cleaning up Lexan windshields - Polaris RZR Forum - RZR Forums.net
post #1 of 21 Old October 18th, 2011, 07:13 PM Thread Starter
roadranger's Avatar
I've got a Lexan windshield that I try to take care of by NOT dry wiping dirt/dust off of it, instead using a wet terrycloth bath towel to lightly wipe with.
STILL get vey small "swirly" scratches on it - not too bad to look thru unless driving into the sun. Then it like clouds over from all the tiny scratches.
What will fix this problem??
Some say Pledge will clean it up, anybody know?
I've also seen headlight cover cleaner that supposedly gets yellowing out and polishes the plastic, anybody tried this?
Any suggestions welcome!
Jim B.
Colorado Springs
2011 RZR LE EPS 'Orange Crush' 54 in. wide
Power Steering, Grim Reaper 26x10's all 4, Black Rock Revo wheels, Polaris brush guard, Cooter Brown roof, UTV fold down windshield,
Tusk UHMW skid , Viper Max 3500 winch, Irate SS grille, RacerTech front springs, RacerTech 2" lift, KirksCreation Pbrake
roadranger is offline
post #2 of 21 Old October 18th, 2011, 07:21 PM
hdd-max's Avatar
Re: cleaning up Lexan windshields
Is your windshield not MR-10? My widshield does not scratch dry wipe or not
2011 XP900 LE
hdd-max is offline
post #3 of 21 Old October 18th, 2011, 07:27 PM
UTVFrank's Avatar
yea MR10 is the only way to go. I clean my with a regulat towel.
UTVFrank is offline
post #4 of 21 Old October 18th, 2011, 08:27 PM
VirtualRider's Avatar
I have the EMP Lexan Windshield. It too, is scratching. I didn't think Lexan would do that. Disappointed. There's no way to not scratch these things, if they are that soft.
VirtualRider is offline
post #5 of 21 Old October 18th, 2011, 08:51 PM
AKA: blinginvic
Feedback Score: 6 reviews
bilinvic's Avatar
You have a few options:
1. Novus Plastic Polish NOVUS Plastic Polish
2. Regular car wax if the scratches are minor
3. Special sandpaper that steps up to 12000 grit. They are used for aircraft glass/canopies. MICRO-SURFACE FINISHING PRODUCTS, INC
2009 RZR 800 LE (Stealth Black)
2009 RZR 170 - For Sale
My RZR Website: http://members.shaw.ca/bilinvicRZR/R...invic_Home.htm
bilinvic is offline
post #6 of 21 Old October 18th, 2011, 09:09 PM
Banned
itsruf's Avatar
Originally Posted by roadranger View Post
....Some say Pledge will clean it up, anybody know?....
Pledge?, baloney. you need a buffer. You would be hand rubbing for a month!
....What will fix this problem??......
Sir we "buff out" poly faces regularly. generally old polycarbonate sign faces that must be re-used and have old psa (pressure sensitive adhesive) that someone scraped off and scratched the heck out of. (see photo from last week) We use an electric buffer and various automotive buffing compounds including a final plastic polish. You can get out deep scratches from poly. The pan faces in the photo are about $400 apiece wholesale so yes we re-use often. That customer had (2) to re-finish. It is 12' in the air so Finesse-it was good enough and quite professional.
In a nutshell your clear windshield can be buffed out by someone who is pretty good at it but you need the pads, polishes, and buffer, and time.
But the old rule holds. You never clean your eyeglasses with a paper towel you use a cotton cloth. Paper is wood. It scratches.
Most headlamps are still a GE polycarbonate derivative and most likely that product is a plastic polish. Either use a buffer lightly or one heck of a lot of elbow grease. The stuff probably works.
ID:	38016   Click image for larger version
ID:	38019   Click image for larger version
itsruf is offline
post #7 of 21 Old October 19th, 2011, 09:46 AM
Feedback Score: 16 reviews
guy48065's Avatar
The wax in Pledge will fill in fine swirls and improve clarity a lot--but not entirely. The fine scratches will still refract the sun and makes the whole windshield glow--hard to see through that when the sun is at the right angle. The wax also offers some protection against more scratches.
guy48065 is offline
post #8 of 21 Old October 19th, 2011, 09:54 AM
Countryboy's Avatar
Try warming the lexan with a heat gun, most of the time this will completely clean up the surfaces and takes minutes to do. Just be very careful not to melt it, but pretty hot all the same.
Countryboy is offline
post #9 of 21 Old October 19th, 2011, 10:06 AM
olddognewtrick's Avatar
Here is a site with polish kits-
Auto Glass Repair - Car Windshield Crack, Scratch Repair - Plastic Repair, Polishing Kits
I've read where folks are shining up their head light covers with colgate tooth paste, don't know if that would work on your W/S but you could test it on a small area.
2011 Pursuit Camo
olddognewtrick is offline
post #10 of 21 Old October 19th, 2011, 10:17 AM
dmax61's Avatar
what is the polaris 1/2 windscreen made of? and will these above mentioned polish and buffing work on it
dmax61 is offline
post #11 of 21 Old October 19th, 2011, 10:19 AM
AKA: blinginvic
bilinvic's Avatar
Plastic is plastic.....the hardness level/coating will determine how much elbow grease goes into polishing.
bilinvic is offline
post #12 of 21 Old October 19th, 2011, 10:20 AM
Banned
itsruf's Avatar
Both good tips.
keep in mind when we buff out we are also removing the "ghost" image burned in by the sun. To some extent our polishes and buffer do an OK job of that. Most go well, and some don't. The plastics vary greatly.
if you are good at buffing a car finish you will probably do well at trying the windshield. Automotive paint and clearcoat is in effect plastic that in theory never fully dries.
I will try the heat gun tip next time. Some of our signs at eye level. The plastic substrates are not always back-lit. Some times its flat against the wall with routed letters. They need to be darn good.
itsruf is offline
post #13 of 21 Old October 19th, 2011, 04:00 PM
birdrl's Avatar
Great thread, I have a EMP lexon windshield that is scratched bad.
Been thinking about the heat gun trick. It works pretty good on scratches on the red body panel, but you do have to be very careful and go slow.
I think I will invest in a buffer, any recommendations?
Roger
birdrl is offline
post #14 of 21 Old October 19th, 2011, 05:39 PM
Mr. Impulse
Mr. Impulse's Avatar
Ok, I know i will get alot of " are you nuts???" but here is something to try. I use black magic tire shine in a pump bottle, and it is amazing what it does for a milky windshield with light scratches. The difference is night and day, and will make it almost glass clear and when you wipe it off, it is squeaky, not greasy at all. I am actually using it on my entire rzr now, but I used to use it in my race shield back in the go kart days. Don't knock it till you try it LOL, and I assure you it does not effect the lexan' at all.
Mr. Impulse is offline
post #15 of 21 Old October 19th, 2011, 05:56 PM
jlb27537's Avatar
Location: Texas in Winter and somewhere cool in summer.
Any good plastic polish will work. Available at better motorcycle shops. Or what I used on my motorcycle helmet face shields, Turtle Wax. The old green liquid stuff. Just enough abrasive to take out the scratches.
Jim
jlb27537 is offline
How do you bend Lexan? MossLager General RZR Discussion 8 May 20th, 2010 04:20 AM
New RZR Shorty Lexan Windshield flip Polaris RZR Parts For Sale 0 April 9th, 2010 04:11 PM
Full Lexan Windshield flip Polaris RZR Parts For Sale 0 January 17th, 2010 10:36 AM
Lexan deflectors rimfire General RZR Discussion 2 February 4th, 2008 07:39 AM
