Winch is stuck - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old July 3rd, 2011, 11:17 AM Thread Starter
KEAppleby's Avatar
Winch is stuck
Hi, there: I have a winch on my Polaris which I hae been happily using to operate a snow plow and pull down dead trees. Now, the cable appears to be stuck -- at about 8 feet, "out" becomes "in" -- I assume because it's stuck so hard that it reverses. I've tried a variety of things -- pulling manually in "free spool",trying to "rock" it (in and out) while pulling the cable, hoping it will unwind itself, but no luck.
Anybody have any suggests as to how I can get unstuck? Thanks to all.
KEAppleby is offline
post #2 of 8 Old July 3rd, 2011, 11:33 AM
Feedback Score: 17 reviews
FJK's Avatar
Re: Winch is stuck
Try hooking it to a tree,set the free spool and back the rzr up slowly ,you can pull it out this way ,
FJK is offline
post #3 of 8 Old July 3rd, 2011, 12:35 PM
keith0715's Avatar
Re: Winch is stuck
i have had the same problem a few times. i did what fjk has stated and it works great. you might have to give it a good yank with the rzr. once it breaks free i leave the rzr tied to the tree and reel the cable in by pulling the rzr with the winch. it keeps the cable tight. also put rzr in neutral when doing this. good luck
08 rzr super atv s conversion with 5"lift, snorkels, 28inch gators, roll bar chopped 3in, home made doors, seat belt harness,:rzrs:
keith0715 is offline
post #4 of 8 Old July 3rd, 2011, 01:03 PM
spitse's Avatar
One time on my Honda, the cable was so Pinched in, it would not unwind by pulling with the rubi, so I had to remove the winch from the atv and open it up to remove the spindle. Then was able to pry the cable out so it could be rewound once the winch was reinstalled.
spitse is offline
post #5 of 8 Old July 3rd, 2011, 08:06 PM
<<< My personal RZR jack
gjem1's Avatar
Send a message via MSN to gjem1
Re: Winch is stuck
remember, A kinked cable become much weaker and because of these problems with reeling the steel cable in, i switched to synth cable... what a charm it is now
gjem1 is offline
post #6 of 8 Old July 4th, 2011, 03:53 AM
whiteeye42's Avatar
Re: Winch is stuck
If pulling it out with the rzr does not work you will have to cut it off the drum and then buy a new cable and even if you do get it to come free i would inspect it very close because a kinked cable is a weak cable.
11 polaris rzr 800 le
Be Good Play Nice and Share Your Toys
whiteeye42 is offline
post #7 of 8 Old July 4th, 2011, 07:44 AM
FJK's Avatar
Re: Winch is stuck
Put a heavy towel on the cable when you are pulling it out,it will keep it from coming back on you if it breaks.
FJK is offline
post #8 of 8 Old July 4th, 2011, 08:43 AM
Polaris Outlaw's Avatar
Re: Winch is stuck
Put it on freespool as mentioned, back up....keep backing until all 50' is off and then spring the $50 to get synth rope. The $50 for the rope is cheaper than any trip to the ER for the cable slicing your hand, snapping and cutting you, etc.
2011 RZR
29.5 Skinny Outlaws on black SS212
snorkels
Roktek 3" lift
Audio Formz stereo top
front and rear bumpers
Viper 3500 # winch
Polaris Outlaw is offline
Tags
winch
Stuck in 4wd. Why? biohazard58 General RZR Discussion 19 October 24th, 2015 04:10 PM
stuck rzr soyer General RZR Discussion 0 April 10th, 2011 04:00 PM
STUCK!!! Matt20o6 Muddin' 16 July 27th, 2010 04:05 PM
WTB Remote Winch Control for Polaris 3500 Winch RZRdudeNY Want to Buy 6 January 2nd, 2010 12:10 PM
