Difference between AGL vs. AGL Plus and can you mix them? - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old April 11th, 2012, 12:52 PM Thread Starter
louisb's Avatar
Hey All,
I just recently started changing the fluids on my 09 RZR 800 and I ran out of AGL Plus fluid when I was filling up the tranny. I ordered what I thought was more AGL Plus fluid off eBay and they ended up sending me just AGL. The image shows AGL fluid, but everything else in the auction said AGL Plus including the description.
What are the differences between the two fluids and would it be an issue if I mixed the two together?
I haven't called the dealer who was selling it on eBay yet because I figured I would see if it was even a big deal or not.
Thanks in advance for your help.
louisb is offline
post #2 of 4 Old April 11th, 2012, 01:20 PM
jlb27537's Avatar
Location: Texas in Winter and somewhere cool in summer.
Re: Difference between AGL vs. AGL Plus and can you mix them?
They both are synthetic gear lube. Probably same stuff, just different package. The MSDS are here for both
http://msds.polarisindustries.com/Po...t%20_0126_.pdf
http://msds.polarisindustries.com/Po...%20_10271_.pdf
jlb27537 is offline
post #3 of 4 Old April 11th, 2012, 01:22 PM
rardoin's Avatar
I was told by the dealer: They are interchangeable...viscosity/applications are the same, he thought they had added corrosion modifiers to the plus but he felt it was more a marketing ploy. (Like "New and improved Tide"..basically same crap with a different pour spout etc.) I use a vacuum pump to remove old fluid on changes and in the demand drive unit (front diff) it leaves an ounce or so in the bottom. This means I have mixed the two and my drive works fine.
rardoin is offline
post #4 of 4 Old April 11th, 2012, 01:25 PM Thread Starter
louisb's Avatar
Thank you for the quick response!
louisb is offline
Any difference in a 08 CV & 09 S CV southernman General RZR Discussion 2 October 30th, 2010 12:53 PM
What's the difference ? stretch General RZR Discussion 7 April 20th, 2010 02:08 AM
difference in 07 and 08 rzr's pimp800 General RZR Discussion 6 August 9th, 2009 12:04 PM
What's the difference? FUBAR_Midway RZR-S Specific Discussion 0 August 2nd, 2009 03:13 PM
difference between rzr and rzr s damonmlime General RZR Discussion 5 July 22nd, 2009 07:40 AM
