This is a discussion on 2011 Fan Issue (Circuit Breaker Location Problem) within the General RZR Discussion forums, part of the General RZR category; Searched the forum high and low recently to try to resolve an overheating issue. My main problem being the fan not running at all. Began ...
Began by removing air from system by raising front end, removing rad and overflow caps, running to temp and bleeding the system. Proceeded to check fan by running direct to battery and everything worked ok. Then swapped relays and again a no go. Then decided to look at the wire diagram for a fuse, and found that a circuit breaker is in-between the battery and fuse block. Normally they are found under dash, but after further breakdown and searching, mine was about 18" from battery laying between the skid plate and underbody. Of course a perfect area for mud and the last place to dry out, it was completed rusted/corroded. Below are pictures of one similar and the way I found mine. Rest assured its not going back to where it was on my machine. Now I now a lot of people stay clear of mud/water, but this is still no place for something that can go bad so fast and easily. My machine was built 08/10 and is currently at 27 hrs. Hopefully this may save others, my advice would be to just take a peak under the dash and see if yours is located in a dryer location that mine was. ![]()
| Sponsored Links | ||
Re: 2011 Fan Issue (Circuit Breaker Location Problem)
You should take a photo of were it's located at for others to see...and also how you re mount the new one.
link for crow dog's site!!! www.utvguide.net running makin trax afco shocks and springs |
Here is a picture of the offender. This is a pic of the bottom of the rzr, looking up from the ground. You will notice the underside of the battery box in the background.
My local dealer had a waterproof circuit breaker with a Polaris part # that I used. It was about 35$. |
That's why I like the dry dunes...lol. Thats a bad location
#8
You guys rock. Had my 2011 RZR back to the dealer TWICE to get this intermittent fan issue fixed. They couldn't figure it out.
Reading the forums and came across this - and yep, mine was completely rusted through. Thanks for sharing the information! - This forum pays for itself a few times a month! ![]() I am running new wiring and moving mine up behind the seat. Sitting on the skid plate.... What were they thinking!?
...doesn't look that deep.
#9
without reloaction this could you just put electric tape around the whole breaker to keep it from rusting cause mine look ok but i just want to do something to it before my rust out
2011 RZR S, EMP BUMPER, EMP A-ARM GUARDS TUSK SKID PLATE, SIMPSON HARNESS UTV INC HALF DOORS, UTV INC GUSSET KIT UTV INC INTRUSION BARS, UTV INC PARKING BRAKE FOX SHOCKS, RACER TECH HEAVY SPRINGS AMERICAN ROCK RODS HOOD PANELS 27" KENDA HTR
#10
Looking at the age and the amount of rust I would say someone made a huge mistake with the choice of relay AND the location.
Unreal kind of quality touch I see on the china crap ATV's |
#11
Here's where I moved mine - should slow the rusting and it'll be much easier to swap out when it does.
#12
Thanks for posting this same on mine and have relocated circuit breaker after my first one completely corroded thru.
2011 RZR 3500 lb Winch Polaris SixR rims with 26" Bighorns, RDC Lift/Shifter Handle/Flame Fairlead, front and rear bumpers, Pro Armor Doors, SSV Stereo, Snorkels 2010 850XPEPS 3500lb Winch, front and rear bumpers, handguards, heated thumb/handlebars, 60" Plow, 30" Silverbacks for Mud, 26" Bighorns for Trails, Tamarack Boom It rear box, RDC Gen II V2.0 Lift/Shifter Handle/Got Mud fairlead/Gas Cap/Rad Relocate, Center Snorks by Cooks Mills Customs, Dalton Clutch Kit, Gorilla Axles |
#13
Wow...That sucks! When I was washing mine yesterday, I was surprised to see the number of connections under the engine just laying on the skid plate, just waiting to soak up water and crap.
#14
So I just pulled my seats out, and sure enough, there's my circuit breaker....rusting away...Def not a water proof part. I'm wondering what to do about this...I've got the extended warranty for 4 years...If I screw with it, and my mod goes bad, engine goes, I'm at fault...If I leave it be, it will fail, while I'm stuck in the middle of some place. ARGH.
How is the circuit breaker attached to the harness? It's wrapped tight into the harness so I can't see w/o tearing it apart. |
#15
WTF !!!
Now I got to crawl under mine. You guys are right... that's the crap the Chinese companies would do. OK... I've seen thermal breakers in the wiring harness... but even if it was waterproof... who was the genius that decided to put it UNDER the RZR. I feel bad for the guys who put new skid plates on. They will have to take them off to get to it. |
| Search tags for this page |
2011 polaris rzr 800 fan circuit braker,2011 polaris rzr cooling fan fuse,2011 polaris rzr cooling problems,circuit breaker polaris rzr 2434017,location of fan circuit breaker 2011 rzr,polaris razor problems with fan,polaris rzr 2011 800 circuit breaker,polaris rzr 800 circuit braker,polaris rzr fan circuit breaker,polaris rzr fan circuit breaker#gsc.tab,polaris rzr fan circut breaker,polaris rzr fan problems,polaris rzr fan relay,rzr forum circuit breaker location,wher is the circut breaker for a rzrs
| Thread Tools | |
| Display Modes | |
| bead breaker | ocelotred05 | Wheels and Tires | 18 | December 19th, 2011 09:58 AM |
| 2011 RZR Voltage regulator Location. | wicked0ne | General RZR Discussion | 0 | June 15th, 2011 07:17 AM |
| clutch problem or belt issue | pawngod | Engine and Drivetrain | 7 | April 25th, 2010 11:38 AM |
| No power...breaker anywhere? | dwilsondvm | Lighting, Stereo and Electrical | 9 | December 28th, 2009 10:32 AM |
| Problem with Prerunner Rear bumper. Anyone else having this issue? | PistolPete | General RZR Discussion | 11 | September 29th, 2009 06:04 PM |
