have replaced the bearing.
HELP!!!
hoyt1967 is offline   Reply With Quote
Old August 29th, 2012, 01:08 PM   #2
gunrunner's Avatar
First Name: Man
Member #4830
Re: Help play in my rear wheels!!!!
worn out, polaris uses cheap china bearings, its going to happen for sure fast if you ride in mud a lot
site de flirt internet
gunrunner is offline   Reply With Quote
Old August 29th, 2012, 02:14 PM   #3
hoyt1967's Avatar
First Name: Jeff
Member #40577
Whats worn out? The bearing is new, its a Federal Mogul bearing that has zero miles on it. It pressed into the hub just fine.
Old August 29th, 2012, 02:24 PM   #4
HIGHOCTANE's Avatar
Member #16360
Chek the hub where it goes into the bearing..ie Mic it and compare to spec in the shop manual. The hub is what the wheel mounts to, bearing carrier is what the bearing is pressed in to. Not being a smartass, just clarifying what I am talking about measuring. Many people call the bearing carrier the hub.
HIGHOCTANE is offline   Reply With Quote
Old August 29th, 2012, 02:36 PM   #5
gunrunner's Avatar
First Name: Man
Member #4830
What he said also check the bushings where the hub attaches to the a-arm, they wear out fast cause it has no grease fittings.
Old August 29th, 2012, 02:51 PM   #6
hoyt1967's Avatar
First Name: Jeff
Member #40577
10-4, I'm a mechanic for a living, so I can relate to "clarifying". Yes the bearing pressed in nicely into the carrier, no excessive wear. I do suspect the hub and that is good avice, I'm just frustrated. It has to be a hub or an axle, I already wasted time and money on bearings and cone washers. Just want to get it right this time.
Gunrunner, I have checked the bushings, they are tight, and greased
Not bashing Polaris, but come on!!! My outlander has 3500 miles on it, ran in the same conditions, no wheel bearing issues.
Old August 29th, 2012, 03:00 PM   #7
HIGHOCTANE's Avatar
Member #16360
I'd be frustrated too..something we kind of deal with on Polaris'...sometimes I think the parts are out of spec from day one..I've seen bad wheel bearings and hubs with very low miles..once replaced no repeat issues for a long time..and often it's a single bearing or hub...makes me think bad QA on those parts from the get go...no screaming transmission though lol( loved my Outlander..was ready to by a new one until I heard the new frame has more issues than the old one ) Problem should not be the axle unless for some strange reason the axle nut is running out of threads before pulling the hub down tight. I won't say that's impossible..but I haven't seen it..something to check though.
Old August 29th, 2012, 03:05 PM   #8
LoneStar Racing's Avatar
Member #11
View LoneStar Racing's Photo Gallery(0)
Its probably the hub. They are aluminum and wear down slightly, and sometimes break off. If your old bearing was shot, it might have contributed to the problem, or the splines inside that connect to the axle stub shaft are worn out. We replace these hubs all the time. There are some better aftermarket ones available, and polaris switched to a steel hub on the RZR4, that i think is a direct replacement, but not 100% sure on that one. If the bearings are good, its most likely the wheel hub, as you said all the bushings were tight.
G-
Lone Star Racing
forum members coupon code for 10% off : utvforum10
www.lsracing.com
LoneStar Racing is offline   Reply With Quote
Old August 29th, 2012, 04:31 PM   #9
hoyt1967's Avatar
First Name: Jeff
Member #40577
Thanks for the great advice guys! One tends to loose sight of the KISS rule when you get frustrated. The old bearing was not bad is what pissed me off the worst, I just replaced it cause I had some play in the wheel. I will order up a new hub and replace the other side if that is the cure.
Yes the outlander has given me some troubles also, just not at 300 miles. I love this RZR, but I'd rather be bolting on more accessories than parts
Old August 29th, 2012, 04:44 PM   #10
GGG
GGG's Avatar
First Name: Geoffrey
My RZR: 2012 RZR XP LE
Member #38490
View GGG's Photo Gallery(0)
i have a 2012 with around 150 miles and the same thing i am also a mechanic. i replaced the bearings and now i guss i will just replace everything on both sides. so its not just you lol
GGG is offline   Reply With Quote
Old August 29th, 2012, 04:47 PM   #11
Member #11
keep in mind, the stock bushings for the rear knuckles are a flexible rubber, so you will get some movement no matter what.. but it should be easy to tell if those are moving or not..
G-
Lone Star Racing
www.lsracing.com
Old August 29th, 2012, 04:57 PM   #12
HIGHOCTANE's Avatar
Member #16360
Yeah hub or bearing play should be easy for a mech to differentiate from bushing..Normal bushing flex will feel spongy..hub and /or bearing won't.. You have to really bow up on the wheel to flex the bushings lol
Old August 29th, 2012, 05:11 PM   #13
tbailey's Avatar
Member #25568
View tbailey's Photo Gallery(0)
Aftermarket Source for Steel Hubs?
G-
Who sells the aftermarket steel hubs? I'd like to be ready for what sounds like the inevitable.
tbailey is offline   Reply With Quote
Old August 30th, 2012, 08:58 AM   #14
Member #11
Polaris makes a steel hub for the RZR4. Its what comes on them from the factory. I want to say they are a direct replacement, but i am not 100% sure. I think the knuckles, brakes, and cv stubs are all the same, so I would think they would go right on, but I haven't tried it, so i can't say for sure. Anyone else actually try this?
Lone Star Racing
www.lsracing.com
Old August 30th, 2012, 09:21 AM   #15
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
I think all the hubs and wheel bearing have more play in them than they should.
I tried new bearings with no change, and then billet hubs from UTV Inc and they still wiggle a little.
2008-2009: UTV INC POLARIS RZR RZR-S RZR-4 BILLET FRONT & REAR HUBS HUB
2010+: UTV INC 2010+ POLARIS RZR RZR-S RZR-4 RZR 570 BILLET FRONT & REAR HUBS
none available for the XP yet.
2010 polaris rzr rear wheel play
2010 polaris sportsman xp rear wheel play
2012 polaris ranger rear wheel bearing play
aftermarket steel hubs for 2014 rzr s 800
how much play should there be in my polaris ranger wheels
metal hubs for polaris rzr
play in rear hub rzr fourm
rear wheel has play on rzr
rear wheel has play polaris rzr
rzr 800 play in rear hub
rzr 800 rear tire has some play
rzr 800 rear wheels have play
rzr 800s rear wheel play
rzr 800s wheel moves has play
rzr rear spindel play
Rear Yoke Play silverbullet General RZR Discussion 0 April 8th, 2012 09:39 AM
Play in rear wheels YZ117 RZR XP 900 3 March 18th, 2012 08:09 PM
play in front wheels bruno2 Engine and Drivetrain 11 October 25th, 2011 06:27 PM
Play in both rear hubs rzr340 Engine and Drivetrain 5 March 6th, 2010 07:08 PM
Front wheels have play in them sandaddict General RZR Discussion 26 October 1st, 2008 12:54 PM
