Driveshaft removal - Polaris RZR Forum - RZR Forums.net
Driveshaft removal
This is a discussion on Driveshaft removal within the General RZR Discussion forums, part of the General RZR category; 2012 RZR 800, how hard to remove and how do you do it. I want to send it out to be balanced....
Old May 21st, 2012, 03:36 PM   #1
Feedback Score: 4 reviews
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
View Sahara01's Photo Gallery(0)
Driveshaft removal
Sahara01 is offline   Reply With Quote
Old May 21st, 2012, 03:51 PM   #2
Feedback Score: 5 reviews
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Knock the roll pin out out next to the front differential and it'll slide back and out. You'll need to remove the center console, maybe skid plate, and maybe the front axle.
chipper is offline   Reply With Quote
Old May 21st, 2012, 04:02 PM   #3
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
Sounds easy enough, Thankyou.
Old May 21st, 2012, 04:16 PM   #4
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Yes sir. You can search on here and find a downloadable manual to help you out. Check in the signature of teamhog I think maybe.
Old May 21st, 2012, 05:10 PM   #5
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
Cool, thanks again !
Old May 21st, 2012, 05:28 PM   #6
King of crash!
Member #787
Re: Driveshaft removal
it fits lose so ball might not help
Old May 21st, 2012, 05:59 PM   #7
Sahara01's Avatar
My RZR: 800 EFI
Member #33929
Huh, now what.
Old May 21st, 2012, 06:49 PM   #8
Pirate's Avatar
First Name: Stuart
Member #3677
You won't have to remove the front diff. But before you put it back together, be sure to slide the driveshaft forward, past the front axle splines (not on them)...then slide the rear yoke over the trans output shaft. It will slide to the rear far enough to be able to put the front yoke on the front axle input shaft.
Pirate
Pirate is offline   Reply With Quote
Old May 21st, 2012, 08:29 PM   #9
nuclear_orange's Avatar
First Name: Kyle
My RZR: 11 Rzr 800 LE Nuclear Sunset Orange
Member #29572
View nuclear_orange's Photo Gallery(1)
Before you remove the shaft make sure your drive shaft shop can even balance it. I broke the weld on the rear yolk ( 2 weeks out of warranty and it was clearly a bad weld and not abuse ). It was easy to remove without that piece attached but did not go back in so easy. My local shop put in better tubing than factory but they did not have the correct splines to balance. I thought that was odd, but anyway I do not notice it being a problem. Also be patient with the role pin when you are driving it out - I used a 1/4 long extension with a tiny socket on the end that was a little smaller than the roll pin after soaking it all with PBblaster. Bottom line, if you don't have some serious vibration in that shaft I would find a better mod to spend your time on.
2011 800 50" LE Nuclear Orange. Factory UTV Full Skid package, RacerTech Lift and Springs, Viper Winch, EMP Bumper, 26" BigHorns on ITP HD2, Kolpin Full Vented Windshield & EMP Cooter Brown Roof.
nuclear_orange is offline   Reply With Quote
Old May 21st, 2012, 10:25 PM   #10
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Thanks Chip...
It should be right there...
Chris Dierkens
teamhog is offline   Reply With Quote
2011 polaris razor 4 800 drive shaft removalpartshouse.com/
2011 polaris razor 800 4 seater drive shaft removal
900 ranger driveshaft removal
drive shaft for 2011 800s rzr
front drive on polaris rzr
how remove main center drive shaft 2012 rzr 800s
how to pull front drive shaft from polaris rzr 800s
how to remove drive shaft from 2012 razer
how to remove drive shaft from polaris rzr
how to take driveshaft off rzr 800
how to take out drive shaft on 800 rzr
polaris rzr 800 drive shaft removal
remove rzr 900 xp drive shaft
rzr xp4 drive shaft removal
Driveshaft rubbing tngw1500se RZR 4 Specific Discussion 13 February 10th, 2014 10:00 PM
Driveshaft ? jpred1 RZR XP 900 2 April 21st, 2011 06:48 PM
Cut Driveshaft??? bmzero Engine and Drivetrain 8 March 29th, 2010 08:37 AM
Driveshaft Problems The Scotsman Forum Help, Questions and Info 2 March 23rd, 2010 03:50 PM
Driveshaft HELP killintime Engine and Drivetrain 3 March 12th, 2009 09:47 PM
