How do you keep the dust out of the cab???
This is a discussion on How do you keep the dust out of the cab??? within the General RZR Discussion forums, part of the General RZR category; i made my on laid it on a bar put a block on top and bottom thin heated it with a torch to bend it...
  #31
Old November 21st, 2008, 05:35 AM
super s puppy's Avatar
First Name: steven
My RZR: 2008 2gen
Member #3970
View super s puppy's Photo Gallery(0)
Re: How do you keep the dust out of the cab???
  #32
Old November 21st, 2008, 07:37 AM
RZRCRZY's Avatar
My RZR: 2008 Gen 3
Member #839
View RZRCRZY's Photo Gallery(0)
Quote: Originally Posted by jarel View Post
I might be making or purchasing an underdash block-off piece. there is a big gap underneath the dash, where i would think alot of dust/dirt would get thru especially since its where the front wheels are. I'll be seeing this weekend how the half windshield works with all the dust and what not.
I have the underdash block-off with the half windshield and still get a lot of dust in the cab. The underdash block-off helped a little but I still think I am going to try the rear window.
  #33
Old November 21st, 2008, 03:28 PM
andrews08's Avatar
My RZR: 2009
Member #3717
View andrews08's Photo Gallery(0) Send a message via AIM to andrews08
I purchased one from Trail Armor and ended up buying one from Polaris.
Buy the one from Polaris, much easier to install.
  #34
Old November 21st, 2008, 04:01 PM
jarel's Avatar
jarel
My RZR: RZR-S
Member #5075
View jarel's Photo Gallery(0)
Ahhh gotcha. Who makes a rear window? (Sorry if the brand was posted already). But i'll see how the dust is this weekend. Should be pretty dry up at Gorman.
  #35
Old November 21st, 2008, 11:54 PM
andrews08's Avatar
My RZR: 2009
Member #3717
The front window half or whole causes a vortex behind and in the cab...
The dust is BAD. The block off kit helps. There is a rear clear vinyl window from a company called VDP
Vertically Driven Products Wind Stoppers | Rocky Mountain ATV/MC
I am currently working on a complete two piece rear window and hope to have it done by this weekend....
Once done I will post for everyone to see and post where I got all the components. Half Black ABS, Vinyl Plastic seamless piano hinge, and clear acrylic. 3/16 like the factory windows
  #36
Old November 22nd, 2008, 10:11 AM
thekdxkid's Avatar
Member #4354
View thekdxkid's Photo Gallery(0)
Are you talking about the rear window? In another post you say you are making one? Keep us posted as to what you used.....and how it works....
  #37
Old November 22nd, 2008, 11:05 AM
razrface's Avatar
My RZR: rzr s
Member #3663
View razrface's Photo Gallery(0)
i have all that stuff only use it in rain or snow
  #38
Old November 25th, 2008, 12:23 PM
andrews08's Avatar
My RZR: 2009
Member #3717
Here is my HARD rear window
I used ABS plastic for the lower black piece, to avoid scratches from items in the cargo area.
I used Clear Acrylic for the top piece.
I found a piano type plastic hinge that joins the two pieces together.
I will try to find the link for the hinge.
Total cost for parts for the window $85.00
My 14 YR old made a wind deflector that we will be installing this weekend, to keep the dust of the back window. (Simular to what you see on A school bus)
  #39
Old November 25th, 2008, 01:22 PM
NineTNine's Avatar
Member #4347
View NineTNine's Photo Gallery(0)
Ok here is my fix, you could stay outta the dirt and be a bad a$$ street racer or wear some goggles, grow a set and get dirty who cares isn't that why they call it an off road vehicle???
  #40
Old November 25th, 2008, 03:17 PM
andrews08's Avatar
My RZR: 2009
Member #3717
WOW... Just another typical Smart A$$ that has nothing better to do then to try and degrade the people on the forum.
NineTNine.... If you aren't interested in the use of the forum..." How do you keep the dust out of the cab???" Then why be on it?
Why don't you start your own that says " I know everything and I am better then everyone" Or just shut the hell up!!
  #41
Old November 25th, 2008, 03:25 PM
thekdxkid's Avatar
Member #4354
I like your new rear window....but I like your comment even more....hahhaha
  #42
Old November 25th, 2008, 03:53 PM
walbright's Avatar
Alaskan RZR fan
First Name: Wade
My RZR: 2009 RZR LE Sunset Red
Member #4099
View walbright's Photo Gallery(1)
That is a nice setup. Where did you find the plastic piece that joins the two peices of the window? I might have to make this mod as well. Let us know how it handles the dust.
  #43
Old November 25th, 2008, 04:16 PM
andrews08's Avatar
My RZR: 2009
Member #3717
ARCHITECTURAL PRODUCTS 800-835-4400
Is where I ordered the "Hinge" From
I have been trying to find the part number, but can't seem to locate the receipt.
The bottom piece is 11 7/8" Tall
The top is 16 1/2 " Tall
Both pieces are 48" width
I used cardboard to make the bottom template, then slid the hinge on and slid the top window in as you can see in the pictures.
I then traced around the "Cage" to make the raidus etc...
I sort of went excessive on the clamps but I wanted no rattle...
I have run it through a few farm fields here in Idaho and the dust does not swirl back in the cab like it did.
I still get a little from under the seats and working on that next.
with the same material that is used for boat covers...
When I get it done I will post pics also
  #44
Old November 25th, 2008, 04:29 PM
chopperbill's Avatar
Member #443
I have contemplated some sort of wind deflector for my Direction 2 rear window. I would be interested in seeing what your son made up.
  #45
Old November 25th, 2008, 04:37 PM
rjl's Avatar
rjl rjl is offline
First Name: Rick
My RZR: 09
Member #4508
View rjl's Photo Gallery(0)
I went to a local tent and canvas company and had them make a back window out of coverlight vinyl and boat glass , with the 1/2 windshield and block off kit I don't get any dust in the cab now . It straps on like the soft top that Polaris makes . Works great !
Bookmarks
Another on Bites the Dust Floyd27 General RZR Discussion 12 February 6th, 2009 07:56 AM
Still no dust fix guy48065 General RZR Discussion 27 July 25th, 2008 11:53 PM
dust problem crunchman General RZR Discussion 13 July 7th, 2008 04:42 PM
dust rogerpjr General RZR Discussion 7 July 5th, 2008 06:13 PM
dust problems spainrzr Member Introductions 0 May 6th, 2008 09:09 AM
