battery light flashing-- New battery and light still flashes - Polaris RZR Forum - RZR Forums.net
post #1 of 14 Old January 15th, 2012, 06:17 AM Thread Starter
shanksyamaha's Avatar
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
View shanksyamaha's Photo Gallery(0)
My battery light flashed from time to time for the last 1/2 of last season but the machine always started fine and seamed fine other than the lights would dim slightly when at idle but I figured that was normal. It always seamed the battery light would flash when I was riding, esp. under hard acceleration when the battery should be charging the best, but rarely did it flash at idle when I would think it would not generate as much power.
I Parked the machine for a month or so and went to get it out of the shed and battery was completely flat. Won't even register when I put it on my optimate 3. So I bought a new battery from a local atv shop, they said they have had great luck with these batteries. I put it in and seamed fine but after a few minutes riding around the yard, the battery light started flashing again, only for a few seconds then stopped, then started again a little while later.. The machine seams to start fine and the battery is new and strong..
What else could be going on here??
2009 RZR-s 800: full skids front to back, bumper, 3500lbs winch, tunes, rock sliders, FMF pipe, clutch kit
2006 Yamaha Apex RTX with G-Force supercharger. 180hp trail sled that loves the frozen lakes..
2004 Polaris XC 700 SP with some moderate tweeks, wifes sled that outruns most of my buddies sleds, love it...
shanksyamaha is offline
post #2 of 14 Old January 15th, 2012, 07:14 AM
ride guide extrodanire
rzrwrecker's Avatar
First Name: Skeeter
My RZR: High Lifter Edtion
Member #614
View rzrwrecker's Photo Gallery(0)
Re: battery light flashing-- New battery and light still flashes
mabe the charging system is workin correctly
rzrwrecker is offline
post #3 of 14 Old January 15th, 2012, 07:24 AM
gtmcgeejr's Avatar
Member #2498
View gtmcgeejr's Photo Gallery(0)
Running hot!
gtmcgeejr is offline
post #4 of 14 Old January 15th, 2012, 07:25 AM Thread Starter
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
would a stator work like this, produce some power but not enough??
post #5 of 14 Old January 15th, 2012, 07:32 AM Thread Starter
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
Originally Posted by gtmcgeejr View Post
Running hot!
Alot of times it comes on within 5 minutes of starting the machine and I never get a temp light or any sign that the motor is hot
post #6 of 14 Old January 15th, 2012, 07:39 AM
truggyboy's Avatar
First Name: Rick
My RZR: 2010 RZR-S orange madness le
Member #7737
View truggyboy's Photo Gallery(0)
Sounds to me like the charging system isn't charging enough volts/amps. I see this all the time in the automotive world. Should take to someone that knows how to test the charging system properly.
truggyboy is offline
post #7 of 14 Old January 15th, 2012, 08:26 AM
socalrzr's Avatar
My RZR: 08 RZR
Member #2960
View socalrzr's Photo Gallery(0)
Voltage regulator might be going bad as well.
08 RZR, Mafia 6+ LT, Fox 2.0 shocks with remote reservoir, Eibach Springs, UMP intake, Eagle Eye HID's, PRP seats, PRP 5-point harness, PCI race radio and intercom, Odyssey 925L, white maier plastics, Latest Concepts and Designs cage with roof and doors,
socalrzr is offline
post #8 of 14 Old January 15th, 2012, 08:29 AM
Etced's Avatar
My RZR: 2012 RZR 570
Member #15200
View Etced's Photo Gallery(0)
Check your grounds.
Etced is offline
post #9 of 14 Old January 15th, 2012, 08:36 AM Thread Starter
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
Originally Posted by Etced View Post
Check your grounds.
I have some mechanical ability but my electrical skills are limited. Where do I start checking grounds and what am I looking for??? If I have to I'll take it to the dealer and have them test the charging system but at $80/hr I'd rather do everything I can in my garage...
Thanks guys.. This site is a HUGE HELP!!
post #10 of 14 Old January 15th, 2012, 09:36 AM
1969shyden's Avatar
First Name: Steve
My RZR: 2009 camo
Member #33099
View 1969shyden's Photo Gallery(0)
Put a volt meter on the battery then start it up.check the volts with it running should be well above 12.now turn on all of the lights and what ever you have,keeping a eye on the volt meter give it some gas and see if the volt meter goes up.
1969shyden is offline
post #11 of 14 Old January 15th, 2012, 09:42 AM
tkmayes's Avatar
First Name: tkmayes
My RZR: 2011 S LE Black
Member #21372
View tkmayes's Photo Gallery(5)
AFTER cleaning your battery cables. That means bright and shiny on mating surfaces and yes they can look good but be dirty so you must take them off and brush them shiney. Borrow a quality voltmeter and measure battery voltage at the battery with engine at idle, engine at high rpm, engine at idle with headlights on bright and engine at high rpm wiht headlights on bright. not a complete test but might give us a clue as to what is going on. Charging system should be able to maintain battery voltage at idle 13.6 to 14.2. Engine not running should be 12.5 to 13.6. voltage may drop below 13.6 when idling whith lights on but should increase to above 13.6 at high idle. Poor boy diagnosis but works most of hte time.
tkmayes is offline
post #12 of 14 Old January 15th, 2012, 09:50 AM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
Also check you wires in the harness and regulator they break sometimes and will cut your voltage down. Johnnycat had this problem and he found the wires when he rebuilt the rzr.
crazywatson is offline
post #13 of 14 Old January 15th, 2012, 10:57 AM
"Dual Primed!"
desertvet1990's Avatar
First Name: Rick
Member #15483
Feedback Score: 11 reviews
There are grounds to the frame as well. Someone here posted that his ground to the frame was stripped out and had to re-bolt it. Might check that as well
Land of the Free,, Because of the Brave!!Freedom is'nt free,, I Payed for it!
Shock Therapy Springs
GET FULL COVERAGE INSURANCE!! DONT take the chance!!
desertvet1990 is offline
post #14 of 14 Old January 15th, 2012, 11:59 AM Thread Starter
First Name: Nick
My RZR: 2009 RZR-s
Member #26059
Thanks for all the help guys.. I have a couple days off this week so I'll be working on it then..
battery light on ??? sgracing General RZR Discussion 5 May 22nd, 2011 05:31 PM
battery light flashes, (at times) richcrook Lighting, Stereo and Electrical 7 October 17th, 2010 10:22 AM
Battery light on Dankfx450r Forum Help, Questions and Info 4 July 23rd, 2010 10:06 AM
battery light dirt General RZR Discussion 3 November 30th, 2008 05:29 PM
Battery Light jayman69 General RZR Discussion 7 July 24th, 2008 08:06 PM
