Rzr Wont Start!?! - Polaris RZR Forum - RZR Forums.net
Rzr Wont Start!?!
This is a discussion on Rzr Wont Start!?! within the General RZR Discussion forums, part of the General RZR category; i have a 09 rzr s thats only a week old and it will turn over but wont start. i cant take it to the ...
Old December 23rd, 2008, 03:49 PM   #1
FlyHigh rzr's's Avatar
First Name: Nick
My RZR: 09 rzr s
Member #4775
View FlyHigh rzr's's Photo Gallery(0)
Bluduh Rzr Wont Start!?!
i cant take it to the dealer untill after the holidays and ive tried every thing i could think of, so i was hoping some one could help.
FlyHigh rzr's is offline   Reply With Quote
Old December 23rd, 2008, 04:35 PM   #2
Make It Happen!
Gerard's Avatar
First Name: Gerard
My RZR: 2008 RNP Intake, Fuel Controller and Exhaust
Member #5640
View Gerard's Photo Gallery(0)
Re: Rzr Wont Start!?!
You need to give us more info. What have you already tried? Is the gas tank empty, if your relying on the gauge maybe its broke, take off the gas cap (if you haven't already) and look inside. List everything you have tried.
Gerard is offline   Reply With Quote
Old December 23rd, 2008, 04:36 PM   #3
Feedback Score: 19 reviews
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
Crank, Spark, Fuel. You have crank.
What do you have and what don't you have.
When you key up do you hear the fuel pump run for a couple seconds?
Have you unplugged and replugged connectors?
Have you checked your battery for good tight connections
and the chassis grounds?
Check your fuel box for blown fuses.
Did you add some fuel for laughs and giggles?
Check your air filter?
There are some starting points, OK?
quadnkev is offline   Reply With Quote
Old December 23rd, 2008, 06:11 PM   #4
parks688's Avatar
My RZR: 900xp
Member #2173
View parks688's Photo Gallery(0)
check and see if feul filter is clogged. this has happened to a couple of rzrs before. Some plastic from the new tank can clog up the lines. also are you pushing your foot down on the brake peddle when you start?
parks688 is offline   Reply With Quote
Old December 23rd, 2008, 06:15 PM   #5
First Name: Nick
My RZR: 09 rzr s
Member #4775
ok i cchecked and did what u stated above and it all seems to be fine. im thinking it might be the sparkplugs but cant find away to get to them without removing the bed. is there an easyer way.
thanks
Old December 23rd, 2008, 06:16 PM   #6
First Name: Nick
My RZR: 09 rzr s
Member #4775
where is the fuel filter?
Old December 23rd, 2008, 07:29 PM   #7
Stumpduster's Avatar
First Name: Mike #688
My RZR: 16 1000 XP
Member #1676
If you don't have it yet, try here
http://http://www.extremerzr.com/docs/rzrservicemanual/
This is for a 08 but lots of good answers in there!
It's likely something simple, .........foot is on the brake, right?
Stumpduster is offline   Reply With Quote
Old December 23rd, 2008, 07:31 PM   #8
My RZR: 16 1000 XP
Member #1676
I mat be wrong but the only fuel filters I know of are inside the fuel tank and being a week old I'd leave that pain to the dealer!
Old December 23rd, 2008, 07:59 PM   #9
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
That is in the tank, do not go there, that be a dealer thing to do.
You could take a fuel fitting loose to check for fuel flow but that would be getting ahead of the game.
All seems to be fine, state what you did.
I deal with this stuff all the time with students, they did everything and it won't work.
I go over and find the obvious.
You may as well learn to remove the bed, it is your best bet for finding out what is wrong.
Think of it as foreplay, getting into the mood, you will be doing this forever as long as you own this creature.
There are some posts of how to do it but simply having at it will be the best teacher. Takes 10 minutes with a drink, others are faster but nice guys finish last. My wife likes that.
Anyway, after you have removed the bed(hope you do not have a rear bumper on yet) check for spark, have a tester? No? Just hold the boot to engine metal=ground and crank, got spark? Y?N? If N,remember those connectors to check... follow back to the coils and do that open and shut thing to them. If Y pull a plug and see if it is wet and soggy or really black, clean them if so, but before putting them back in blow out the cylinders first with compressed air. This is so you avoid having someone throw water on your fire as you put a match to it. Don't really mean to be a jerk as I go through these machinations, like I said I deal with students and this is how it goes. Fine put back the plugs and give it a rip.
No again? Now take a connector off of a fuel injector and with a test light to ground check for one the wires being 12 positve the light will glow if so. IF not check the fuse box ECM fuse or fuel pump, actually check them all. Then place the test light lead on one wire and the other end on the other wire and crank the motor it may be a glow and off, not real bright, but blinking, noid lights are best otherwise a #194 bulb from you car will work too(dashlight or such,cig ashray bulb).
Don't get to carried away doing stuff or the Dealer may say you caused the problem,keep that in mind.
Sorry if this came off as talking down too, not meant to be, just having a bit of fun along the way.
Good Luck, Hope you get it going.
08 rzr wont start
polaris 900xp cranks but wont start
polaris razer wont crank no spark or fuel injectors not working
polaris razr wont crank after getting wet
polaris rzr has spark and fuel but wont start
polaris rzr will turn over but wont start
polaris rzr wont start
polaris rzr wont start after
polaris rzr wont start after being washed
rzr 570 getting wet
rzr 570 turns but does not start
rzr 570 wont idle
rzr wont start
rzrs fuel ok no spark
washed rzr570 now wont go 5 mph
Engine wont start jonny_jard Engine and Drivetrain 8 October 13th, 2012 07:16 AM
Clunk at the start in H! Bruce General RZR Discussion 10 September 17th, 2010 06:00 PM
Be sure and replace plugs if engine wont idle slc1lxn General RZR Discussion 1 August 26th, 2008 11:12 AM
4wd wont engage sometimes baja_hammer01 General RZR Discussion 8 May 21st, 2008 03:30 PM
It's a start LTRZR Projects and How-To 14 January 9th, 2008 08:34 PM
