Problem with UTV Crap frame tubes on RZR S
This is a discussion on Problem with UTV Crap frame tubes on RZR S within the General RZR Discussion forums, part of the General RZR category; The installation of the rear tubes is fine. I found on the front the RZR S frame tubes have a seam on the inside and ...
Old October 18th, 2008, 05:48 PM
Klutch's Avatar
Member #2493
View Klutch's Photo Gallery(0)
Bluduh Problem with UTV Crap frame tubes on RZR S
The installation of the rear tubes is fine. I found on the front the RZR S frame tubes have a seam on the inside and the I.D. of the RZR S frame tubes are a bit smaller than the back tubes. So, I took a die grinder and scribed a slot on the UTV Crap tubes all the way down as straight as I could. This worked for the seam but I still had trouble getting the tubes in as they are in about 6.5" which puts the reinforcing tube ahead of the rear mounting location of the lower a-arm by 1.5". I can't get it any further than this(beating with 8lb hammer). Will this be far enough in for support? You would think if the frame tubes were going to bend it would be behind the rear mounting point of the lower a-arm. Thanks.
Old October 18th, 2008, 05:51 PM
cwspfx's Avatar
Drive fast...take chances
First Name: Chris W.
My RZR: 09 RZR S
Member #3687
View cwspfx's Photo Gallery(0)
Re: Problem with UTV Crap frame tubes on RZR S
I think you are the first S to install them ...maybe? I haven't herd of anyone with a S installing them.
Old October 18th, 2008, 05:56 PM
Feedback Score: 5 reviews
Member #787
View johnnycat8's Photo Gallery(54) Send a message via Yahoo to johnnycat8
ya the tubes are for the regular old frame not the new frame that is differant should of checked before and also before complaining about something not made for your ride!!!!
lots of toy's
Old October 18th, 2008, 06:03 PM
Klutch's Avatar
Member #2493
Oookay, wasn't complaining, was asking a question as well as letting others know of what I ran into. UTV Crap thought they would work when I ordered them. They haven't tried them on a S either so it was a bit of a guess. How whould have I checked if I'm possibly the first one to try???
Old October 18th, 2008, 06:05 PM
cwspfx's Avatar
My RZR: 09 RZR S
Member #3687
Easy ...you two ...we are here to learn!!
LOL!!
I thought the S was already guseted more from the factory ...?
Old October 18th, 2008, 06:10 PM
Klutch's Avatar
Member #2493
It's all good, ha ha.
Old October 18th, 2008, 06:17 PM
cwspfx's Avatar
My RZR: 09 RZR S
Member #3687
So..I have a question
You said the front tube is smaller ... is the ID smaller and the tube the same on the OD. Making it just a thicker walled tube?
  #8
Old October 18th, 2008, 06:57 PM
Klutch's Avatar
Member #2493
I'm guessing it's a bit thicker walled tube. I don't have a standard rzr to measure the O.D. on that tube. But the I.D. is a smidge smaller. The rear tubes slid in without much tapping, so that is what I'm basing the smaller I.D. on.
  #9
Old October 18th, 2008, 07:05 PM
cwspfx's Avatar
My RZR: 09 RZR S
Member #3687
I know Polaris said they were increassing the tube thickness on the cages ... just wounder if they did it everwere ... its hard to really find out what is different on the S. There is defently incressed gusetting on all the A-arm points.
Are you going to drill and plug weld the add tubes? or are you just welding up the ends?
  #10
Old October 18th, 2008, 07:54 PM
crazywatson's Avatar
#13
First Name: steve
My RZR: red
Member #3534
I think the reason why jonnycat thought you were complaining is because when you look at recent threads it just says Problem with UTV crap......If you read the rest of the thread it does not sound like complaining.But is good to know for s owners and UTV crap
  #11
Old October 19th, 2008, 06:52 AM
Klutch's Avatar
Member #2493
I just took self tapping screws and secured them that way, works good and fast.
Bookmarks
RZR Frame Reinforcement Tubes Johnny UTV Crap 119 February 27th, 2010 06:17 PM
RZR S frame reinforcement tubes Johnny UTV Crap 24 December 3rd, 2009 01:59 PM
UTV Crap gusset tubes question? Klutch General RZR Discussion 4 October 3rd, 2008 09:32 AM
bent frame and another boot tore same one second time now anybody have this problem frosty09 General RZR Discussion 5 August 26th, 2008 09:25 AM
change axle tubes 726 General RZR Discussion 2 February 17th, 2008 07:56 PM
