Rear end popping/clicking when turning - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old April 26th, 2012, 08:41 AM Thread Starter
Blazinhi87's Avatar
First Name: Rich
My RZR: '09 Rzr
Member #9305
Feedback Score: 4 reviews
View Blazinhi87's Photo Gallery(49)
Ok so I tore 3 cv boots on my gorilla axles last weekend. I took the cvs apart, cleaned all the grease out, installed new grease & boots. When I put it all back together I hear a clicking noise from the rear only when I'm turning. Makes no noise at all when going straight. Is something binding in the cv or there something starting to go in the rear diff.?
Sent from my SCH-I510 using Tapatalk 2
Blazinhi87 is offline
post #2 of 11 Old April 26th, 2012, 10:13 AM
bluetoad7's Avatar
First Name: Ron
My RZR: 2017 XP 1000 Gold Matte Metallic Rock Crawler Edition
Member #19658
View bluetoad7's Photo Gallery(0)
Re: Rear end popping/clicking when turning
Check the torque on your rear hub nuts, heck check the front too. Should be 80 ft.lbs. If that is OK try adjusting your rear brake calipers. There is an allen head bolt on the inside of each caliper. Tighten all the way then back off 1/4 to 1/2 turn. Hope one of these solves your problem.
Da Blue Toad
bluetoad7 is offline
post #3 of 11 Old April 26th, 2012, 05:02 PM Thread Starter
Blazinhi87's Avatar
First Name: Rich
My RZR: '09 Rzr
Member #9305
Well I loosened everything and retorqued. Axle nuts, upper & lower a-arms, shocks, swaybar, & calipers. changed all the brakes(needed anyways) & adjusted them. same noise. Is this possibly just the break-in till the grease covers the whole cv joint? Or do I need to break cv down and see if something is out of place?
post #4 of 11 Old April 26th, 2012, 05:19 PM
Love2Ride's Avatar
My RZR: 2009 Orange LE, 2012 RZR S
Member #24167
View Love2Ride's Photo Gallery(0)
I have the same problem with my 09, I tore it all apart twice and can't make anything click. It only clicks when I turn to the right. I pushed it down the hill and it seems to come from inner CV. I had the dealer replace the wheel bearings and that wasn't it. So its currently at my dealer. I called today and they haven't looked at it yet. May be next week before they figure it out.
I have driven 350 miles with it clicking, so who knows what it is? I've tried the caliper and the hub nuts so I understand your frustration.
Love2Ride is offline
post #5 of 11 Old April 26th, 2012, 05:37 PM
bluetoad7's Avatar
First Name: Ron
Member #19658
Have either of you checked to see if your hubs are cracked? That is very common. They will crack from center towards a lug from running too little torque on the hub nut. You could also have too little torque on your lug nuts. This also will cause clicking. The other question I have is are the Gorilla axles supposed to allow you more or less angle than stock before cv joints bind? You can jack the rear up and let wheels droop so they clear the ground and rotate them. If you have bind, you should be able to feel it. I have no experience with Gorilla axles, but since that is the mod you made, you might check with the vendor to see if they will work with a RokTek 3" lift. Just trying to play devil's advocate here.
Da Blue Toad
post #6 of 11 Old April 26th, 2012, 05:50 PM
Teamnipplesdeep's Avatar
First Name: Blake
Member #37593
View Teamnipplesdeep's Photo Gallery(0)
Mines doin the same thing, keep us posted mines the driver rear
Teamnipplesdeep is offline
post #7 of 11 Old April 26th, 2012, 06:22 PM Thread Starter
Blazinhi87's Avatar
First Name: Rich
My RZR: '09 Rzr
Member #9305
Not the hub. they are fine(billet alumni. hubs). I always torque my lugs down. I have run those axles for 2 1/2 yrs and been fine. Gorilla allow for 40% more angle than stock cvs. Bearings are brand new also. It has to be either rear diff. or I rebuilt the cv wrong. can't run without rear axle in place so it's kinda hard to tell which one.
post #8 of 11 Old April 26th, 2012, 07:25 PM
Just Chuck's Avatar
First Name: Chuck
My RZR: 09 RZR S
Member #6362
View Just Chuck's Photo Gallery(0)
Another suggestion. Try putting some grease on the splines of the axle and splines on the hub.
Just Chuck is offline
post #9 of 11 Old April 26th, 2012, 07:32 PM
OnlyPolaris's Avatar
First Name: Stephen
My RZR: 2015 RZR XP1K
Member #16556
View OnlyPolaris's Photo Gallery(0)
Its the cv joint clicking. When is only happens when turning thats a classic sign. Probably drove a little to long with the torn boots and have a flat spot in some of the balls.
OnlyPolaris is offline
post #10 of 11 Old April 26th, 2012, 07:36 PM
Red Dragons
LoneStarRZR's Avatar
First Name: Taylor
My RZR: 2014 XP1000
Member #23779
View LoneStarRZR's Photo Gallery(7) Send a message via AIM to LoneStarRZR Send a message via Yahoo to LoneStarRZR Send a message via Skype™ to LoneStarRZR
Had the same problem on the passenger rear inner after the boot got cut but i ran it for a couple days and got a bunch of trash in it, heard the popping so i took it apart and cleaned it new grease new boot, drove it for about 5 minutes then, boom, it blew apart, that inner maybe had 15 hours on it, i think it was just faulty, bought a new one and she is runnin smooth again
2008 800 -SOLD SOLD SOLD
2014 Titanium XP1000
LoneStarRZR is offline
post #11 of 11 Old May 13th, 2012, 06:12 AM
riknkeri's Avatar
Member #30080
View riknkeri's Photo Gallery(0)
my o8 is doing same thing when turning hard right!!!
riknkeri is offline
Clicking after turning key off jlb27537 Engine and Drivetrain 9 October 2nd, 2011 06:32 AM
Rear End clicking/popping noise at slow speed pmbaseball24 Engine and Drivetrain 1 July 9th, 2011 02:42 PM
clicking and popping noise in rear end of rzr solved DirtDobber General RZR Discussion 6 February 27th, 2011 07:22 PM
popping in front end when turning jodyfj40 General RZR Discussion 18 February 22nd, 2011 03:29 PM
Clicking noise when turning left??? urclever RZR-S Specific Discussion 31 January 29th, 2011 06:56 AM
