Grumpy mod done w/pics - Polaris RZR Forum - RZR Forums.net
post #1 of 44 Old June 19th, 2012, 02:05 PM Thread Starter
scubadnv's Avatar
First Name: Don & Viv
My RZR: 2011 RGE RZR-4
Member #21107
View scubadnv's Photo Gallery(30)
Just did the grumpy mod, hopes this helps because I don't want to have to spend $39 every couple of trips, hell that's 2 30 packs of beer. Opening is cut 6 inches wide and 6.25 inches tall. Web site won't let me load pics so I will try a different way. [IMG] [/IMG]
scubadnv is offline
post #2 of 44 Old June 19th, 2012, 06:34 PM
mxking03's Avatar
Member #38283
View mxking03's Photo Gallery(0)
Re: Grumpy mod done w/pics
what is the part number for the filter, and will this really help with the dirt in the intake
mxking03 is offline
post #3 of 44 Old June 19th, 2012, 06:42 PM
Waistdeep's Avatar
My RZR: 2011 RZR Camo
Member #18687
View Waistdeep's Photo Gallery(0)
That will be loud..
Waistdeep is offline
post #4 of 44 Old June 19th, 2012, 06:53 PM
darkstar_420's Avatar
My RZR: 2011 Screamin Yellow "S"
Member #29684
View darkstar_420's Photo Gallery(0)
actually its not that loud, i have it done with a fram filter, paper, because itll filter better
darkstar_420 is offline
post #5 of 44 Old June 19th, 2012, 07:03 PM
I am still 16 in my head!
Kandgo's Avatar
First Name: Rick
My RZR: 09s 08stnd several atv's and more
Member #22394
Feedback Score: 29 reviews
That will definitely work on keeping your Air Box Cleaner! If it gets to loud then your half way there for a easy snorkel on up top to keep the noise down. But I bet it won't be bad at all!
Kandgo is offline
post #6 of 44 Old June 19th, 2012, 07:24 PM Thread Starter
scubadnv's Avatar
Member #21107
K&N P# 33-2008-1 I don't expect a noise isssue since I have a PRP bench seat between it and me, just remember to adjust clearance between seat and the filter if you have a rear bench. When I first put the seat in it made a perfect seal on the filter.
scubadnv is offline
post #7 of 44 Old June 19th, 2012, 08:34 PM
aintlftyet's Avatar
First Name: Vic
My RZR: 2011 yellow 800
Member #38417
View aintlftyet's Photo Gallery(0)
It's not loud at all. I was using paper filter but went to the K&N. You can pull it out and tap out the dirt and good to go. At the end of the ride just rinse with water and let dry. I can make 3 to 4 rides before checking the stock filter, which has a Outerwear on it. Also no oil on the K&N filter.
aintlftyet is offline
post #8 of 44 Old June 19th, 2012, 08:48 PM
whiteeye42's Avatar
First Name: Robert
My RZR: 2011 rzr LE
Member #18881
View whiteeye42's Photo Gallery(0)
nice mob but what are the measurement for the cut out (ie: how far from the bottom for the first line and the side lines where did you measure from)
11 polaris rzr 800 le
Be Good Play Nice and Share Your Toys
whiteeye42 is offline
post #9 of 44 Old June 20th, 2012, 03:50 PM
mxking03's Avatar
Member #38283
would it be better to do this to keep the dirt out or just snorkel it to keep the dirt out
mxking03 is offline
post #10 of 44 Old June 20th, 2012, 04:41 PM
kbh78's Avatar
First Name: Kyle
My RZR: 2010 rzr s and 2011 rzr 170
Member #32165
View kbh78's Photo Gallery(0)
I did away with my setup after I put a bench seat in. It was restricktive and was to loud (to much belt wine). I put a piece of rubber back over the hole I cut to get it back to factory but I added a snorkel going directly into the box from the top and put a filter on that so it pulls air from the snorkel and factory air inlet. The cvt and motor need alot of air and I just didnt think they would get that much air with that setup and a bench seat plus the filter got dirty quick which retricted that much more.
2010 RZR S
Custom cage, Boonedocker programmer,Dirty Dawg Clutch, S&S cycle 7000 rpm valve train kit, S&S reprogramed ECU to 7000 rpm, 46mm throttle body, Muzzy exhaust, Affco silver series shocks with progressive rate spring, UTV Gaint middle seat, HID lights, Holtz engine mounts, Top Dog outfitters rock sliders, and 1.5 to 1 steering quickener, EMP tranny saver, Rath doors, Polaris pre runner bumper, Lock in ride windshield, FUTV a arm skids
2011 RZR 170
kbh78 is offline
post #11 of 44 Old June 20th, 2012, 04:45 PM Thread Starter
scubadnv's Avatar
Member #21107
I wouldn't want to give a dimension from the bottom since the assembly of the air box and foward panel could vary considerably possibly causing you to cut the bottom of the air box so the best thing would be to reach under the panel to find the bottom of the air box and base your measurements off of that and start a bit higher than that. The filter comes with a seal which is very close to the the dimensions of the filter and I used it as a template for the hole, this made the hole smaller than it will finally be but it is a bunch easier to enlarge the opening a bit at a time than try to figure out a way to make it smaller so start at "your" base line, mark a center line and cut to make your filter fit snugly. Hope this helps.
scubadnv is offline
post #12 of 44 Old August 4th, 2012, 03:00 PM
wvrzrider's Avatar
First Name: Maddog
My RZR: 2013 RZR XP Walker Evans Edition
Member #35965
View wvrzrider's Photo Gallery(0)
Don, just wanted to say thanks for posting these pics and info. I got mine done today and this thread made it so easy. I used a dremil to cut out the opening. Ordered the k&n filter from advance auto yesterday and it arrived this morning. 29.95. Thanks a bunch
Watch out for the idiot behind me
wvrzrider is offline
post #13 of 44 Old August 4th, 2012, 03:06 PM Thread Starter
scubadnv's Avatar
Member #21107
You are welcome. I made a small improvement after the install since the noise was a bit more with the mod. I fabed a scoop out of sheet metal to go over the filter and the pick up is more like the factory set up drawing air from below and this also keeps the seat from touching the filter because at the end of every ride I could see the imprint of the filter on the back of my seat. This mod could also offer protection from elbows, gear or what ever making contact.
scubadnv is offline
post #14 of 44 Old August 5th, 2012, 05:29 AM
timonste's Avatar
First Name: Luc
My RZR: 800 Black/Liquid Silver LE
Member #40208
View timonste's Photo Gallery(0)
Originally Posted by darkstar_420 View Post
exactually its not that loud, i have it done with a fram filter, paper, because itll filter better
Darkstar Do you have the Fram Filter #.
timonste is offline
post #15 of 44 Old August 5th, 2012, 05:37 AM
Official Parts Breaker
orangecrush's Avatar
My RZR: 2013 Jagged X
Member #21745
Feedback Score: 21 reviews
View orangecrush's Photo Gallery(20)
Scuba,
One quick question... You used black foam in a can at the bottom of the filter hole. Did you go all the way around it or did you make a mistake and use the foam for just the bottom edge?
I ask because obviously if the hole is the right size, it should fit without any foam.
Just checking.
Thanks,
Mark
orangecrush is offline
Grumpy mod question darkstar_420 General RZR Discussion 5 April 29th, 2012 12:24 PM
Grumpy Mod info sucks!! Dirty Dog General RZR Discussion 11 May 4th, 2011 05:34 AM
Grumpy mod. with recessed prefilter install protector General RZR Discussion 1 March 21st, 2011 07:36 PM
Holz-Grumpy air filter Henry Forum Help, Questions and Info 0 June 4th, 2010 05:43 PM
KMS and Grumpy Mod??? Kid Dynomite Engine and Drivetrain 1 May 27th, 2009 06:15 AM
