Front axle removal tips? - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old July 29th, 2012, 07:07 PM Thread Starter
Teamnipplesdeep's Avatar
So I broke a front axle on my 08 std about a month ago ( I left for work right after it happened) and I will be attempting to replace it when I get in. My question is: are there any tips to remove it? The only thing left of the axle is the inside cv (cup and spline?) that goes into the front diff. I had this happen on an 08 sportsman and never did get the cv out of the diff. I tried prying it out, pb blaster, everything I could think of and could never get it out. Has anyone else had this problem and could possibly throw me some tips or suggest a special tool I'm unaware of? Thanks ahead of time!
Teamnipplesdeep is offline
post #2 of 10 Old July 30th, 2012, 08:57 AM
Is this my outloud voice?
Drground's Avatar
Re: Front axle removal tips?
Disconnect the shocks and the A arms. Grab hold of the axle and jerk pull it from the diff.
"Time is free, but it's priceless. You can't own it, but you can use it. You can't keep it, but you can spend it. Once you've lost it, you can never get it back."
~ Harvey MacKay
Drground is offline
post #3 of 10 Old July 30th, 2012, 09:09 AM
mnrzr-s's Avatar
Do you have a slide hammer? That's what I ended up using to get mine out. I think I saw a company that actually made an adapter for removing cv's with at slide hammer. I just used the "L" attachment and worked my way around the cv trying not to pull too hard in any one direction.
I have also found that Kroil seems to loosen seized parts better than PB. Smells better too.
When I installed the new axles, I used anti seize on the splines to hopefully make removing them the next time a bit easier.
mnrzr-s is offline
post #4 of 10 Old July 30th, 2012, 09:09 AM Thread Starter
The axle is not complete, I jerked on it so much to where the only thing left is the inner cv inside of the front diff
post #5 of 10 Old July 30th, 2012, 09:27 AM
mnrzr-s's Avatar
I read that in your first post. Did you read my reply?
Slide HAmmer attachment
mnrzr-s is offline
post #6 of 10 Old July 30th, 2012, 09:46 AM Thread Starter
Ha looks like I posted that right after you did I was replying to the other post, I'm looking online now for a slide hammer. That seems to be the best route
post #7 of 10 Old July 30th, 2012, 10:50 AM
6skinner
Orangemadness12's Avatar
That's what I've been trying to think of for hours, a slide hammer but I couldn't remember what it was called. That would be your best bet, pretty much perfect for what you're doing
14 scrambler 1000, 28 mega mayhems on 14" sixr wheels, qsc clutched on hardest setting
14 Ace, 26" pro comp extremes on 14" msa m17 elixer wheels, total blast!
And a 600rwhp 03 powerstroke on 37" mud grapplers to haul it all
13 fx4 a/p on 35"grapplers, 6.2l
Orangemadness12 is offline
post #8 of 10 Old July 30th, 2012, 11:41 AM
Kymedic's Avatar
I used a large 3' screw driver. Slid it between the cv cup and diff and popped right out.
Sent from my Desire HD using Tapatalk 2
Kymedic is offline
post #9 of 10 Old July 30th, 2012, 11:42 AM Thread Starter
Thanks fellas I'll give it a shot I hope it all goes easy as planned
post #10 of 10 Old July 30th, 2012, 04:01 PM
keith0715's Avatar
we just had this problem. i pulled the axle righ out of the cup. spent two hrs and still couldnt get the cv cup out. we put the axle bar back in the cup,gave it a jerk or two and it popped out.
08 rzr super atv s conversion with 5"lift, snorkels, 28inch gators, roll bar chopped 3in, home made doors, seat belt harness,:rzrs:
keith0715 is offline
Tips on getting axle out of diff. Sasq40 RZR XP 900 38 May 22nd, 2013 03:11 PM
things to watch for ...or tips needed axle removal / installation btq RZR XP 900 0 July 23rd, 2011 11:04 AM
Frt. Axle removal Darren Ellis Forum Help, Questions and Info 36 July 24th, 2010 10:03 PM
axle removal how? bigmike58 General RZR Discussion 6 February 11th, 2009 12:20 AM
Front Axle Removal crazywatson Projects and How-To 7 January 16th, 2009 11:39 AM
