Loading my RZR plus hauling my Travel Trailer
This is a discussion on Loading my RZR plus hauling my Travel Trailer within the General RZR Discussion forums, part of the General RZR category; I have a 2005 GMC ext cab, I do believe the box is 6' 5". Anyways, wondering if there is anything around the site showing ...
Old November 7th, 2011, 05:51 PM
reacon's Avatar
First Name: Bryan
My RZR: 2009
Member #16465
View reacon's Photo Gallery(0)
I have a 2005 GMC ext cab, I do believe the box is 6' 5". Anyways, wondering if there is anything around the site showing loading the RZR plus being able to hook up the the travel trailer. If I left the tailgate down would never be able to hook up the trailer. Now if there was a way, that would be the best vacation one could ask for.
Thanks,
Bryan.
Old November 7th, 2011, 06:32 PM
Dunerocket's Avatar
First Name: Don
My RZR: 2011 OM LE
Member #15059
View Dunerocket's Photo Gallery(0)
Re: Loading my RZR plus hauling my Travel Trailer
You might look into the hitch extensions. they use them when you have a full size camper in the truck. It moves the reciever farther back. Torklift.com I think is the website.
Old November 7th, 2011, 06:40 PM
Impaired's Avatar
Member #30496
View Impaired's Photo Gallery(0)
I think the need to ask simply weeds out the ones who shouldn't.
Old November 7th, 2011, 07:20 PM
Wildman4x4nut's Avatar
First Name: Rick
Member #30057
View Wildman4x4nut's Photo Gallery(0)
Well the FIRST question is how much does your trailer weigh? Any mods to your RZR? If it will fit into your bed then you only issue is the tounge on your trailer. And as some have stated you can get a extender for your hitch. But that come back to how much does your trailer weigh? The standard ones aren't good for over 5,000lbs. There are ones on the market that will offer higher load capacity but they cost more. But if you want to be safe when you tow they are worth it.
Old November 8th, 2011, 09:16 AM
Cliff Clavin's Avatar
Member #19936
View Cliff Clavin's Photo Gallery(0)
I went to the website and here is the link....
Torklift.com | Home of Torklift International
not sure on pricing but it doesn't look cheap.....You must have a relatively light trailer as you lose much capacity using extensions....However for some it looks like a great option.....
I have a 24" extension I bought at Princess Auto that I use for a snowmobile trailer.....It allows me to have my gate down and still hook up my sled trailer.....my trailer is pretty light, under 2000lbs loaded with two quads or two snowmachines....
Old November 8th, 2011, 03:02 PM
Desert Drifter's Avatar
My RZR: 2012 Standard 800
Member #18974
View Desert Drifter's Photo Gallery(0)
It can be done. But it is going to cost you!!!!
I have the TorkLift Super Hitch rated at 1700 tongue weight and 17000 pull weight. My 21 " extension which is a dual beam Super Truss de-rates the hitch to 750 tongue and 7500 pull. My trailer is 600/6000 so I'm well within limits.
JANE CALL HOME - 1 800 HANOI
Old November 8th, 2011, 03:35 PM
07fj's Avatar
My RZR: XP9
Member #561
View 07fj's Photo Gallery(0)
put a drive on rack in the bed for the rzr , then tow normally.
XP9, Stock Roof, POPO steering wheel, POPO cover, TS Vortex seats and Crow belts. XP L-n-R box, Rigid D2 Leds lights, RZR Wraps
  #8
Old November 8th, 2011, 03:39 PM
Dirtslinger76's Avatar
First Name: Justin
My RZR: 09 Nuclear Sunset Orange
Member #24482
View Dirtslinger76's Photo Gallery(0)
Buy a toy hauler.........i am selling mine!!
  #9
Old November 8th, 2011, 03:41 PM
FunRZR's Avatar
First Name: Bill
Member #22083
View FunRZR's Photo Gallery(0)
I'm sure you are aware of this but if you aren't your weight distribution would be greatly improved by caring your RZR in your bed backwards
2005 Polaris Sportsman 800
2008 Polaris Ranger RZR
2009 Polaris Sportsman 850XP
2009 Polaris Ranger RZR
2010 Polaris Sportsman 550
  #10
Old November 8th, 2011, 04:29 PM
SomeGuyFromOlympia's Avatar
SomeGuyFromOlympia
First Name: Kyle
My RZR: 2010 RZR-S
Member #10618
View SomeGuyFromOlympia's Photo Gallery(0)
When you get older, you will learn the term 'I don't know' is the sign of a higher than average person on the thinking scale
The guy is just asking for help from a bunch of people that have probably alread done what he is trying to do
....and as you can see he has alread gotten some answers to his question
Rogue Fabrication
Cage
Nerf Bars
Bumpers
Seat Brackets
  #11
Old November 8th, 2011, 05:14 PM
First Name: Rick
Member #30057
This is the right way to do this job and as DD said it ain't cheap but it is SAFE.
  #12
Old November 8th, 2011, 05:33 PM
SomeGuyFromOlympia
First Name: Kyle
My RZR: 2010 RZR-S
Member #10618
I'd go the rack rout if you could get away with it
...keep your hitch short
Rogue Fabrication
Cage
Nerf Bars
Bumpers
Seat Brackets
  #13
Old November 8th, 2011, 06:17 PM
First Name: Rick
Member #30057
SGFO,
On a shortbed truck isn't the rack going to still have to be 8' long for the RZR to fit? So all your doing is move the turn point from the tail gate to the rack. Either could hit the trailer if it isn't moved back enough. I might not be looking at this right but that is my thought.
  #14
Old November 8th, 2011, 06:45 PM
bigbore's Avatar
First Name: Dave
My RZR: RZR S Weber Turbo
Member #14010
View bigbore's Photo Gallery(0)
I run a F250 with 6 3/4 bed and haul my RZR S and a 28ft TT that weighs 8000lbs loaded. I have a Hensley Hitch and the optional 7" longer hitch insert. Occationally the tailgate will hit the torstion towers on the camper hitch set up. I wish the extension was 3" longer. After 2 years of running this set up, next time I will get a truck with an 8' bed and I will add rear air bags to level the load. Load is Ok when running one or the other, but together I have to deal with 4-5" of sag.
  #15
Old November 9th, 2011, 01:46 PM
reacon's Avatar
First Name: Bryan
My RZR: 2009
Member #16465
All good comments...I can see why this is a top rated site for anyone wanting info on RZR's plus towing them. Being retired gives a bit of time trying to figure things out. Everyone here has been a great help. Wife and I are an older couple enjoying our new toy and exploring the countryside. When I first looked to the RZR, hmmm this is for the younger folk, NO WAY. Let them RZR,s fly. Our Trailer is a 26' Jayco, 5600 GVW, I will come up with a way to tow both the RZR and The Trailer.
Thanks Again,
Bryan
2003 Honda 450s
2009 Polairs RZR
best camping trailer for rzr-s
haul rzr and travel trailer solutions
haul two utvs on a trailer
hauling 3 polaris rzr
hauling a rzr
hauling atv in f250
hauling polaris rzr
hauling polaris rzr truck
hauling rzr in pickup
hauling travel trailer with tail gate down
hauling utv in pickup and extending tailgate for chevy colorado
how can i haul my rzr and my trailer
my polaris rzr trailer
polaris razor on diamond back cover
rzr hauling
tow travel trailer with atv in bed of truck
truck bed rzr travel trailer
what kind of trailer should i buy to haul my polaris utv
what size trailer is needed for hauling the rzr 570
what size trailer would you need tohaul 570 polaris razor
pulling travel trailer while hauling rzr bull General RZR Discussion 10 September 21st, 2011 06:40 PM
loading the rzr onto trailer whiteeye42 General RZR Discussion 39 August 9th, 2011 03:06 PM
Trailer Loading Question Ozy RZR XP 900 18 April 8th, 2011 09:53 PM
Compressing suspension for trailer loading Bobholthaus Suspension 6 March 21st, 2011 10:29 AM
Careful When Loading on your Trailer Wingpilot General RZR Discussion 16 October 3rd, 2010 05:12 AM
