Foam filled roll cage stronger? |
October 5th, 2008, 02:25 PM
Do you guys think that filling roll gage with expanding foam would help to increase strength. May be a cheap way to make quick improvement. What do you think?
Re: Foam filled roll cage stronger? |
October 5th, 2008, 04:44 PM
My RZR: 09 RZR S
It will not increases the strength of the tube enough to help. You are talking about tube that has a, before 2009, 50,000 lbs tensile strength and 2009 and newer, 65K tensile strength. What do you think the tensile strength of 1 1/2 round foam might be? 3 or 5 lbs. If you are thinking that it might help it from deforming the tube, thus making it stronger ... If you are bending that tube ... the foam isn't going to slow it down enough to even measure!
October 6th, 2008, 08:00 AM
It will add strength. Try this--you'll be surprised: Take 2 McDonald straws and fill one with expanding foam. Let it cure a day then bend each one in the middle.
Some truck manufacturers have been injecting foam in their roof rails to increase strength without adding weight.
October 6th, 2008, 08:38 AM
My RZR: the green one
yes the use of expanding foam for additional strength is not a new concept. how much i don't claim to know, but it will add some beef to the cage.
October 6th, 2008, 08:53 AM
SSV Works
make sure you run your wires to the light bar FIRST....
October 6th, 2008, 09:22 AM
My RZR: 09 RZR S
There is no way that on .090 or .120 tube ...that the time spent getting it in is worth the amout it adds ... I would have to see the test data to belive anyone!
October 6th, 2008, 09:33 AM
UTVCRAP*****
First Name: Johnny
My RZR: the red one
hmmm sounds stupid to me .....but hunnie I didnt buy the life insurance because I filled my rollcage with foam
www.utvcrap.com 623-934-3070
623.934.3070
October 6th, 2008, 09:41 AM
UTVCRAP*****
First Name: Johnny
My RZR: the red one
alrighty thanks guys I just got banned from MickyDs for the rest of my life....while I was sittin eatin my lunch we decided to do the expanding foam test well dam that stuff sure expands when it stared running out the ends of test straw number 3 we knew there was going to be a problem test straw one and two were ok but 3-4-5 the foam started running out the ends and all over the table and floor
October 6th, 2008, 09:56 AM
Rhino defector
My RZR: green gen 3 racer
you guys have it all wrong!!!
you have to add 300psi of Helium for strength and it will lighten you overall weight.
October 6th, 2008, 09:57 AM
My RZR: 09 RZR S
LMFAO ....!!!
You are talking about filling something that has tensile strength of less then what you are filling it with. So it would work on a straw.
Not the same for 50k or 65k tensile strength tube ... the gains would not be worth while.
That is some funny $hit ... you guys
Don't forget to fill the tire also with Helium .... they spin faster!
October 6th, 2008, 10:01 AM
UTVCRAP*****
First Name: Johnny
My RZR: the red one
No I put the helium in the tires so I could jump futher
October 6th, 2008, 10:04 AM
My RZR: 09 RZR S
LOL ...AHHH thats right ...thanks for the corection!
October 6th, 2008, 10:05 AM
First Name: Rob
My RZR: Going to buy the Green RZR.
 You sound like the import guys who add stickers to gain HP!!
RobMR3
Looking to Buy RZR
October 6th, 2008, 10:13 AM
to the poster, yes you can add foam and it will add significant strength to the cage. it is a common practice. you guys joke....but it really works. here is a sample of foam they use in pontoon boats.
16 LB Density Urethane Foam
Common Applications: This 16LB density foam is essentially as hard as a rock, you would need a hammer in order to make any dents in this product. Can be used for sculpting or the casting of objects that require superior toughness and strength.
Free Rise Density: 16.0 lbs cubic ft.
Expansion Rate: Approx. 4x Liquid Volume
Buoyancy (flotation): 46 LBs per Cubic Ft.
*Physical Properties:
Parallel Compressive Strength: 580 psi
Tensile Strength: 450 psi
Shear Strength: 230 psi
Flexural Strength: 750 psi
the flex strength is excellent, just what a cage needs. in fact, here is a 8lb foam, half the strength of the first posted foam........
This 8LB density foam is extremely hard and rigid, like that of a soft wood. Your fingernail can penetrate its skin, however it cannot be dented by hand. Uses include casting, carving, sculpting, sign making as well as areas where an extremely durable and rigid foam is needed for support. More questions?
October 6th, 2008, 10:18 AM
UTVCRAP*****
First Name: Johnny
My RZR: the red one
No comment
