2011 rzr s won't start hot - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old July 16th, 2011, 06:10 AM Thread Starter
wv mountain man's Avatar
Member #23332
View wv mountain man's Photo Gallery(0)
My 2011 rzr won't start after turning it off when it is 204 temp. Have to let it cool down to around 180 to start, It run fine before and after. Any thought on want to ckeck?
Greg
wv mountain man is offline
post #2 of 17 Old July 16th, 2011, 06:27 AM
scubadnv's Avatar
First Name: Don & Viv
My RZR: 2011 RGE RZR-4
Member #21107
View scubadnv's Photo Gallery(30)
Re: 2011 rzr s won't start hot
Sounds like fuel is vapor locking in the fuel rail to the injectors. Try to cycle the key on for 2 seconds (without cranking the engine) and do this 10 times then try to start the engine. If this works, and I think it will, what you are doing is using fuel pressure to purge the fuel vapors from the system up to the injectors and replacing it with liquid fuel. You may want to give it a short crank on the 5th cycle to allow fuel vapors to be purged through the injectors and depending on how much vapor there may be in the system it may even start at that time.
scubadnv is offline
post #3 of 17 Old July 16th, 2011, 06:37 AM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Yep.
UTV Inc. makes a sweet little aluminum heat shield to protect the rail for turbos. That would likely do the trick for you long term. Just bolt it on. You'd have to ask for a part number, or look around their site. You could probably fab something up if you wanted to mess around with it. Theirs is nicely formed and fits perfectly around the fuel rail.
FunRide is offline
post #4 of 17 Old March 29th, 2013, 06:08 PM
papajohn's Avatar
Member #47864
View papajohn's Photo Gallery(0)
I have the same problem right now. Been fighting it for some time. Everything seems to point to vapor lock. im gonna try the heat shield thing.And maybe wrap the fuel rails with header tape. I just cant figure out why they ALL dont have this problem.
2011 graphite rally. Zillas on ss 108's stereo. Cooter Brown bed cover. GPS. MUCH MORE !!!!
papajohn is offline
post #5 of 17 Old March 29th, 2013, 07:15 PM
RZR_WV's Avatar
Member #38934
View RZR_WV's Photo Gallery(0)
I have had luck with letting the motor idel for about 30 sec after I stop then shuting her down.
RZR_WV is offline
post #6 of 17 Old March 29th, 2013, 09:05 PM
2011 RZR 800's Avatar
First Name: Kerry
My RZR: 2011 800 RZR 50
Member #23427
Pissed Re: 2011 rzr s won't start hot
Yep let it run till temp drops back to 194 and fan cuts off and it will start. It's been talked about in another thread. Hard to start when warm i think is the topic. You might try and search for it,Kerry
Racer Tech 2" Lift and Springs,Super ATV Winch,Polaris Sport Roof,Polaris Brush Guards,Super Daves Shock Bushings, Polaris 14" Wrec Wheels, ITP TERRACROSS Tires,Super ATV Harnesses,Polaris S fender flares
2011 RZR 800 is offline
post #7 of 17 Old March 30th, 2013, 03:05 PM
papajohn's Avatar
Member #47864
Ok, Went riding today. I tried turning the key on and off 10 times. it worked once. it was a little chilly out so i let it sit til the temp dropped below 188 degrees. Then it would start. im building a heat shield and wrapping them. it seems like the only real solution
papajohn is offline
post #8 of 17 Old March 30th, 2013, 03:08 PM
sandblster's Avatar
Member #46247
Might try ethanol free gas. Might make a big difference.
sandblster is offline
post #9 of 17 Old March 30th, 2013, 04:07 PM
Pirate's Avatar
First Name: Stuart
Member #3677
Hmmm....maybe its time to check the fuel pump pressure and see if the pump isn't part or all of the problem?
Just a thought...easy to do...
Pirate
Pirate is online now
post #10 of 17 Old March 31st, 2013, 12:18 PM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Agree with Pirate - check fuel pressure. If that turns out to not be the problem, there is another thread about this problem either on this forum or on the 800 forum. A dealer talked with Polaris about it. Here is what they recommend.
1) Don't use oxygenated fuel (use non ethenal fuel).
2) Don't shut off the engine when the fan is running - wait until the engine cools down and the fan stops.
3) If the stop is going to be less than 20 minutes, leave the engine running for the length of the stop.
Mike
MikeT is offline
post #11 of 17 Old March 31st, 2013, 05:56 PM
papajohn's Avatar
Member #47864
Its the heat. and i think i know why. My rzr is snorkeled . The old cvt exhaust has been removed. It used to blow air under the bed which used to cool it a bit. Polaris did this to keep the bed from getting so hot. When i was out the other day i tried turning the key on and off ten times. That worked once. i tried shutting it off when the fan quit running. That worked once. The only thing that worked every time was waiting til the temp gauge dropped below 188. More like 185. Then it started. im making a shield and wrapping the fuel rail with header tape. That should solve it. Or installing a fan but thats not the permanent solution . And if there is a bunch of mud on top of the engine , I imagine that doesnt help things either.
papajohn is offline
post #12 of 17 Old March 31st, 2013, 06:08 PM
mattmanstroked's Avatar
First Name: matthew
My RZR: 2012 RZR4
Member #40089
View mattmanstroked's Photo Gallery(0)
Mike
They actually said this is the fix just leave it running? Just think if the auto manufactures were to say something like that. The world would stop spinning. It is hard to believe some of the dumb ways they try to get out of actually fixing the problem.
mattmanstroked is offline
post #13 of 17 Old March 31st, 2013, 06:18 PM
sandblster's Avatar
Member #46247
Mike
No it actual is not. Diesel over the road are required a cool down time. It is called "heat soak" where a engine will heat up a lot after a run when shut off and not allowed to cool down. That is why a car electric fan will start after a shut down car sets awhile, to remove the "heat soak" effect.
post #14 of 17 Old March 31st, 2013, 06:19 PM
RZR_WV's Avatar
Member #38934
Just a side note my 500 efi Ranger was exactily the same way as my RZR. It is as simple as letting it idel for 30 seconds before you kill it.
RZR_WV is offline
post #15 of 17 Old March 31st, 2013, 06:35 PM
papajohn's Avatar
Member #47864
Ya right!! like everyone wants to hear your machine running everytime you stop to B.S.
as for leaving it run for 30 seconds. It didnt work for me.
papajohn is offline
Wet RZR won't start. Gundog General RZR Discussion 6 June 16th, 2011 07:39 PM
2011 RZR S will crank but not start Hemi Engine and Drivetrain 2 April 17th, 2011 01:26 PM
RZR 4 2011 wont start. cribbs13 Engine and Drivetrain 4 February 10th, 2011 05:11 PM
08 RZR - RPM very low at start up ;-) cisco kid Engine and Drivetrain 3 November 24th, 2009 06:52 AM
It's a start LTRZR Projects and How-To 14 January 9th, 2008 07:34 PM
