Leaking radiator fluid again... - Polaris RZR Forum - RZR Forums.net
This is a discussion on Leaking radiator fluid again... within the General RZR Discussion forums, part of the General RZR category; Bought 2011 RZR and started leaking anti freeze on second ride. Dealer came and picked up and replaced radiator. I only have 11 hours on ...
Old November 11th, 2011, 09:40 AM   #1
Bull Hog Grande's Avatar
Member #24879
View Bull Hog Grande's Photo Gallery(0)
Bought 2011 RZR and started leaking anti freeze on second ride. Dealer came and picked up and replaced radiator. I only have 11 hours on it since April and just climbed out of it and its leaking radiator fluid again. I cant find a leak and the connections are all good. I know alot of people have had this issue. When it leaks its not alot, it no more than a 1/4 cup. It looks like its just overflow. Does anyone have any information on this ? What is wrong recall etc ??
Bull Hog Grande is offline   Reply With Quote
Old November 12th, 2011, 08:51 AM   #2
Feedback Score: 4 reviews
RWTDCT's Avatar
First Name: Robert
My RZR: 2014 XP4 1000 - Titanium
Member #21382
View RWTDCT's Photo Gallery(15)
Re: Leaking radiator fluid again...
I have the rzr 4. After approx 15 to 20 hrs. I inspected the whole rzr from top to bottom side to side. I took the under belly off (skid plate) I noticed two places where the coolant was leaking. There is a metal pipe with rubber hoses in a couple sections with hose clamps that runs from your radiator to the motor. All I needed to do was tighten down the clamps, it cured the problem.
Not sure if your might have same problem, but a place to start.
RWTDCT is offline   Reply With Quote
Old November 12th, 2011, 09:33 AM   #3
Waistdeep's Avatar
My RZR: 2011 RZR Camo
Member #18687
View Waistdeep's Photo Gallery(0)
i had the same thing happen on mine, seemed like it was either overflowing or coming from the connections right at the rad. After the 3rd time to the dealer they were able to sort it out and corrected the problem. No issues now - oh yea, other than the water pump seal that leaked oil over the bottom of the motor. they said that was due to a pitted water impellar, fixed that and now no problems
Waistdeep is offline   Reply With Quote
Old November 12th, 2011, 09:33 AM   #4
2011 RZR 800's Avatar
First Name: Kerry
My RZR: 2011 800 RZR 50
Member #23427
mine had a leak right where the lines start under the body and all i did was tighten the clamps up then went through all of them and tighten them up,also system might just need to be burped if it's coming from over flow.
2011 RZR 800 is offline   Reply With Quote
Old November 12th, 2011, 11:16 AM   #5
Member #24879
Thanks guys. I refilled the resevoir and took for a.ride. Dripped a little bit again. I just sent the thing to the dealer for first oil/fluid change. First ride back it started.
08 polaris rzr leaking coolant out of overflow
cf moto
cf moto z6 radiator fluid is leaking from a vent in motor hose routing water pump
coolant leaking from overflow hose polaris
ducati 1098 leaking radiator fluid overflow pipe
polaris razor leaking tramsisson fluid by overflow hose
polaris rzr 2010 leaking radiator tube
polaris rzr leaking ani freeze
polaris rzr radiator hose leak
polaris rzr radiator overflow hose routing
purple fluid leaking from polaris rzr
radiator leak polaris razor
replace radiator on polaris rzr
type of radiator fluid in rzr
why is my rm85 leaking antifreeze
crap....im leaking transmission fluid. help! evilking General RZR Discussion 8 March 14th, 2012 07:10 AM
Purple tinted fluid leaking bonny RZR XP 900 6 April 24th, 2011 08:09 PM
2 rzr "s"s leaking tranfer case fluid!! razrface RZR-S Specific Discussion 3 April 24th, 2010 09:44 AM
why is my radiator overflo leaking pawngod Engine and Drivetrain 10 March 22nd, 2010 09:46 PM
Transmission Vent leaking fluid - Normal? 2fiftyR Engine and Drivetrain 2 October 7th, 2009 07:01 PM
