This is a discussion on turbo rzr 0-60 times within the General RZR Discussion forums, part of the General RZR category; I tested my rzr with a vericom 2000 and a g-tech accelerometer to get a 0-60 of 6 seconds flat. I have the mcx turbo ...
I tested my rzr with a vericom 2000 and a g-tech accelerometer to get a 0-60 of 6 seconds flat. I have the mcx turbo running 11.5 psi of boost stacked with the mountain performance box. I dont know the weight but I know this rzr is pretty heavy. It is equipped with 4" long travel, a stereo, optima battery, prp suspension seats, front and rear winshield, and 4 fuego hid lights with there modular lightbar on top. I tested a stock rzr with the same device and it ran 0-60 in 13 sec.
| Sponsored Links | ||
Re: turbo rzr 0-60 times
Wow you cut the time to less than half of stock! Was the stock rzr loaded with accessories or pretty much bone stock. That is a serious improvement. Also running that high on the boost what type of fuel are you running.
Good info jlprince.
I wonder why turbo manufacturers don't advertise this type of info? Do you have any 0 to 30 times or 0 to 40? Thats the power range I am interested in for climbing the dunes...
______________________________________ My Links: Polaris Parts Microfiche , FREE DOWNLOADS , How to change a RZR clutch belt VIDEO |
Jlp, thanks for the info, I'm also running the MXC but with 15#.
With 91 octane for someone who asked. What belt are you running? What surface are you making the runs on? I mostly run the sand and find 4X4 to be the fastest. Do you mash it from a standing start or allow a few feet for the clutch to spool up. Are you running the 80+ weights that come with the turbo kit? Just interested, But I'm not sure a bit of weight makes much difference with power we produce, John |
With 91 octane for someone who asked. What belt are you running? What surface are you making the runs on? I mostly run the sand and find 4X4 to be the fastest. Do you mash it from a standing start or allow a few feet for the clutch to spool up. Are you running the 80+ weights that come with the turbo kit? Just interested, But I'm not sure a bit of weight makes much difference with power we produce, John If you run an AFR gauge hit the brake pedal and give some gas until you see on the gauge 0 or a bit more and let it go. Better tha smash the gas pedal, day an night difference Edit: Forgot to mention that I change both clutch springs Last edited by Dogo X; December 17th, 2008 at 08:24 AM. |
Nice info...
Chris |
#11
60 is really close to the top end, especially stock.
A 0-40 MPH speed would be MUCH more useful when comparing stock to aftermarket. That, and "most" people "most" places hardly ever have a chance to hit 60MPH, unless you're on the dunes...
-I may not be the fastest... but I'll be damned if I'm the slowest! -I make up for power, by adding stickers and flashing lights. |
#12
I think 0-60 is a very good test, because a stock one will do it on pavement no problem. Load it in the sand, and that's a different story. I think a 0-40 would also be a good test, but in all honesty the best test is putting a load on it and running it up a long steep hill. That's where it really shines.
Chris |
#13
Chris 0-40 might only take 4 seconds, while that last 20mph to 60 may take another 6 seconds... making the 0-60 10 seconds which isn't very useful. I'm sure we've all felt the low end even bone stock... 40 comes in a flash!
#14
All the testing was done on pavement. The stock rzr has stock a arms with a polaris brushguard and stereo. Definately lighter than mine. I am running EPI belt with the weights that came with the turbo kit. The mountain performance box helped alot because on launch it was hitting rev limiter BAD. You have to talk to trey about tuning with this box.
#15
If you reach the rev limiter fast means too much boost for your clutch set up (simple) i have mess around with mine a lot and if your clutch is not set property or you AFR is in correct your up to issues. Period :
| Visitors found this page by searching for these keywords: |
Rzr s 0-60 time |
| Thread Tools | |
| Display Modes | |
| TURBO RZR owners post your speed/times here! | Tuf-Skin | Forced Induction | 27 | July 11th, 2009 11:06 PM |
| 100 Ft. Times | Shelby-Gt-500 | General RZR Discussion | 8 | January 22nd, 2009 05:09 PM |
| Relocating the turbo on a TSI Turbo kit (Pics) | zrated | Engine and Drivetrain | 12 | August 25th, 2008 10:52 AM |
| Let the good times roll | Johnny | UTV Inc | 7 | June 16th, 2008 09:06 AM |
| Broken EPI belt ... rolled it three times over | twvette | General RZR Discussion | 7 | April 17th, 2008 03:44 AM |
