Maximum Tire size on a 2011 standard.
This is a discussion on Maximum Tire size on a 2011 standard. within the General RZR Discussion forums, part of the General RZR category; Looking for some advice on gaining more clearance without installing a lift kit, and bigger tires seems like a logical way to go. I would ...
Old August 6th, 2011, 04:35 AM
Dennis01's Avatar
Member #24410
View Dennis01's Photo Gallery(0)
Looking for some advice on gaining more clearance without installing a lift kit, and bigger tires seems like a logical way to go. I would like to know how big I can go with the stock 12" rim, I've been told I should be able to go with 26 or even 27, (stock tires are 25X10X12 rear, 25X8X12 front). If I go with 27 will I have rubbing issues, and will I need wheel spacers?
Old August 6th, 2011, 05:22 AM
orangecrush's Avatar
Official Parts Breaker
Feedback Score: 13 reviews
My RZR: 2011 Rzr
Member #21745
View orangecrush's Photo Gallery(20)
Re: Maximum Tire size on a 2011 standard.
Keep one thing in mind... you may physically be able to put a set of 27’s on a rzr but the extra height will cut your gear ratio down effectively making the rzr sluggish IMO.
I put a set of 26’s on and IMO they were the perfect size because I always thought the 25’s looked too small (I have a 2” liftkit)
When I replace these tires, I’m going back to the 26’s.
25’s
Old August 6th, 2011, 05:29 AM
chipper's Avatar
Feedback Score: 4 reviews
First Name: Chip
My RZR: 2011 RZR
Member #15196
You will need wheel spacers because of the rear motor mount. I have 26 " bighorns which measure big and I had some rubbing on front fenders.
I recently got the forward a-arms from superatv and it'll take at least a 28" now and wouldn't rub.
As mark said you'll lose power which can be helped with a clutch kit.
Old August 6th, 2011, 07:14 AM
My RZR: 2011 Rzr
Member #21745
Sorry, forgot to mention that... my wheels are aftermarket and the offset is different so the rear motor mount wasn’t an issue for me (by less than a 1/4 “...lol)
I also bought the Holz clutch kit (WHICH I STRONGLY RECOMMEND) so it all works out...
Let us know what you do.
Mark
Old August 6th, 2011, 03:54 PM
Dennis01's Avatar
Member #24410
25’s
I think I would go with the 26 tires, what lift did you put on, and with the
26's and lift how much do you think you gained in clearance from stock. I am thinking of the racertech lift, did a lot of reascearch and from what i gather it's probably one of the few that won't cause cv joint problems.
Thanks for the reply.
Old August 6th, 2011, 04:14 PM
turkeyhunter's Avatar
First Name: gary
My RZR: 800 Turbo / XP turbo
Member #16815
View turkeyhunter's Photo Gallery(0)
Your right on the money with your choice. 26" with racertech lift and holz clutch kit. You'll be happy with the height and the performance.
Old August 6th, 2011, 04:44 PM
My RZR: 2011 Rzr
Member #21745
25’s
I went with the racertech lift, it gave me approx 3” of lift. Unfortunately, I installed a cage which weighs a bit more than stock and I changed over to Elka shocks. (I don’t have them turned up)
Right now with the cage and soft shocks, I’m probably not even 2” over stock. (I plan on cranking up the shocks soon)
I would go with the 26’s again....
Mark
2011 polaris rzr 800 eps tire sizes
2011 polaris rzr tire size
2011 polaris rzr tires and lift
2011 polaris rzr wheel spacer how big
largest size tire on stock wheel for a polaris rzr
max tire size on polaris rzr
polaris rzr s rear tire size 2011
rzr 800 max tire size
rzr london ky
rzr max tire size
rzr tire size
what size is the back tires on a 2011 polaris rzr
whats the max tire size to run on a stock rzr
wheel size for 2011 polaris razr
tire size flyingcatfish General RZR Discussion 6 October 31st, 2010 06:37 PM
actual tire size vs. advertised size crawlrinny Wheels and Tires 1 July 7th, 2010 08:12 PM
Wheel Size to Tire Size Chart? user_name Wheels and Tires 4 May 12th, 2010 01:55 PM
What size tire? BigBluff44 Wheels and Tires 6 April 19th, 2010 07:19 PM
Maximum Tire Size ??? jajl22 Wheels and Tires 2 July 30th, 2008 09:40 AM
