Hard to Start when Warm - Page 7 - Polaris RZR Forum - RZR Forums.net
post #91 of 519 Old March 15th, 2012, 07:16 PM
slider_buck's Avatar
Re: Hard to Start when Warm
Originally Posted by New570RZR View Post
This used to happen a lot to older fuel injected cars. There is a one way valve on the fuel pump or line that keeps pressure in the fuel line when the engine is shut off. If the valve goes bad the engine vapor locks, and you either have to crank the heck out of it or hold the pedal to the floor to get it to start. I don't know if a pressure test after the engine is shut off would help determine if this is the problem. As in- how long does the fuel rail hold the 40lbs of pressure?
yeah but when you first turn the key on the pump runs and builds pressure.
slider_buck is offline
post #92 of 519 Old March 16th, 2012, 10:03 AM
jbeane's Avatar
Originally Posted by 2011 RZR 800 View Post
When this occurs is your fan running and at idle when you shut it off?
doesnt matter on mine. ive tried it both ways. once it does start it runs perfect.
2015 HightLifter XP1K MSA/EFX, S3, Totron, EMP, pro armor
We Sell L.E.D. light bars, MSA Wheels/Tires, S3 lifts, Titan axles, EMP, Pro Armor
jbeane is offline
post #93 of 519 Old March 16th, 2012, 09:23 PM
Ride and be happy!
FiredogRZR4's Avatar
This sounds like a big problem. My RZR 4 just started it and I have read all the post but it looks like no one has really nailed what it is yet. Is there any Polaris Reps on the thread? Have you had any talks with design engineer's?
FiredogRZR4 is offline
post #94 of 519 Old March 17th, 2012, 04:14 AM
jbsharley's Avatar
I have talked to my dealer in Rocky Mount NC. twice and they don't seem to have a clue.
My 50 inch, 2011, 800 has recently started acting up when cold.
I'm concerned the problem is getting worse.
jbsharley is offline
post #95 of 519 Old March 17th, 2012, 04:39 AM
redrzrrider's Avatar
I just want to ad that when I start mine cold it fires up and idles perfectly fine. If I shut it down after a good warm up it fires back up but runs like it's loaded up or maybe running on one cylinder until I hit the throttle and clean it out or it ads fuel and runs on 2! It will some times die prior to cleaning it out but still starts back up without a problem and then runs fine again.
I'm wondering if these machines need a reflash on the ECU??? They seem to be running rich or perhaps lean IMO! I'm going to start letting it idle for at least 1 minute prior to shutting her down and see what the results are.
redrzrrider is offline
post #96 of 519 Old March 17th, 2012, 05:48 AM
Kymedic's Avatar
I always let mine cool off to at least 190 and it does the same thing when warm. Acts like it is loaded up.
Sent from my Desire HD using Tapatalk
Kymedic is offline
post #97 of 519 Old March 17th, 2012, 07:30 AM
HIGHOCTANE's Avatar
I'll throw another possibility out there that I haven't seen mentioned. Leaking injectors...ie leaking fuel(bleeding off rail pressure) into the cylinder after shutdown...I'll say I'd be suprised if were this because of the number of reports but the symptoms fit IMO.
If it really is "loaded up" rich that is..
HIGHOCTANE is offline
post #98 of 519 Old March 17th, 2012, 08:38 AM
jbsharley's Avatar
Checked out two more dealers. One thought maybe dirty throttle body or maybe it needed a leak down test.
The other said throttle position control, but thought it strange that no check engine light ever came on.
All this sounds like money going down the drain.
post #99 of 519 Old March 17th, 2012, 03:39 PM
It did it again today! Ya know, I think it feels more like it's starved for gas. Seems like it fires on 1 cylinder and if it tries to die out and you hit the gas it fires on both. Kind of a sputter until it kicks in. Maybe need to pull the plugs when it happens and see if they are dry or wet but as long as it starts I can live with it! It's a mind puzzler!
post #100 of 519 Old March 17th, 2012, 03:45 PM
Kymedic's Avatar
Mine has done the exact same thing for a while now. Usually on longer rides and after sitting shut off for a few and trying to restart.
Kymedic is offline
post #101 of 519 Old March 17th, 2012, 03:49 PM
roadiestar's Avatar
Mine is the same way. I take it as being a Polaris.
roadiestar is offline
post #102 of 519 Old March 17th, 2012, 05:12 PM Thread Starter
Waistdeep's Avatar
It would be really appreciatedfor the Polaris boys that review these threads would speak up. It is happening to enough people that we should be given some idea where to go for a fix??
Waistdeep is offline
post #103 of 519 Old March 18th, 2012, 04:47 AM
coyotebuster's Avatar
mine started doing this just recently, hard to start after being ran for an hour or so and after doing some reading i think this is a heat related issue at least on mine. so i think i will try to put a heat shield on the lines and possibly something on the injector rail
ill post a couple pics after i get this done
coyotebuster is offline
post #104 of 519 Old March 18th, 2012, 07:24 AM
TennesseeRZR's Avatar
mine just started doing it the last couple rides. from about 350 miles or so. same with his 2011. just in the last couple rides.
thats what baffles me.[/QUOTE]
Are you and your buddy both using fuel from the same source as I'm thinking this problem is probably a vapor lock problem. Oh yea and by the way I've had this going on for quiet so time I've changed plugs, air filter and it's still happening let us know if someone figures it out.
TennesseeRZR is offline
post #105 of 519 Old March 18th, 2012, 08:30 AM
jbsharley's Avatar
I have also changed plugs and air filter. The trouble still remains.
It does seem to get worse as the day grows older.
Hard start? birdmanf250 Engine and Drivetrain 5 October 20th, 2013 12:08 PM
Starts hard when its warm ?? vegastoys4rent RZR 4 Specific Discussion 3 January 18th, 2011 02:54 PM
Hard to start Backfire. DenisonRZR Engine and Drivetrain 2 January 13th, 2011 08:05 AM
need help hard to start weekend warrior Engine and Drivetrain 6 September 13th, 2010 03:23 PM
170 no idle - hard to start Jojano RZR 170 Specific Disccusion 1 January 17th, 2010 01:05 PM
