Brake pressure switch - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old February 13th, 2012, 08:39 PM Thread Starter
rorhound's Avatar
Anyone ever change one? The part number said it included sealent. I'm assumming it unscrews, apply the sealent and screw it back in. Then bleed the brakes.
If no replies, I'll let you all know what happened when the part arrives.
2013 WE XP, Alba BB & Stage II, Pro Armor Cage, Doors, Door bags, Harnesses & Steering Wheel, HRD Racing True Suspension Seats.
2012 27'CBG Attitude
2008 GMC 2500 Duramax
rorhound is offline
post #2 of 8 Old February 13th, 2012, 08:47 PM
King of crash!
Send a message via Yahoo to johnnycat8
Re: Brake pressure switch
if any it will be on the threads allready if not..dont aply anything it could get in the system... just tighten it.
johnnycat8 is offline
post #3 of 8 Old February 23rd, 2012, 07:56 AM Thread Starter
rorhound's Avatar
Got the new switch. Took the old one off (un-screwed out of junction block). Put some teflon tape on the threads and tightened it up. The terminals on the top were different than the stocker. I modified some electrical connectors to go between the switch and the female plug. Everything works great now. The only air in the system is the little pocket in the switch. After I drive it for a bit I'll bleed the brakes. Not sure how the fluid would push that air out right now. I'll wait for the mush in the pedal then do it.
rorhound is offline
post #4 of 8 Old February 23rd, 2012, 09:47 AM
N0OSV's Avatar
Rzr Icon Re: Brake pressure switch
Lossen the switch a little. Maybe an 1/8 of a turn. Press the brake pedal and hold. Some fluid should come out around the threads of the switch. Tighten the switch before releasing the brake pedal. Again, tighten the switch before releasing the brake pedal. If you don't you will draw air into the system. This should save you from a total brake system bleed.
N0OSV is offline
post #5 of 8 Old February 22nd, 2013, 04:51 AM
Workhardplayhard's Avatar
Anyone know where the brake pressure switch is located on an 11 standard rzr
Have to jump my solenoid with a screwdriver, but not sure if its the solenoid or this switch. Hear it is under the seat but dont see it
Workhardplayhard is offline
post #6 of 8 Old February 22nd, 2013, 04:56 AM
Balls Out sXs's
RzRolloverKing's Avatar
Should be on the inside of the driver side frame rail just in front of the shifter linkage. Check it to see if a mud ball or stick knocked it loose. Had the same problem, pushed it back on and problem fixed.
RzRolloverKing is offline
post #7 of 8 Old November 28th, 2013, 10:59 PM
flynhi757's Avatar
Anyone have the part number for the top connector piece that slides on the emer brake start?? Mine wont make a good tight connection anymore and The mud has really worn the tabs . Thanks
flynhi757 is offline
post #8 of 8 Old December 5th, 2013, 06:09 PM
JimGz's Avatar
Mine is acting up... What's the local dealer price on the switch? Looks like about $14 online if it's the right one...
Tusk Hydraulic Brake Switch Nissin Brakes | Dirt Bike | Rocky Mountain ATV/MC
2012 XP900, 14" SS212/26" Maxxis Bighorns, EMP windshield, L&R roof, custom painted PA doors, front and rear bumpers, rock sliders, winch w/synthetic line, dual batteries, custom JBL stereo, & EZSteer!
JimGz is offline
Disabling the Foot Brake Start Switch Overlord Engine and Drivetrain 29 January 11th, 2015 09:00 PM
Brake Switch rorhound Lighting, Stereo and Electrical 4 June 23rd, 2014 11:15 PM
Polaris RZR 800 WTB rear left brake caliper and brake line andyrzr Polaris RZR Parts For Sale 3 June 7th, 2011 11:22 PM
Need: 4 wheel drive switch and headlight switch for pre 2011 RZR RZR4Crew Want to Buy 4 January 25th, 2011 10:07 PM
Foot Pedal e-brake or Line Lock e-brake RZRider General RZR Discussion 10 December 12th, 2009 09:04 PM
